[petsc-users] PetscDSSetJacobianPreconditioner causing DIVERGED_LINE_SEARCH for multi-field problem
Thu Mar 3 11:00:13 CST 2016
On Thu, Mar 3, 2016 at 10:48 AM, Sander Arens <Sander.Arens at ugent.be> wrote:
> So is the block size here refering to the dimension of the near-nullspace
> or has it something to do with the coarsening?
> I would have thought to also see the block size in this part:
Dang, that is a problem. It should have the correct block size when FS
pulls it out of the overall matrix. This should be
passed down using the block size of the IS. Something has been broken here.
I will put it on my list of things to look at.
    Matt
>                   Mat Object:                           1 MPI processes
>                   type: seqaij
>                   rows=1701, cols=1701
>                   total: nonzeros=109359, allocated nonzeros=109359
>                   total number of mallocs used during MatSetValues calls =0
>                   has attached near null space
>                      using I-node routines: found 567 nodes, limit used is
> 5
> Thanks,
> Sander
> On 3 March 2016 at 17:29, Matthew Knepley <knepley at gmail.com> wrote:
>> You can see the block size in the output
>>                     type: seqaij
>>                     rows=12, cols=12, bs=6
>>                     total: nonzeros=144, allocated nonzeros=144
>> calls =0
>>                       using I-node routines: found 3 nodes, limit used is
>> 5
>>               linear system matrix = precond matrix:
>>                 type: seqaij
>>                   using I-node routines: found 3 nodes, limit used is 5
>>   Thanks,
>>     Matt
>> On Thu, Mar 3, 2016 at 10:28 AM, Sander Arens <Sander.Arens at ugent.be>
>> wrote:
>>> Sure, here it is.
>>> Thanks,
>>> Sander
>>> On 3 March 2016 at 15:33, Matthew Knepley <knepley at gmail.com> wrote:
>>>> On Thu, Mar 3, 2016 at 8:05 AM, Sander Arens <Sander.Arens at ugent.be>
>>>> wrote:
>>>>> Yes, the matrix is created by one of the assembly functions in Plex,
>>>>> so that answers my question. I was confused by this because I couldn't see
>>>>> this information when using -snes_view.
>>>> Hmm, then something is wrong because the block size should be printed
>>>> for the matrix at the end of the solver in -snes_view, Can you
>>>> send that to me?
>>>>   Thanks,
>>>>      Matt
>>>>> Thanks for the helpful replies,
>>>>> Sander
>>>>> On 3 March 2016 at 14:52, Matthew Knepley <knepley at gmail.com> wrote:
>>>>>> On Thu, Mar 3, 2016 at 7:49 AM, Sander Arens <Sander.Arens at ugent.be>
>>>>>> wrote:
>>>>>>> And how can I do this? Because when I look at all the options with
>>>>>>> -help I can strangely enough only find -fieldsplit_pressure_mat_block_size
>>>>>>> and not -fieldsplit_displacement_mat_block_size.
>>>>>> Maybe I am missing something here. The matrix from which you
>>>>>> calculate the preconditioner using GAMG must be created somewhere. Why
>>>>>> is the block size not specified at creation time? If the matrix is
>>>>>> created by one of the assembly functions in Plex, and the PetscSection has
>>>>>> a number of field components, then the block size will already be set.
>>>>>>   Thanks,
>>>>>>      Matt
>>>>>>> Thanks,
>>>>>>> Sander
>>>>>>> On 3 March 2016 at 14:21, Matthew Knepley <knepley at gmail.com> wrote:
>>>>>>>> On Thu, Mar 3, 2016 at 6:20 AM, Sander Arens <Sander.Arens at ugent.be
>>>>>>>> > wrote:
>>>>>>>>> Ok, I forgot to call SNESSetJacobian(snes, J, P, NULL, NULL) with
>>>>>>>>> J != P, which caused to write the mass matrix into the (otherwise zero)
>>>>>>>>> (1,1) block of the Jacobian and which was the reason for the linesearch to
>>>>>>>>> fail.
