[petsc-users] Strange GAMG performance for mixed FE formulation
Justin Chang jychang48 at gmail.com
Wed Mar 2 16:28:49 CST 2016
Dear all,
Using the firedrake project, I am solving this simple mixed poisson problem:
mesh = UnitCubeMesh(40,40,40)
V = FunctionSpace(mesh,"RT",1)
Q = FunctionSpace(mesh,"DG",0)
W = V*Q
v, p = TrialFunctions(W)
w, q = TestFunctions(W)
f = Function(Q)
f.interpolate(Expression("12*pi*pi*sin(pi*x[0]*2)*sin(pi*x[1]*2)*sin(2*pi*x[2])"))
a = dot(v,w)*dx - p*div(w)*dx + div(v)*q*dx
L = f*q*dx
u = Function(W)
solve(a==L,u,solver_parameters={...})
This problem has 1161600 degrees of freedom. The solver_parameters are:
-ksp_type gmres
-pc_type fieldsplit
-pc_fieldsplit_type schur
-pc_fieldsplit_schur_fact_type: upper
-pc_fieldsplit_schur_precondition selfp
-fieldsplit_0_ksp_type preonly
-fieldsplit_0_pc_type bjacobi
-fieldsplit_1_ksp_type preonly
-fieldsplit_1_pc_type hypre/ml/gamg
for the last option, I compared the wall-clock timings for hypre, ml,and
gamg. Here are the strong-scaling results (across 64 cores, 8 cores per
Intel Xeon E5-2670 node) for hypre, ml, and gamg:
hypre:
1 core: 47.5 s, 12 solver iters
2 cores: 34.1 s, 15 solver iters
4 cores: 21.5 s, 15 solver iters
8 cores: 16.6 s, 15 solver iters
16 cores: 10.2 s, 15 solver iters
24 cores: 7.66 s, 15 solver iters
32 cores: 6.31 s, 15 solver iters
40 cores: 5.68 s, 15 solver iters
48 cores: 5.36 s, 16 solver iters
56 cores: 5.12 s, 16 solver iters
64 cores: 4.99 s, 16 solver iters
ml:
1 core: 4.44 s, 14 solver iters
2 cores: 2.85 s, 16 solver iters
4 cores: 1.6 s, 17 solver iters
8 cores: 0.966 s, 17 solver iters
16 cores: 0.585 s, 18 solver iters
24 cores: 0.440 s, 18 solver iters
32 cores: 0.375 s, 18 solver iters
40 cores: 0.332 s, 18 solver iters
48 cores: 0.307 s, 17 solver iters
56 cores: 0.290 s, 18 solver iters
64 cores: 0.281 s, 18 solver items
gamg:
1 core: 613 s, 12 solver iters
2 cores: 204 s, 15 solver iters
4 cores: 77.1 s, 15 solver iters
8 cores: 38.1 s, 15 solver iters
16 cores: 15.9 s, 16 solver iters
24 cores: 9.24 s, 16 solver iters
32 cores: 5.92 s, 16 solver iters
40 cores: 4.72 s, 16 solver iters
48 cores: 3.89 s, 16 solver iters
56 cores: 3.65 s, 16 solver iters
64 cores: 3.46 s, 16 solver iters
The performance difference between ML and HYPRE makes sense to me, but what
I am really confused about is GAMG. It seems GAMG is really slow on a
single core but something internally is causing it to speed up
super-linearly as I increase the number of MPI processes. Shouldn't ML and
GAMG have the same performance? I am not sure what log outputs to give you
guys, but for starters, below is -ksp_view for the single core case with
GAMG
KSP Object:(solver_) 1 MPI processes
  type: gmres
    GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
Orthogonalization with no iterative refinement
    GMRES: happy breakdown tolerance 1e-30
  maximum iterations=10000, initial guess is zero
  tolerances:  relative=1e-07, absolute=1e-50, divergence=10000.
