[petsc-users] Matrix reuse with changing structure
Smith, Kevin R. Kevin.R.Smith at jhuapl.edu
Tue Mar 15 12:56:28 CDT 2016
Barry - Yeah, I suspected it was doing this. In my original implementation I would get allocation errors.
Matt - Thanks, I will try this solution out.
Thanks for your help,
  Kevin
-----Original Message-----
Sent: Tuesday, March 15, 2016 1:48 PM
To: Matthew Knepley
Cc: Smith, Kevin R.; petsc-users at mcs.anl.gov
Subject: Re: [petsc-users] Matrix reuse with changing structure
> On Mar 15, 2016, at 12:28 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Mar 15, 2016 at 12:24 PM, Smith, Kevin R. <Kevin.R.Smith at jhuapl.edu> wrote:
> Hello,
> Is it possible to reuse a sparse matrix and not reuse its non-zero structure?   I have a matrix whose sparse structure changes each time. I’m hoping to avoid destroying and allocating new matrices each time the structure changes.
   Sure you can just add new nonzero locations at a later time. But it won't take out any current entries even if they are zero. So effectively the nonzero structure grows over time.
   Barry
> Hmm, I can't find a toplevel API that does this (it would be something like MatReset()). You can get this effect using
>   MatSetType(A, MATSHELL)
>   MatSetType(A, <type you had before>)
> A little messy but it will work.
>   Thanks,
>      Matt
> Thanks,
>   Kevin
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
