[petsc-users] Example for FAS
Tue Mar 1 08:21:10 CST 2016
On Tue, Mar 1, 2016 at 8:08 AM, Jed Brown <jed at jedbrown.org> wrote:
> Cyrill Vonplanta <cyrill.von.planta at usi.ch> writes:
> > Dear PETSc User-list,
> > I am trying to use the FAS from PETSc in version 3.6.3. For other
> solvers there would be usually an example or two on the documentation, but
> on
> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/SNES/SNESFAS.html
> I couldn’t find one at the bottom.
> It's pure run-time options.  See src/snes/examples/tutorials/makefile
> and search for '-snes_type fas'.  ex5 and ex19 are good examples to
> check out.
I also have examples from SNES ex12 if you want an unstructured grid:
https://bitbucket.org/petsc/petsc/src/d076321ee94a992e029f0665fc86b0401d68c775/config/builder.py?at=master&fileviewer=file-view-default#builder.py-390
and here is a SNES ex5 example with FAS
https://bitbucket.org/petsc/petsc/src/d076321ee94a992e029f0665fc86b0401d68c775/src/snes/examples/tutorials/makefile?at=master&fileviewer=file-view-default#makefile-411
    Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160301/c48ef74a/attachment-0001.html>
