[petsc-users] multigrid preconditioning and adaptivity
Lawrence Mitchell lawrence.mitchell at imperial.ac.uk
Mon Mar 7 08:21:15 CST 2016
On 07/03/16 14:16, Lukasz Kaczmarczyk wrote:
>> On 7 Mar 2016, at 13:50, Matthew Knepley <knepley at gmail.com
>> <mailto:knepley at gmail.com>> wrote:
>> On Mon, Mar 7, 2016 at 6:58 AM, Lukasz Kaczmarczyk
>> <Lukasz.Kaczmarczyk at glasgow.ac.uk
>> <mailto:Lukasz.Kaczmarczyk at glasgow.ac.uk>> wrote:
>>     Hello,
>>     I run multi-grid solver, with adaptivity, works well, however It
>>     is some space for improving efficiency. I using hierarchical
>>     approximation basis, for which
>>     construction of interpolation operators is simple, it is simple
>>     injection.
>>     After each refinement level (increase of order of approximation
>>     on some element) I rebuild multigrid pre-conditioner with
>>     additional level. It is a way to add dynamically new levels
>>     without need of rebuilding whole MG pre-conditioner.
>> That does not currently exist, however it would not be hard to add,
>> since the MG structure jsut consists of
>> arrays of pointers.
>>     Looking at execution profile I noticed that 50%-60% of time is
>>     spent on MatPtAP function during PCSetUP stage.
>> Which means you are using a Galerkin projection to define the coarse
>> operator. Do you have a direct way of defining
>> this operator (rediscretization)?
> Matt,
> Thanks for swift response. You are right, I using Galerkin projection.
> Yes, I have a way to get directly coarse operator, it is some sub
> matrix of whole matrix. I taking advantage here form hierarchical
> approximation.
> I could reimplement PCSetUp_MG to set the MG structure directly, but
> this probably not good approach, since my implementation which will
> work with current petsc version could be incompatible which  future
> changes in native MG data structures. The alternative option is to
> hack MatPtAP itself, and until petsc MG will use this, whatever
> changes you will make in MG in the future my code will work.
Why not provide a shell DM to the KSP that knows how to compute the
operators (and how to refine/coarsen and therefore
restrict/interpolate).  Then there's no need to use Galerkin coarse
grid operators, and the KSP will just call back to your code to create
the appropriate matrices.
Cheers,
Lawrence
Desc: OpenPGP digital signature
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160307/bfe74afe/attachment-0001.pgp>
