[petsc-users] Petsc mesh scalability issue with iterative solver and direct solver
Fri Jul 29 13:09:46 CDT 2016
  First run  under valgrind all the cases to make sure there is not some use of uninitialized data or overwriting of data. Go to http://www.mcs.anl.gov/petsc follow the link to FAQ and search for valgrind (the web server seems to be broken at the moment).
  Second it is possible that your code the assembles the matrices and vectors is not correctly assembling it for either the sequential or parallel case. Hence a different number of processes could be generating a different linear system hence inconsistent results. How are you handling the parallelism? How do you know the matrix generated in parallel is identically to that sequentially?
Simple preconditioners such as pbjacobi will converge slower and slower with more elements.
Note that you should run with -ksp_monitor_true_residual and -ksp_converged_reason to make sure that the iterative solver is even converging. By default PETSc KSP solvers do not stop with a big error message if they do not converge so you need make sure they are always converging.
   Barry
> On Jul 29, 2016, at 11:46 AM, Jinlei Shen <jshen25 at jhu.edu> wrote:
> Dear PETSC developers,
> Thank you for developing such a powerful tool for scientific computations.
> I'm currently trying to run a simple cantilever beam FEM to test the scalability of PETSC on multi-processors. I also want to verify whether iterative solver or direct solver is more efficient for parallel large FEM problem.
> Problem description, An Euler elementary cantilever beam with point load at the end along -y direction. Each node has 2 DOF (deflection and rotation)). MPIBAIJ is used with bs = 2, dnnz and onnz are determined based on the connectivity. Loop with elements in each processor to assemble the global matrix with same element stiffness matrix. The boundary condition is set using call MatZeroRowsColumns(SG,2,g_BC,one,PETSC_NULL_OBJECT,PETSC_NULL_OBJECT,ierr);
> Based on what I have done, I find the computations work well, i.e the results are correct compared with theoretical solution, for small mesh size (small than 5000 elements) using both solvers with different numbers of processes.
> However, there are several confusing issues when I increase the mesh size to 10000 and more elements with iterative solve(CG + PCBJACOBI)
> 1. For 10k elements, I can get accurate solution using iterative solver with uni-processor(i.e. only one process). However, when I use 2-8 processes, it tells the linear solver converged with different iterations, but, the results are all different for different processes and erroneous. The wired thing is when I use >9 processes, the results are correct again. I am really confused by this. Could you explain me why?  If my parallelization is not correct, why it works for small cases? And I check the global matrix and RHS vector and didn't see any mallocs during the process.
> 2. For 30k elements, if I use one process, it says: Linear solve did not converge due to DIVERGED_INDEFINITE_PC. Does this commonly happen for large sparse matrix? If so, is there any stable solver or pc for large problem?
> For parallel computing using direct solver(SUPERLU_DIST + PCLU), I can only get accuracy when the number of elements are below 5000. There must be something wrong. The way I use the superlu_dist solver is first convert MatType to AIJ, then call PCFactorSetMatSolverPackage, and change the PC to PCLU. Do I miss anything else to run SUPER_LU correctly?
> I also use SUPER_LU and iterative solver(CG+PCBJACOBI) to solve the sequential version of the same problem. The results shows that iterative solver works well for <50k elements, while SUPER_LU only gets right solution below 5k elements. Can I say iterative solver is better than SUPER_LU for large problem? How can I improve the solver to copy with very large problem, such as million by million? Another thing is it's still doubtable of performance of SUPER_LU.
> For the inaccuracy issue, do you think it may be due to the memory? However, there is no memory error showing during the execution.
> I really appreciate someone could resolve those puzzles above for me. My goal is to replace the current SUPER_LU  solver in my parallel CPFEM main program with the iterative solver using PETSC.
> Please let me if you would like to see my code in detail.
> Thank you very much.
> Bests,
> Jinlei