  left preconditioning
  using PRECONDITIONED norm type for convergence test
PC Object:(solver_) 1 MPI processes
  type: fieldsplit
    FieldSplit with Schur preconditioner, factorization UPPER
    Preconditioner for the Schur complement formed from Sp, an assembled
approximation to S, which uses (lumped, if requested) A00's diagonal's
inverse
    Split info:
    Split number 0 Defined by IS
    Split number 1 Defined by IS
    KSP solver for A00 block
      KSP Object:      (solver_fieldsplit_0_)       1 MPI processes
        type: preonly
        tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
        using NONE norm type for convergence test
      PC Object:      (solver_fieldsplit_0_)       1 MPI processes
        type: bjacobi
          block Jacobi: number of blocks = 1
          Local solve is same for all blocks, in the following KSP and PC
objects:
          KSP Object:          (solver_fieldsplit_0_sub_)           1 MPI
processes
            type: preonly
          PC Object:          (solver_fieldsplit_0_sub_)           1 MPI
processes
            type: ilu
              ILU: out-of-place factorization
              0 levels of fill
              tolerance for zero pivot 2.22045e-14
              matrix ordering: natural
              factor fill ratio given 1., needed 1.
                Factored matrix follows:
                  Mat Object:                   1 MPI processes
                    type: seqaij
                    rows=777600, cols=777600
                    package used to perform factorization: petsc
                    total: nonzeros=5385600, allocated nonzeros=5385600
                    total number of mallocs used during MatSetValues calls
=0
                      not using I-node routines
            linear system matrix = precond matrix:
            Mat Object:            (solver_fieldsplit_0_)             1 MPI
processes
              type: seqaij
              total number of mallocs used during MatSetValues calls =0
        Mat Object:        (solver_fieldsplit_0_)         1 MPI processes
          type: seqaij
    KSP solver for S = A11 - A10 inv(A00) A01
      KSP Object:      (solver_fieldsplit_1_)       1 MPI processes
        type: preonly
      PC Object:      (solver_fieldsplit_1_)       1 MPI processes
        type: gamg
          MG: type is MULTIPLICATIVE, levels=5 cycles=v
            Cycles per PCApply=1
            Using Galerkin computed coarse grid matrices
            GAMG specific options
              Threshold for dropping small values from graph 0.
              AGG specific options
                Symmetric graph false
        Coarse grid solver -- level -------------------------------
          KSP Object:          (solver_fieldsplit_1_mg_coarse_)           1
MPI processes
            type: preonly
            maximum iterations=1, initial guess is zero
          PC Object:          (solver_fieldsplit_1_mg_coarse_)           1
MPI processes
            type: bjacobi
PC objects:
              KSP Object:              (solver_fieldsplit_1_mg_coarse_sub_)
              1 MPI processes
                type: preonly
divergence=10000.
              PC Object:              (solver_fieldsplit_1_mg_coarse_sub_)
              1 MPI processes
                type: lu
                  using diagonal shift on blocks to prevent zero pivot
[INBLOCKS]
                  matrix ordering: nd
                  factor fill ratio given 5., needed 1.
                        type: seqaij
                        rows=9, cols=9
                        total: nonzeros=81, allocated nonzeros=81
calls =0
                          using I-node routines: found 2 nodes, limit used
is 5
                  type: seqaij
                  rows=9, cols=9
                    using I-node routines: found 2 nodes, limit used is 5
              type: seqaij
              rows=9, cols=9
        Down solver (pre-smoother) on level 1
          KSP Object:          (solver_fieldsplit_1_mg_levels_1_)
1 MPI processes
            type: chebyshev
              Chebyshev: eigenvalue estimates:  min = 0.0999525, max =
1.09948
              Chebyshev: eigenvalues estimated using gmres with
translations  [0. 0.1; 0. 1.1]
              KSP Object:
(solver_fieldsplit_1_mg_levels_1_esteig_)               1 MPI processes
                type: gmres
Gram-Schmidt Orthogonalization with no iterative refinement
                maximum iterations=10, initial guess is zero
                tolerances:  relative=1e-12, absolute=1e-50,
divergence=10000.
            maximum iterations=2
            using nonzero initial guess
          PC Object:          (solver_fieldsplit_1_mg_levels_1_)
1 MPI processes
            type: sor
              SOR: type = local_symmetric, iterations = 1, local iterations
= 1, omega = 1.
              type: seqaij
              rows=207, cols=207
              total: nonzeros=42849, allocated nonzeros=42849
                using I-node routines: found 42 nodes, limit used is 5
        Up solver (post-smoother) same as down solver (pre-smoother)
        Down solver (pre-smoother) on level 2
          KSP Object:          (solver_fieldsplit_1_mg_levels_2_)
1 MPI processes
            type: chebyshev
              Chebyshev: eigenvalue estimates:  min = 0.0996628, max =
1.09629
              KSP Object:
(solver_fieldsplit_1_mg_levels_2_esteig_)               1 MPI processes
                type: gmres
divergence=10000.