>>>>>>>>> However, after fixing that and trying to solve it with FieldSplit
>>>>>>>>> with LU factorization for the (0,0) block it failed because there were zero
>>>>>>>>> pivots for all rows.
>>>>>>>>> Anyway, I found out that attaching the mass matrix to the Lagrange
>>>>>>>>> multiplier field also worked.
>>>>>>>>> Another related question for my elasticity problem: after creating
>>>>>>>>> the rigid body modes with DMPlexCreateRigidBody and attaching it to the
>>>>>>>>> displacement field, does the matrix block size of the (0,0) block still
>>>>>>>>> have to be set for good performance with gamg? If so, how can I do this?
>>>>>>>> Yes, it should be enough to set the block size of the
>>>>>>>> preconditioner matrix.
>>>>>>>>   Matt
>>>>>>>>> Thanks,
>>>>>>>>> Sander
>>>>>>>>> On 2 March 2016 at 12:25, Matthew Knepley <knepley at gmail.com>
>>>>>>>>> wrote:
>>>>>>>>>> On Wed, Mar 2, 2016 at 5:13 AM, Sander Arens <
>>>>>>>>>>> Hi,
>>>>>>>>>>> I'm trying to set a mass matrix preconditioner for the Schur
>>>>>>>>>>> complement of an incompressible finite elasticity problem. I tried using
>>>>>>>>>>> the command PetscDSSetJacobianPreconditioner(prob, 1, 1, g0_pre_mass_pp,
>>>>>>>>>>> NULL, NULL, NULL) (field 1 is the Lagrange multiplier field).
>>>>>>>>>>> However, this causes a DIVERGED_LINE_SEARCH due to to Nan or Inf
>>>>>>>>>>> in the function evaluation after Newton iteration 1. (Btw, I'm using the
>>>>>>>>>>> next branch).
>>>>>>>>>>> Is this because I didn't use PetscDSSetJacobianPreconditioner
>>>>>>>>>>> for the other blocks (which uses the Jacobian itself for preconditioning)?
>>>>>>>>>>> If so, how can I tell Petsc to use the Jacobian for those blocks?
>>>>>>>>>> 1) I put that code in very recently, and do not even have
>>>>>>>>>> sufficient test, so it may be buggy
>>>>>>>>>> 2) If you are using FieldSplit, you can control which blocks come
>>>>>>>>>> from A and which come from the preconditioner P
>>>>>>>>>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCFieldSplitSetDiagUseAmat.html#PCFieldSplitSetDiagUseAmat
>>>>>>>>>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCFieldSplitSetOffDiagUseAmat.html#PCFieldSplitSetOffDiagUseAmat
>>>>>>>>>>> I guess when using PetscDSSetJacobianPreconditioner the
>>>>>>>>>>> preconditioner is recomputed at every Newton step, so for a constant mass
>>>>>>>>>>> matrix this might not be ideal. How can I avoid recomputing this at every
>>>>>>>>>>> Newton iteration?
>>>>>>>>>> Maybe we need another flag like
>>>>>>>>>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/SNES/SNESSetLagPreconditioner.html
>>>>>>>>>> or we need to expand
>>>>>>>>>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/SNES/SNESSetLagJacobian.html
>>>>>>>>>> to separately cover the preconditioner matrix. However, both
>>>>>>>>>> matrices are computed by one call so this would
>>>>>>>>>> involve interface changes to user code, which we do not like to
>>>>>>>>>> do. Right now it seems like a small optimization.
>>>>>>>>>> I would want to wait and see whether it would really be maningful.
>>>>>>>>>>   Thanks,
>>>>>>>>>>     Matt
>>>>>>>>>>> Thanks,
>>>>>>>>>>> Sander
>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>> experiments lead.
>>>>>>>>>> -- Norbert Wiener
>>>>>>>> experiments lead.
>>>>>>>> -- Norbert Wiener
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160303/fa2e327e/attachment.html>
