[petsc-users] OpenMPI 2.0 and Petsc 3.7.2
Mon Jul 25 13:57:18 CDT 2016
On Mon, Jul 25, 2016 at 11:33 AM, Eric Chamberland <
Eric.Chamberland at giref.ulaval.ca> wrote:
> Hi,
> has someone tried OpenMPI 2.0 with Petsc 3.7.2?
> I am having some errors with petsc, maybe someone have them too?
> Here are the configure logs for PETSc:
> http://www.giref.ulaval.ca/~cmpgiref/dernier_ompi/2016.07.25.01h16m02s_configure.log
> http://www.giref.ulaval.ca/~cmpgiref/dernier_ompi/2016.07.25.01h16m02s_RDict.log
> And for OpenMPI:
> http://www.giref.ulaval.ca/~cmpgiref/dernier_ompi/2016.07.25.01h16m02s_config.log
> (in fact, I am testing the ompi-release branch, a sort of petsc-master
> branch, since I need the commit 9ba6678156).
> For a set of parallel tests, I have 104 that works on 124 total tests.
It appears that the fault happens when freeing the VecScatter we build for
MatMult, which contains Request structures
for the ISends and  IRecvs. These looks like internal OpenMPI errors to me
since the Request should be opaque.
I would try at least two things:
1) Run under valgrind.
2) Switch the VecScatter implementation. All the options are here,
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Vec/VecScatterCreate.html#VecScatterCreate
but maybe use alltoall.
     Matt
> And the typical error:
> *** Error in
> `/pmi/cmpbib/compilation_BIB_dernier_ompi/COMPILE_AUTO/GIREF/bin/Test.ProblemeGD.dev':
> free(): invalid pointer:
> ======= Backtrace: =========
> /lib64/libc.so.6(+0x7277f)[0x7f80eb11677f]
> /lib64/libc.so.6(+0x78026)[0x7f80eb11c026]
> /lib64/libc.so.6(+0x78d53)[0x7f80eb11cd53]
> /opt/openmpi-2.x_opt/lib/libopen-pal.so.20(opal_free+0x1f)[0x7f80ea8f9d60]
> /opt/openmpi-2.x_opt/lib/openmpi/mca_pml_ob1.so(+0x16628)[0x7f80df0ea628]
> /opt/openmpi-2.x_opt/lib/openmpi/mca_pml_ob1.so(+0x16c50)[0x7f80df0eac50]
> /opt/openmpi-2.x_opt/lib/libmpi.so.20(+0x9f9dd)[0x7f80eb7029dd]
> /opt/openmpi-2.x_opt/lib/libmpi.so.20(MPI_Request_free+0xf7)[0x7f80eb702ad6]
> /opt/petsc-3.7.2_debug_openmpi_2.x/lib/libpetsc.so.3.7(+0x4adc6d)[0x7f80f2fa6c6d]
> /opt/petsc-3.7.2_debug_openmpi_2.x/lib/libpetsc.so.3.7(VecScatterDestroy+0x68d)[0x7f80f2fa1c45]
> /opt/petsc-3.7.2_debug_openmpi_2.x/lib/libpetsc.so.3.7(+0xa9d0f5)[0x7f80f35960f5]
> /opt/petsc-3.7.2_debug_openmpi_2.x/lib/libpetsc.so.3.7(MatDestroy+0x648)[0x7f80f35c2588]
> /opt/petsc-3.7.2_debug_openmpi_2.x/lib/libpetsc.so.3.7(+0x10bf0f4)[0x7f80f3bb80f4]
> /opt/petsc-3.7.2_debug_openmpi_2.x/lib/libpetsc.so.3.7(PCReset+0x346)[0x7f80f3a796de]
> /opt/petsc-3.7.2_debug_openmpi_2.x/lib/libpetsc.so.3.7(KSPReset+0x502)[0x7f80f3d19779]
> /opt/petsc-3.7.2_debug_openmpi_2.x/lib/libpetsc.so.3.7(+0x11707f7)[0x7f80f3c697f7]