          PC Object:          (solver_fieldsplit_1_mg_levels_2_)
1 MPI processes
            type: sor
= 1, omega = 1.
              type: seqaij
              rows=5373, cols=5373
              total: nonzeros=28852043, allocated nonzeros=28852043
                using I-node routines: found 1481 nodes, limit used is 5
        Down solver (pre-smoother) on level 3
          KSP Object:          (solver_fieldsplit_1_mg_levels_3_)
1 MPI processes
            type: chebyshev
              Chebyshev: eigenvalue estimates:  min = 0.0994294, max =
1.09372
              KSP Object:
(solver_fieldsplit_1_mg_levels_3_esteig_)               1 MPI processes
                type: gmres
divergence=10000.
          PC Object:          (solver_fieldsplit_1_mg_levels_3_)
1 MPI processes
            type: sor
= 1, omega = 1.
              type: seqaij
              rows=52147, cols=52147
              total: nonzeros=38604909, allocated nonzeros=38604909
              total number of mallocs used during MatSetValues calls =2
        Down solver (pre-smoother) on level 4
          KSP Object:          (solver_fieldsplit_1_mg_levels_4_)
1 MPI processes
            type: chebyshev
              Chebyshev: eigenvalue estimates:  min = 0.158979, max =
1.74876
              KSP Object:
(solver_fieldsplit_1_mg_levels_4_esteig_)               1 MPI processes
                type: gmres
divergence=10000.
          PC Object:          (solver_fieldsplit_1_mg_levels_4_)
1 MPI processes
            type: sor
= 1, omega = 1.
            linear system matrix followed by preconditioner matrix:
            Mat Object:            (solver_fieldsplit_1_)             1 MPI
processes
              type: schurcomplement
              rows=384000, cols=384000
                Schur complement A11 - A10 inv(A00) A01
                A11
            1 MPI processes
                    type: seqaij
                    total: nonzeros=384000, allocated nonzeros=384000
=0
                A10
                    type: seqaij
                    rows=384000, cols=777600
                    total: nonzeros=1919999, allocated nonzeros=1919999
=0
                KSP of A00
            1 MPI processes
                    type: preonly
divergence=10000.
            1 MPI processes
                    type: bjacobi
KSP and PC objects:
                      KSP Object:
(solver_fieldsplit_0_sub_)                       1 MPI processes
                        type: preonly
divergence=10000.
                      PC Object:
                        type: ilu
                          0 levels of fill
                              Mat Object:                               1
MPI processes
                                type: seqaij
nonzeros=5385600
                        Mat Object:
                          type: seqaij
nonzeros=5385600
calls =0
                  1 MPI processes
                      type: seqaij
calls =0
                A01
                    type: seqaij
                    rows=777600, cols=384000
=0
              type: seqaij
              total: nonzeros=3416452, allocated nonzeros=3416452
        Mat Object:        (solver_fieldsplit_1_)         1 MPI processes
            A11
1 MPI processes
                type: seqaij
            A10
                type: seqaij
            KSP of A00
1 MPI processes
                type: preonly
divergence=10000.
1 MPI processes
                type: bjacobi
and PC objects:
                1 MPI processes
                    type: preonly
divergence=10000.
                1 MPI processes
                    type: ilu
                      0 levels of fill
                          Mat Object:                           1 MPI
processes
                            type: seqaij
nonzeros=5385600
                  1 MPI processes
                      type: seqaij
calls =0
      1 MPI processes
                  type: seqaij
            A01
                type: seqaij
          type: seqaij
    type: nest
    rows=1161600, cols=1161600
      Matrix object:
        type=nest, rows=2, cols=2
        MatNest structure:
        (0,0) : prefix="solver_fieldsplit_0_", type=seqaij, rows=777600,
cols=777600
        (0,1) : type=seqaij, rows=777600, cols=384000
        (1,0) : type=seqaij, rows=384000, cols=777600
        (1,1) : prefix="solver_fieldsplit_1_", type=seqaij, rows=384000,
cols=384000
Any insight as to what's happening? Btw this firedrake/petsc-mapdes is from
way back in october 2015 (yes much has changed since but
reinstalling/updating firedrake and petsc on LANL's firewall HPC machines
is a big pain in the ass).
Justin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160302/f3a7ee50/attachment-0001.html>
