[petsc-users] block matrix without MatCreateNest
Klaij, Christiaan C.Klaij at marin.nl
Thu Jul 28 03:38:54 CDT 2016
I'm trying to understand how to assemble a block matrix in a
format-independent manner, so that I can switch between types
mpiaij and matnest.
The manual states that the key to format-independent assembly is
to use MatGetLocalSubMatrix. So, in the code below, I'm using
this to assemble a 3-by-3 block matrix A and setting the diagonal
of block A02. This seems to work for type mpiaij, but not for
type matnest. What am I missing?
Chris
$ cat mattry.F90
program mattry
  use petscksp
  implicit none
#include <petsc/finclude/petsckspdef.h>
  PetscInt :: n=4   ! setting 4 cells per process
  PetscErrorCode         :: ierr
  PetscInt               :: size,rank,i
  Mat                    :: A,A02
  IS                     :: isg0,isg1,isg2
  IS                     :: isl0,isl1,isl2
  ISLocalToGlobalMapping :: map
  integer, allocatable, dimension(:) :: idx
  call PetscInitialize(PETSC_NULL_CHARACTER,ierr); CHKERRQ(ierr)
  call MPI_Comm_size(PETSC_COMM_WORLD,size,ierr); CHKERRQ(ierr)
  call MPI_Comm_rank(PETSC_COMM_WORLD,rank,ierr);CHKERRQ(ierr)
  ! local index sets for 3 fields
  allocate(idx(n))
  idx=(/ (i-1, i=1,n) /)
  call ISCreateGeneral(PETSC_COMM_WORLD,n,idx,PETSC_COPY_VALUES,isl0,ierr);CHKERRQ(ierr)
  call ISCreateGeneral(PETSC_COMM_WORLD,n,idx+n,PETSC_COPY_VALUES,isl1,ierr);CHKERRQ(ierr)
  call ISCreateGeneral(PETSC_COMM_WORLD,n,idx+2*n,PETSC_COPY_VALUES,isl2,ierr);CHKERRQ(ierr)
!  call ISView(isl3,PETSC_VIEWER_STDOUT_WORLD,ierr); CHKERRQ(ierr)
  deallocate(idx)
  ! global index sets for 3 fields
  allocate(idx(n))
  idx=(/ (i-1+rank*3*n, i=1,n) /)
  call ISCreateGeneral(PETSC_COMM_WORLD,n,idx,PETSC_COPY_VALUES,isg0,ierr);CHKERRQ(ierr)
  call ISCreateGeneral(PETSC_COMM_WORLD,n,idx+n,PETSC_COPY_VALUES,isg1,ierr); CHKERRQ(ierr)
  call ISCreateGeneral(PETSC_COMM_WORLD,n,idx+2*n,PETSC_COPY_VALUES,isg2,ierr); CHKERRQ(ierr)
!  call ISView(isg3,PETSC_VIEWER_STDOUT_WORLD,ierr); CHKERRQ(ierr)
  deallocate(idx)
  ! local-to-global mapping
  allocate(idx(3*n))
  idx=(/ (i-1+rank*3*n, i=1,3*n) /)
  call ISLocalToGlobalMappingCreate(PETSC_COMM_WORLD,1,3*n,idx,PETSC_COPY_VALUES,map,ierr); CHKERRQ(ierr)
!  call ISLocalToGlobalMappingView(map,PETSC_VIEWER_STDOUT_WORLD,ierr); CHKERRQ(ierr)
  deallocate(idx)
  ! create the 3-by-3 block matrix
  call MatCreate(PETSC_COMM_WORLD,A,ierr); CHKERRQ(ierr)
  call MatSetSizes(A,3*n,3*n,PETSC_DECIDE,PETSC_DECIDE,ierr); CHKERRQ(ierr)
!  call MatSetType(A,MATNEST,ierr); CHKERRQ(ierr)
  call MatSetUp(A,ierr); CHKERRQ(ierr)
  call MatSetOptionsPrefix(A,"A_",ierr); CHKERRQ(ierr)
  call MatSetLocalToGlobalMapping(A,map,map,ierr); CHKERRQ(ierr)
  call MatSetFromOptions(A,ierr); CHKERRQ(ierr)
  ! set diagonal of block A02 to 0.65
  call MatGetLocalSubmatrix(A,isl0,isl2,A02,ierr); CHKERRQ(ierr)
  do i=1,n
     call MatSetValuesLocal(A02,1,i-1,1,i-1,0.65d0,INSERT_VALUES,ierr); CHKERRQ(ierr)
  end do
  call MatRestoreLocalSubMatrix(A,isl0,isl2,A02,ierr); CHKERRQ(ierr)
  call MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY,ierr); CHKERRQ(ierr)
  call MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY,ierr); CHKERRQ(ierr)
  ! verify
