[petsc-users] MOOSE_SNES_ISSUES
Patrick Sanan patrick.sanan at gmail.com
Tue Mar 1 03:11:07 CST 2016
On Tue, Mar 01, 2016 at 09:58:18AM +0100, alena kopanicakova wrote:
> Hello,
> I am developing my own nonlinear solver, which aims to solve simulations
> from MOOSE. Communication with moose is done via SNES interface.
> I am obtaining Jacobian and residual in following way:
>            SNESComputeFunction(snes, X, R);
>           SNESSetJacobian(snes, jac, jac, SNESComputeJacobianDefault,
As here, http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/SNES/SNESComputeJacobianDefault.html ,
it seems like you are computing the Jacobian in a brute-force way with finite differences.
Do you have an expression to compute the Jacobian?
> NULL);
>           SNESComputeJacobian(snes, X, jac,  jac);
> Unfortunately, by this setting it takes incredible amount of time to obtain
> Jacobian.
> Taking closer look at perf log, it seems that difference between mine and
> MOOSE solver is, that my executioner calls compute_residual() function
> ridiculously many times.
> I have no idea, what could be causing such a behavior.
> Do you have any suggestions, how to set up interface properly? or which
> change is needed for obtaining more-less same performance as MOOSE
> executioner?
> many thanks,
> alena
> Framework Information:
> MOOSE version:           git commit e79292e on 2016-01-05
> PETSc Version:           3.6.1
> Current Time:            Tue Mar  1 00:51:45 2016
> Executable Timestamp:    Tue Mar  1 00:36:30 2016
> Parallelism:
>   Num Processors:          1
>   Num Threads:             1
> Mesh:
>   Distribution:            serial
>   Mesh Dimension:          3
>   Spatial Dimension:       3
>   Nodes:
>     Total:                 1331
>     Local:                 1331
>   Elems:
>     Total:                 1000
>     Local:                 1000
>   Num Subdomains:          1
>   Num Partitions:          1
> Nonlinear System:
>   Num DOFs:                3993
>   Num Local DOFs:          3993
>   Variables:               { "disp_x" "disp_y" "disp_z" }
>   Finite Element Types:    "LAGRANGE"
>   Approximation Orders:    "FIRST"
> Execution Information:
>   Executioner:             Steady
>   Solver Mode:             NEWTON
>  0 Nonlinear |R| = 2.850000e-02
>       0 Linear |R| = 2.850000e-02
>       1 Linear |R| = 1.653670e-02
>       2 Linear |R| = 1.447168e-02
>       3 Linear |R| = 1.392965e-02
>       4 Linear |R| = 1.258440e-02
>       5 Linear |R| = 1.007181e-02
>       6 Linear |R| = 8.264315e-03
>       7 Linear |R| = 6.541897e-03
>       8 Linear |R| = 4.371900e-03
>       9 Linear |R| = 2.100406e-03
>      10 Linear |R| = 1.227539e-03
>      11 Linear |R| = 1.026286e-03
>      12 Linear |R| = 9.180101e-04
>      13 Linear |R| = 8.087598e-04
>      14 Linear |R| = 6.435247e-04
>      15 Linear |R| = 5.358688e-04
>      16 Linear |R| = 4.551657e-04
>      17 Linear |R| = 4.090276e-04
>      18 Linear |R| = 3.359290e-04
>      19 Linear |R| = 2.417643e-04
>      20 Linear |R| = 1.710452e-04
>      21 Linear |R| = 1.261996e-04
>      22 Linear |R| = 9.384052e-05
>      23 Linear |R| = 6.070637e-05
>      24 Linear |R| = 4.283233e-05
>      25 Linear |R| = 3.383792e-05
>      26 Linear |R| = 2.342289e-05
>      27 Linear |R| = 1.700855e-05
>      28 Linear |R| = 9.814278e-06
>      29 Linear |R| = 4.398519e-06
>      30 Linear |R| = 2.161205e-06
>      31 Linear |R| = 1.289206e-06
>      32 Linear |R| = 6.548007e-07
>      33 Linear |R| = 3.677894e-07
>      34 Linear |R| = 2.640006e-07
>  1 Nonlinear |R| = 2.400310e-02
>       0 Linear |R| = 2.400310e-02
>       1 Linear |R| = 9.102075e-03
>       2 Linear |R| = 5.017381e-03
>       3 Linear |R| = 3.840732e-03
>       4 Linear |R| = 2.990685e-03
>       5 Linear |R| = 1.990203e-03
>       6 Linear |R| = 1.085764e-03
>       7 Linear |R| = 4.657779e-04
>       8 Linear |R| = 3.049692e-04
>       9 Linear |R| = 1.625839e-04
>      10 Linear |R| = 1.124700e-04
>      11 Linear |R| = 7.764153e-05
>      12 Linear |R| = 5.698577e-05
>      13 Linear |R| = 4.581843e-05
