[petsc-users] PETSc without debugging
Michele Rosso mrosso at uci.edu
Mon Mar 14 20:10:42 CDT 2016
I compiled the development branch of PETSc with "--with-debugging=0",
but log_view warns me that I am running in debugging mode:
       #                          WARNING!!!                    #
       #   This code was compiled with a debugging option,      #
       #   To get timing results run ./configure                #
       #   using --with-debugging=no, the performance will      #
       #   be generally two or three times faster.              #
I attached the full output of log_view: it seems that I configured PETSc
correctly.
Can I safely ignore this or I am missing something?
Michele
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160314/812d9724/attachment.txt>