  call MatGetSubmatrix(A,isg0,isg2,MAT_INITIAL_MATRIX,A02,ierr); CHKERRQ(ierr)
  call MatView(A02,PETSC_VIEWER_STDOUT_WORLD,ierr);CHKERRQ(ierr)
  call PetscFinalize(ierr)
end program mattry
$ mpiexec -n 2 ./mattry -A_mat_type mpiaij
Mat Object: 2 MPI processes
  type: mpiaij
row 0: (0, 0.65)
row 1: (1, 0.65)
row 2: (2, 0.65)
row 3: (3, 0.65)
row 4: (4, 0.65)
row 5: (5, 0.65)
row 6: (6, 0.65)
row 7: (7, 0.65)
$ mpiexec -n 2 ./mattry -A_mat_type nest
[0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[0]PETSC ERROR: Null argument, when expecting valid pointer
[0]PETSC ERROR: Null Pointer: Parameter # 3
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.7.3, Jul, 24, 2016
[0]PETSC ERROR: ./mattry        on a linux_64bit_debug named lin0322.marin.local by cklaij Thu Jul 28 10:31:04 2016
[0]PETSC ERROR: Configure options --with-mpi-dir=/home/cklaij/ReFRESCO/Dev/trunk/Libs/install/openmpi/1.8.7 --with-clanguage=c++ --with-x=1 --with-debugging=1 --with-blas-lapack-dir=/opt/intel/composer_xe_2015.1.133/mkl --with-shared-libraries=0
[0]PETSC ERROR: #1 MatNestFindIS() line 298 in /home/cklaij/ReFRESCO/Dev/trunk/Libs/build/petsc/3.7.3-dbg/src/mat/impls/nest/matnest.c
[0]PETSC ERROR: [1]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[1]PETSC ERROR: Null argument, when expecting valid pointer
[1]PETSC ERROR: Null Pointer: Parameter # 3
[1]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[1]PETSC ERROR: Petsc Release Version 3.7.3, Jul, 24, 2016
[1]PETSC ERROR: ./mattry        on a linux_64bit_debug named lin0322.marin.local by cklaij Thu Jul 28 10:31:04 2016
[1]PETSC ERROR: Configure options --with-mpi-dir=/home/cklaij/ReFRESCO/Dev/trunk/Libs/install/openmpi/1.8.7 --with-clanguage=c++ --with-x=1 --with-debugging=1 --with-blas-lapack-dir=/opt/intel/composer_xe_2015.1.133/mkl --with-shared-libraries=0
[1]PETSC ERROR: #1 MatNestFindIS() line 298 in /home/cklaij/ReFRESCO/Dev/trunk/Libs/build/petsc/3.7.3-dbg/src/mat/impls/nest/matnest.c
[1]PETSC ERROR: #2 MatNestFindSubMat() line 371 in /home/cklaij/ReFRESCO/Dev/trunk/Libs/build/petsc/3.7.3-dbg/src/mat/impls/nest/matnest.c
[1]PETSC ERROR: #3 MatGetLocalSubMatrix_Nest() line 414 in /home/cklaij/ReFRESCO/Dev/trunk/Libs/build/petsc/3.7.3-dbg/src/mat/impls/nest/matnest.c
[1]PETSC ERROR: #4 MatGetLocalSubMatrix() line 10099 in /home/cklaij/ReFRESCO/Dev/trunk/Libs/build/petsc/3.7.3-dbg/src/mat/interface/matrix.c
[0]PETSC ERROR: #3 MatGetLocalSubMatrix_Nest() line 414 in /home/cklaij/ReFRESCO/Dev/trunk/Libs/build/petsc/3.7.3-dbg/src/mat/impls/nest/matnest.c
[0]PETSC ERROR: #4 MatGetLocalSubMatrix() line 10099 in /home/cklaij/ReFRESCO/Dev/trunk/Libs/build/petsc/3.7.3-dbg/src/mat/interface/matrix.c
MPI_ABORT was invoked on rank 1 in communicator MPI_COMM_WORLD
with errorcode 85.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
[lin0322.marin.local:11985] 1 more process has sent help message help-mpi-api.txt / mpi-abort
[lin0322.marin.local:11985] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
dr. ir. Christiaan Klaij  | CFD Researcher | Research & Development
MARIN | T +31 317 49 33 44 | mailto:C.Klaij at marin.nl | http://www.marin.nl
MARIN news: http://www.marin.nl/web/News/News-items/Ship-design-in-EU-project-Holiship.htm