>      14 Linear |R| = 4.262610e-05
>      15 Linear |R| = 3.792804e-05
>      16 Linear |R| = 3.404168e-05
>      17 Linear |R| = 2.536004e-05
>      18 Linear |R| = 1.577559e-05
>      19 Linear |R| = 9.099392e-06
>      20 Linear |R| = 6.140685e-06
>      21 Linear |R| = 5.083606e-06
>      22 Linear |R| = 4.521560e-06
>      23 Linear |R| = 3.601845e-06
>      24 Linear |R| = 2.776090e-06
>      25 Linear |R| = 2.252274e-06
>      26 Linear |R| = 1.898090e-06
>      27 Linear |R| = 1.620684e-06
>      28 Linear |R| = 1.395574e-06
>      29 Linear |R| = 1.157953e-06
>      30 Linear |R| = 9.540738e-07
>      31 Linear |R| = 8.487724e-07
>      32 Linear |R| = 7.634710e-07
>      33 Linear |R| = 6.254549e-07
>      34 Linear |R| = 4.811588e-07
>      35 Linear |R| = 3.930739e-07
>      36 Linear |R| = 3.340577e-07
>      37 Linear |R| = 2.873430e-07
>      38 Linear |R| = 2.407606e-07
>      39 Linear |R| = 1.978818e-07
>  2 Nonlinear |R| = 4.185813e-04
>       0 Linear |R| = 4.185813e-04
>       1 Linear |R| = 1.406808e-04
>       2 Linear |R| = 7.266714e-05
>       3 Linear |R| = 5.734138e-05
>       4 Linear |R| = 4.524739e-05
>       5 Linear |R| = 3.025661e-05
>       6 Linear |R| = 1.946626e-05
>       7 Linear |R| = 1.005809e-05
>       8 Linear |R| = 7.639142e-06
>       9 Linear |R| = 6.668613e-06
>      10 Linear |R| = 6.070601e-06
>      11 Linear |R| = 5.496769e-06
>      12 Linear |R| = 4.388115e-06
>      13 Linear |R| = 2.966258e-06
>      14 Linear |R| = 1.838201e-06
>      15 Linear |R| = 9.709174e-07
>      16 Linear |R| = 6.743766e-07
>      17 Linear |R| = 5.531138e-07
>      18 Linear |R| = 4.649969e-07
>      19 Linear |R| = 3.982799e-07
>      20 Linear |R| = 3.662679e-07
>      21 Linear |R| = 3.309140e-07
>      22 Linear |R| = 2.652039e-07
>      23 Linear |R| = 1.728911e-07
>      24 Linear |R| = 1.005779e-07
>      25 Linear |R| = 5.747041e-08
>      26 Linear |R| = 4.185011e-08
>      27 Linear |R| = 3.394446e-08
>      28 Linear |R| = 2.788435e-08
>      29 Linear |R| = 2.046992e-08
>      30 Linear |R| = 1.231943e-08
>      31 Linear |R| = 8.724911e-09
>      32 Linear |R| = 6.390162e-09
>      33 Linear |R| = 5.060595e-09
>      34 Linear |R| = 4.216656e-09
>      35 Linear |R| = 2.969865e-09
>  3 Nonlinear |R| = 2.494055e-07
>       0 Linear |R| = 2.494055e-07
>       1 Linear |R| = 8.559637e-08
>       2 Linear |R| = 4.335101e-08
>       3 Linear |R| = 3.214303e-08
>       4 Linear |R| = 2.549409e-08
>       5 Linear |R| = 1.899624e-08
>       6 Linear |R| = 1.522624e-08
>       7 Linear |R| = 1.258408e-08
>       8 Linear |R| = 1.098545e-08
>       9 Linear |R| = 1.009481e-08
>      10 Linear |R| = 8.423983e-09
>      11 Linear |R| = 6.946144e-09
>      12 Linear |R| = 5.624875e-09
>      13 Linear |R| = 4.448760e-09
>      14 Linear |R| = 2.834320e-09
>      15 Linear |R| = 1.614722e-09
>      16 Linear |R| = 9.409384e-10
>      17 Linear |R| = 7.775851e-10
>      18 Linear |R| = 6.905971e-10
>      19 Linear |R| = 6.129201e-10
>      20 Linear |R| = 5.438935e-10
>      21 Linear |R| = 4.435519e-10
>      22 Linear |R| = 3.486621e-10
>      23 Linear |R| = 2.811928e-10
>      24 Linear |R| = 2.159800e-10
>      25 Linear |R| = 1.670940e-10
>      26 Linear |R| = 1.338889e-10
>      27 Linear |R| = 9.926067e-11
>      28 Linear |R| = 7.483221e-11
>      29 Linear |R| = 5.045662e-11
>      30 Linear |R| = 2.772335e-11
>      31 Linear |R| = 1.814968e-11
>      32 Linear |R| = 1.264268e-11
>      33 Linear |R| = 9.856586e-12
>      34 Linear |R| = 7.802757e-12
>      35 Linear |R| = 6.092276e-12
>      36 Linear |R| = 4.785005e-12
>      37 Linear |R| = 3.887554e-12
>      38 Linear |R| = 3.125756e-12
>      39 Linear |R| = 2.543989e-12
>      40 Linear |R| = 2.062100e-12
>  4 Nonlinear |R| = 2.522382e-12
> | Whale Performance: Alive time=4.25229, Active time=4.12034                                                 |
> | Event                         nCalls     Total Time  Avg Time    Total Time  Avg Time    % of Active Time  |
