[petsc-users] Questions about ASM in petsc4py
Mon Mar 14 14:02:14 CDT 2016
On Mon, Mar 14, 2016 at 12:58 PM, Chih-Hao Chen <
chih-hao.chen2 at mail.mcgill.ca> wrote:
> Hell Matt,
> Thanks for the information.
> I am still trying it now.
> But I observed an interesting thing about the performance difference when
> running ex8.c about the ASM.
> When using Mvapich2 for mph, its convergence speed is much faster than
> OpenMPI.
> Is it becasue the ASM function has been optimized based on Mvapich2?
No, it is probably because you have a different partition on the two cases.
For performance questions, we
need to see the output of -log_summary for each case.
    Matt
> Thanks very much.
> Best,
> Chih-Hao
> On Mar 10, 2016, at 4:28 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Mar 10, 2016 at 3:23 PM, Chih-Hao Chen <
>> Hello PETSc members,
>> Sorry for asking for help about the ASM in petsc4py.
>> Currently I am using your ASM as my preconditioned in my solver.
>> I know how to setup the PCASM based on the ex8.c in the following link.
>> http://www.mcs.anl.gov/petsc/petsc-3.4/src/ksp/ksp/examples/tutorials/ex8.c
>> But when using the function “getASMSubKSP” in petsc4py,
>> I have tried several methods, but still cannot get the subksp from each
>> mpi.
> The subKSPs do not have to do with MPI. On each rank, you get the local
> KSPs.
>> Here is the snippet of the code of the function.
>> def getASMSubKSP(self):        cdef PetscInt i = 0, n = 0        cdef PetscKSP *p = NULL        CHKERR( PCASMGetSubKSP(self.pc, &n, NULL, &p) )        return [ref_KSP(p[i]) for i from 0 <= i <n]
>> In ex8.c, we could use a “FOR” loop to access the indiivdual subksp.
>> But in python, could I use “FOR” loop to get all the subksps with:
>> subksp[i] = pc.getASMSubKSP[i]
> I do not understand this, but I think the answer is no.
>> Another question is in ex8.c, it seems I don’t need to do any setup to
>> decompose the RHS vector.
>> But do I need to decompose the RHS vector with any settings if I don’t
>> use PETSc solvers but with your preconditioners?
> I do not understand what you mean by "decompose the RHS vector".
>   Thanks,
>     Matt
>> Thanks very much.
>> Best,
>> Chih-Hao
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160314/9e7be200/attachment.html>
