[petsc-users] handling multi physics applications on multiple MPI_Comm
Mon Jul 25 16:55:58 CDT 2016
On Mon, Jul 25, 2016 at 2:30 PM, Manav Bhatia <bhatiamanav at gmail.com> wrote:
> On Jul 25, 2016, at 3:43 PM, Matthew Knepley <knepley at gmail.com> wrote:
> Yes. I think the confusion here is between the problem you are trying to
> solve, and the tool for doing it.
> Disparate size of subsystems seems to me to be a _load balancing_ problem.
> Here you can use data layout to alleviate this.
> On the global comm, you can put all the fluid unknowns on ranks 0..N-2,
> and the structural unknowns on N-1. You can have
> more general splits than that.
> Ok. So, if I do that, then there would still be one comm? If yes, then the
> distribution would be by specifying the number of local fluid dofs on N-1
> to be zero?
Yes. If all you want is good load balance, I think this is the best way.
    Matt
> Sorry that this such is a basic question.
> IF for some reason in the structural assembly you used a large number of
> collective operations (like say did artificial timestepping
> to get to some steady state property), then it might make sense to pull
> out a subcomm of only the occupied ranks, but only above
> 1000 procs, and only on a non-BlueGene machine. This is also easily
> measure before you do this work.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160725/59a52640/attachment.html>