> |                                          w/o Sub     w/o Sub     With Sub    With Sub    w/o S    With S   |
> | Exodus        |
> |   output()                    2          0.0126      0.006300    0.0126      0.006300    0.31     0.31     |
> | Setup        |
> |   computeAuxiliaryKernels()   2          0.0000      0.000000    0.0000      0.000000    0.00     0.00     |
> |   computeControls()           2          0.0000      0.000001    0.0000      0.000001    0.00     0.00     |
> |   computeUserObjects()        4          0.0000      0.000001    0.0000      0.000001    0.00     0.00     |
> | Solve        |
> |   ComputeResidualThread       330        3.8288      0.011603    3.8288      0.011603    92.93    92.93    |
> |   computeDiracContributions() 331        0.0002      0.000001    0.0002      0.000001    0.00     0.00     |
> |   compute_jacobian()          1          0.1302      0.130242    0.1302      0.130243    3.16     3.16     |
> |   compute_residual()          330        0.0394      0.000119    3.8724      0.011735    0.96     93.98    |
> |   residual.close3()           330        0.0020      0.000006    0.0020      0.000006    0.05     0.05     |
> |   residual.close4()           330        0.0019      0.000006    0.0019      0.000006    0.05     0.05     |
> |   solve()                     1          0.1052      0.105226    4.1079      4.107900    2.55     99.70    |
> | Totals:                       1663       4.1203                                          100.00            |
> | Setup Performance: Alive time=4.25186, Active time=0.060553                                                             |
> | Setup        |
> |   Create Executioner                       1          0.0003      0.000313    0.0003      0.000313    0.52     0.52     |
> |   FEProblem::init::meshChanged()           1          0.0016      0.001626    0.0016      0.001626    2.69     2.69     |
> |   Initial computeUserObjects()             1          0.0000      0.000005    0.0000      0.000005    0.01     0.01     |
> |   Initial execMultiApps()                  1          0.0000      0.000003    0.0000      0.000003    0.00     0.00     |
> |   Initial execTransfers()                  1          0.0000      0.000001    0.0000      0.000001    0.00     0.00     |
> |   Initial updateActiveSemiLocalNodeRange() 1          0.0004      0.000396    0.0004      0.000396    0.65     0.65     |
> |   Initial updateGeomSearch()               2          0.0000      0.000002    0.0000      0.000002    0.00     0.00     |
> |   NonlinearSystem::update()                1          0.0000      0.000036    0.0000      0.000036    0.06     0.06     |
> |   Output Initial Condition                 1          0.0107      0.010671    0.0107      0.010671    17.62    17.62    |
> |   Prepare Mesh                             1          0.0017      0.001737    0.0017      0.001737    2.87     2.87     |
> |   copySolutionsBackwards()                 1          0.0000      0.000023    0.0000      0.000023    0.04     0.04     |
> |   eq.init()                                1          0.0455      0.045469    0.0455      0.045469    75.09    75.09    |
> |   getMinQuadratureOrder()                  1          0.0000      0.000004    0.0000      0.000004    0.01     0.01     |
> |   initial adaptivity                       1          0.0000      0.000000    0.0000      0.000000    0.00     0.00     |
> |   maxQps()                                 1          0.0003      0.000263    0.0003      0.000263    0.43     0.43     |
> |   reinit() after updateGeomSearch()        1          0.0000      0.000001    0.0000      0.000001    0.00     0.00     |
> | ghostGhostedBoundaries        |
> |   eq.init()                                1          0.0000      0.000002    0.0000      0.000002    0.00     0.00     |
> | Totals:                                    18         0.0606                                          100.00            |
> Current Time:            Tue Mar  1 00:41:08 2016
> Parallelism:
>   Num Processors:          1
>   Num Threads:             1
> Mesh:
>   Mesh Dimension:          3
>   Nodes:
>     Total:                 1331
>     Local:                 1331
>   Elems:
>     Total:                 1000
>     Local:                 1000
>   Num Subdomains:          1
>   Num Partitions:          1
> Nonlinear System:
>   Num DOFs:                3993
>   Executioner:             PassoSteady
>   Solver Mode:             NEWTON
> In Function SNESCreate_passo_Newton_Solver
>       it.          || g ||
>          1        0.0240028
>          2      0.000418569
>          3      2.49436e-07
>          4      1.52966e-12
> Solver converged in 4 iterations.
> Outlier Variable Residual Norms:
>   disp_z: 2.850000e-02
> | Whale Performance: Alive time=199.422, Active time=199.285                                                 |
> | Exodus        |
> |   output()                    2          0.0110      0.005503    0.0110      0.005503    0.01     0.01     |
> | Setup        |
> |   computeAuxiliaryKernels()   2          0.0000      0.000001    0.0000      0.000001    0.00     0.00     |
> |   computeControls()           2          0.0000      0.000000    0.0000      0.000000    0.00     0.00     |
> | Solve        |
> |   ComputeResidualThread       15985      189.8671    0.011878    189.8671    0.011878    95.27    95.27    |
> |   computeDiracContributions() 15986      0.0106      0.000001    0.0106      0.000001    0.01     0.01     |
> |   compute_jacobian()          1          0.1265      0.126484    0.1265      0.126485    0.06     0.06     |
> |   compute_residual()          15985      2.1702      0.000136    192.3009    0.012030    1.09     96.50    |
> |   residual.close3()           15985      0.1200      0.000008    0.1200      0.000008    0.06     0.06     |
> |   residual.close4()           15985      0.1263      0.000008    0.1263      0.000008    0.06     0.06     |
> |   solve()                     1          6.8537      6.853733    199.2830    199.282969  3.44     100.00   |
> | Totals:                       79938      199.2854                                        100.00            |
> | Setup Performance: Alive time=199.422, Active time=0.055161                                                             |
> | Setup        |
> |   Create Executioner                       1          0.0003      0.000315    0.0003      0.000315    0.57     0.57     |
> |   FEProblem::init::meshChanged()           1          0.0016      0.001593    0.0016      0.001593    2.89     2.89     |
> |   Initial execMultiApps()                  1          0.0000      0.000003    0.0000      0.000003    0.01     0.01     |
> |   Initial execTransfers()                  1          0.0000      0.000000    0.0000      0.000000    0.00     0.00     |
> |   Initial updateActiveSemiLocalNodeRange() 1          0.0004      0.000380    0.0004      0.000380    0.69     0.69     |
> |   Initial updateGeomSearch()               2          0.0000      0.000001    0.0000      0.000001    0.00     0.00     |
> |   NonlinearSystem::update()                1          0.0000      0.000034    0.0000      0.000034    0.06     0.06     |
> |   Output Initial Condition                 1          0.0091      0.009094    0.0091      0.009094    16.49    16.49    |
> |   Prepare Mesh                             1          0.0018      0.001766    0.0018      0.001766    3.20     3.20     |
> |   copySolutionsBackwards()                 1          0.0000      0.000025    0.0000      0.000025    0.05     0.05     |
> |   eq.init()                                1          0.0417      0.041668    0.0417      0.041668    75.54    75.54    |
> |   maxQps()                                 1          0.0003      0.000270    0.0003      0.000270    0.49     0.49     |
> |   eq.init()                                1          0.0000      0.000001    0.0000      0.000001    0.00     0.00     |
> | Totals:                                    18         0.0552                                          100.00            |
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160301/fd7861ce/attachment-0001.pgp>
