[petsc-users] Using TS
Max la Cour Christensen mlcch at dtu.dk
Sat Mar 12 05:41:33 CST 2016
Hi guys,
We are making preparations to implement adjoint based optimisation in our in-house oil and gas reservoir simulator. Currently our code uses PETSc's DMPlex, Vec, Mat, KSP and PC. We are still not using SNES and TS, but instead we have our own backward Euler and Newton-Raphson implementation. Due to the upcoming implementation of adjoints, we are considering changing the code and begin using TS and SNES.
After examining the PETSc manual and examples, we are still not completely clear on how to apply TS to our system of PDEs. In a simplified formulation, it can be written as:
\partial( \phi( p ) \rho_o( p ) S_o )/ \partial t = F_o(p,S)
\partial( \phi( p ) \rho_w( p ) S_w )/ \partial t = F_w(p,S)
S_o + S_w = 1,
where p is the pressure,
\phi( p ) is a porosity function depending on pressure,
\rho_x( p ) is a density function depending on pressure,
S_o is the saturation of oil,
S_g is the saturation of gas,
t is time,
F_x(p,S) is a function containing fluxes and source terms. The primary variables are p, S_o and S_w.
We are using a lowest order Finite Volume discretisation.
Now for implementing this in TS (with the prospect of later using TSAdjoint), we are not sure if we need all of the functions: TSSetIFunction, TSSetRHSFunction, TSSetIJacobian and TSSetRHSJacobian and what parts of the equations go where. Especially we are unsure of how to use the concept of a shifted jacobian (TSSetIJacobian).
Any advice you could provide will be highly appreciated.
Many thanks,
PhD student, Technical University of Denmark
