[petsc-users] PetscDSSetJacobianPreconditioner causing DIVERGED_LINE_SEARCH for multi-field problem
Sander Arens Sander.Arens at UGent.be
Thu Mar 3 06:20:21 CST 2016
Ok, I forgot to call SNESSetJacobian(snes, J, P, NULL, NULL) with J != P,
which caused to write the mass matrix into the (otherwise zero) (1,1) block
of the Jacobian and which was the reason for the linesearch to fail.
However, after fixing that and trying to solve it with FieldSplit with LU
factorization for the (0,0) block it failed because there were zero pivots
for all rows.
Anyway, I found out that attaching the mass matrix to the Lagrange
multiplier field also worked.
Another related question for my elasticity problem: after creating the
rigid body modes with DMPlexCreateRigidBody and attaching it to the
displacement field, does the matrix block size of the (0,0) block still
have to be set for good performance with gamg? If so, how can I do this?
Sander
On 2 March 2016 at 12:25, Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Mar 2, 2016 at 5:13 AM, Sander Arens <Sander.Arens at ugent.be>
> wrote:
>> Hi,
>> I'm trying to set a mass matrix preconditioner for the Schur complement
>> of an incompressible finite elasticity problem. I tried using the command
>> PetscDSSetJacobianPreconditioner(prob, 1, 1, g0_pre_mass_pp, NULL, NULL,
>> NULL) (field 1 is the Lagrange multiplier field).
>> However, this causes a DIVERGED_LINE_SEARCH due to to Nan or Inf in the
>> function evaluation after Newton iteration 1. (Btw, I'm using the next
>> branch).
>> Is this because I didn't use PetscDSSetJacobianPreconditioner for the
>> other blocks (which uses the Jacobian itself for preconditioning)? If so,
>> how can I tell Petsc to use the Jacobian for those blocks?
> 1) I put that code in very recently, and do not even have sufficient test,
> so it may be buggy
> 2) If you are using FieldSplit, you can control which blocks come from A
> and which come from the preconditioner P
> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCFieldSplitSetDiagUseAmat.html#PCFieldSplitSetDiagUseAmat
> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCFieldSplitSetOffDiagUseAmat.html#PCFieldSplitSetOffDiagUseAmat
>> I guess when using PetscDSSetJacobianPreconditioner the preconditioner is
>> recomputed at every Newton step, so for a constant mass matrix this might
>> not be ideal. How can I avoid recomputing this at every Newton iteration?
> Maybe we need another flag like
> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/SNES/SNESSetLagPreconditioner.html
> or we need to expand
> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/SNES/SNESSetLagJacobian.html
> to separately cover the preconditioner matrix. However, both matrices are
> computed by one call so this would
> involve interface changes to user code, which we do not like to do. Right
> now it seems like a small optimization.
> I would want to wait and see whether it would really be maningful.
>   Thanks,
>     Matt
>> Thanks,
>> Sander
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160303/55837aa4/attachment.html>
