[petsc-users] asynchronous solve
Fri Mar 11 06:38:27 CST 2016
On Fri, Mar 11, 2016 at 12:48 AM, peter tutuk <petertututk at gmail.com> wrote:
> I am developing my own nonlinear solver and I would like to achieve
> asynchronous solve for subdomains.
> Is there any example around how to use PETSc in such a case? Or in
> general, is there a possibility to achieve desired behavior, while using
> PETSc ?
If you can achieve what you want using MPI, then we can definitely do it.
You will probably need to explain
to us how you want the parallel updates to go.
     Matt
> best,
> peter
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160311/ef49a7ad/attachment.html>
