[petsc-users] build with Scalapack/Blacs from MKL (failed to compile a test)
Mon Mar 14 11:22:08 CDT 2016
I do not know why this is hapenning. I just tried to reproduce - but it ran fine for me.
balay at es^/scratch/balay/petsc(master=) $ ./configure --with-cc=mpicc.openmpi --with-cxx=mpicxx.openmpi --with-fc=mpif90.openmpi --with-blas-lapack-dir=$MKL_HOME --with-scalapack-include=$MKL_HOME/include --with-scalapack-lib="-L$MKL_HOME/lib/intel64 -lmkl_scalapack_lp64 -lmkl_blacs_openmpi_lp64"
Is this issue reproduceable if you just configure with scalapack [as above?] - and not any other package?
What if you try using --download-openmpi - instead of ubuntu openmpi?
Sorry - I don't have a good answer for this issue..
Satish
On Mon, 14 Mar 2016, Denis Davydov wrote:
> Hi Satish,
> Please find the log attached.
> Kind regards,
> Denis
> > On 14 Mar 2016, at 16:59, Satish Balay <balay at mcs.anl.gov> wrote:
> > please send corresponding configure.log
> > Satish
> >> Dear all,
> >> What is the correct way to build PETSc with Scalapack/Blacs from MKL?
> >> I tried:
> >> —with-scalapack-lib=/path/to/mkl/lib/intel64/libmkl_scalapack_lp64.so /path/to/mkl/lib/intel64/libmkl_blacs_openmpi_lp64.so
> >> —with-scalapack-include=/path/to/mkl/include
> >> but PETSc config fails to compile a test program and gives a lot of
> >>       “undefined reference to ‘ompi_mpi_real’, ‘MPI_Allgather’, ‘MPI_Cart_create’” etc from libmkl_blacs_openmpi_lp64.so.
> >> Strangely enough I do see “-lmpi_f90 -lmpi_f77 -lmpi” in the compiler line, so i don’t know why these symbols are missing.
> >> Also MPI wrapper is used (/usr/bin/mpicc).
> >> I already built MUMPS without a problem and even tests run ok, so I am quite puzzled whether it’s something related to PETSc or MKL.
> >> p.s. I use OpenMPI provided by Ubuntu.
> >> Kind regards,
> >> Denis