> /opt/petsc-3.7.2_debug_openmpi_2.x/lib/libpetsc.so.3.7(PCDestroy+0x5d1)[0x7f80f3a79fd9]
> /opt/petsc-3.7.2_debug_openmpi_2.x/lib/libpetsc.so.3.7(KSPDestroy+0x7b6)[0x7f80f3d1a334]
> a similar one:
> *** Error in
> `/pmi/cmpbib/compilation_BIB_dernier_ompi/COMPILE_AUTO/GIREF/bin/Test.ProbFluideIncompressible.dev':
> free(): invalid pointer: 0x00007f382a7c5bc0 ***
> /lib64/libc.so.6(+0x7277f)[0x7f3829f1c77f]
> /lib64/libc.so.6(+0x78026)[0x7f3829f22026]
> /lib64/libc.so.6(+0x78d53)[0x7f3829f22d53]
> /opt/openmpi-2.x_opt/lib/libopen-pal.so.20(opal_free+0x1f)[0x7f38296ffd60]
> /opt/openmpi-2.x_opt/lib/openmpi/mca_pml_ob1.so(+0x16628)[0x7f381deab628]
> /opt/openmpi-2.x_opt/lib/openmpi/mca_pml_ob1.so(+0x16c50)[0x7f381deabc50]
> /opt/openmpi-2.x_opt/lib/libmpi.so.20(+0x9f9dd)[0x7f382a5089dd]
> /opt/openmpi-2.x_opt/lib/libmpi.so.20(MPI_Request_free+0xf7)[0x7f382a508ad6]
> /opt/petsc-3.7.2_debug_openmpi_2.x/lib/libpetsc.so.3.7(+0x4adc6d)[0x7f3831dacc6d]
> /opt/petsc-3.7.2_debug_openmpi_2.x/lib/libpetsc.so.3.7(VecScatterDestroy+0x68d)[0x7f3831da7c45]
> /opt/petsc-3.7.2_debug_openmpi_2.x/lib/libpetsc.so.3.7(+0x9f4755)[0x7f38322f3755]
> /opt/petsc-3.7.2_debug_openmpi_2.x/lib/libpetsc.so.3.7(MatDestroy+0x648)[0x7f38323c8588]
> /opt/petsc-3.7.2_debug_openmpi_2.x/lib/libpetsc.so.3.7(PCReset+0x4e2)[0x7f383287f87a]
> /opt/petsc-3.7.2_debug_openmpi_2.x/lib/libpetsc.so.3.7(PCDestroy+0x5d1)[0x7f383287ffd9]
> /opt/petsc-3.7.2_debug_openmpi_2.x/lib/libpetsc.so.3.7(KSPDestroy+0x7b6)[0x7f3832b20334]
> another one:
> *** Error in
> `/pmi/cmpbib/compilation_BIB_dernier_ompi/COMPILE_AUTO/GIREF/bin/Test.MortierDiffusion.dev':
> free(): invalid pointer: 0x00007f67b6d37bc0 ***
> /lib64/libc.so.6(+0x7277f)[0x7f67b648e77f]
> /lib64/libc.so.6(+0x78026)[0x7f67b6494026]
> /lib64/libc.so.6(+0x78d53)[0x7f67b6494d53]
> /opt/openmpi-2.x_opt/lib/libopen-pal.so.20(opal_free+0x1f)[0x7f67b5c71d60]
> /opt/openmpi-2.x_opt/lib/openmpi/mca_pml_ob1.so(+0x1adae)[0x7f67aa4cddae]
> /opt/openmpi-2.x_opt/lib/openmpi/mca_pml_ob1.so(+0x1b4ca)[0x7f67aa4ce4ca]
> /opt/openmpi-2.x_opt/lib/libmpi.so.20(+0x9f9dd)[0x7f67b6a7a9dd]
> /opt/openmpi-2.x_opt/lib/libmpi.so.20(MPI_Request_free+0xf7)[0x7f67b6a7aad6]
> /opt/petsc-3.7.2_debug_openmpi_2.x/lib/libpetsc.so.3.7(+0x4adb09)[0x7f67be31eb09]
> /opt/petsc-3.7.2_debug_openmpi_2.x/lib/libpetsc.so.3.7(VecScatterDestroy+0x68d)[0x7f67be319c45]
> /opt/petsc-3.7.2_debug_openmpi_2.x/lib/libpetsc.so.3.7(+0x4574f7)[0x7f67be2c84f7]
> /opt/petsc-3.7.2_debug_openmpi_2.x/lib/libpetsc.so.3.7(VecDestroy+0x648)[0x7f67be26e8da]
> I feel like I should wait until someone else from Petsc have tested it
> too...
> Thanks,
> Eric
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160725/fdfd5e4c/attachment.html>
