[petsc-users] Build PETSc as shared library on Windows ("traditional" build or CMake)
E. Tadeu e.tadeu at gmail.com
Wed Mar 16 15:22:39 CDT 2016
Thanks Satish,
  Just to let you know, with a few minor modifications and extra
parameters, I've managed to build it using configure under Cygwin, and
then, outside cygwin, running non-cygwin cmake inside the "arch-..."
folder, targeting MSVC.
On Mon, Mar 14, 2016 at 6:31 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> you could try precompiled petsc from
> http://www.msic.ch/Downloads/Software
> [its old 3.5 version though]
> We don't have any changes wrt .dlls or cmake on windows..
> Satish
> On Mon, 14 Mar 2016, E. Tadeu wrote:
> > Hi,
> >   What is the current status of building PETSc as a shared library on
> > Windows? It seems non-trivial: `--with-shared-libraries=1` won't work,
> > since Cygwin's `ld` fails, and `win32fe` also fails.
> >   Also, what is the status of building PETSc with CMake on Windows?
> Perhaps
> > through using CMake it would be easier to generate the .DLL's, but I
> > couldn't find documentation on how to do this.
> >  Thanks!
> > Edson
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160316/a4241438/attachment.html>
