[petsc-users] Regarding ksp ex42 - Citations
domenico lahaye domenico_lahaye at yahoo.com
Fri Jul 22 03:42:00 CDT 2016
Dear Barry,
   Thank you for your suggestion.
   I will be happy to test drive the new code when available.
  Kind wishes, Domenico.
 To: Lawrence Mitchell <lawrence.mitchell at imperial.ac.uk>
Cc: domenico lahaye <domenico_lahaye at yahoo.com>; PETSc Users List <petsc-users at mcs.anl.gov>
 Sent: Friday, July 22, 2016 1:41 AM
 Subject: Re: [petsc-users] Regarding ksp ex42 - Citations
  I'll add support for handling both A and M via Galerkin. It is easy to write the code, picking a good simple API that doesn't break anything is more difficult.  I'm leaning to change PCMGSetGalerkin(PC,PetscBool) to PCMGSetGalerkin(PC, PCMGGalerkinType) where
typedef enum { PC_MG_GALERKIN_BOTH,PC_MG_GALERKIN_PMAT,PC_MG_GALERKIN_MAT, PC_MG_GALERKIN_NONE
 } PCMGGalerkinType;
Barry
> On Jul 21, 2016, at 6:09 AM, Lawrence Mitchell <lawrence.mitchell at imperial.ac.uk> wrote:
>> On 21 Jul 2016, at 10:55, domenico lahaye <domenico_lahaye at yahoo.com> wrote:
>> Apologies for being not sufficient clear in my previous message.
>> I would like to be able to Galerkin coarsen A^h to obtain A^H
>> and to separately Galerkin coarsen M^h to obtain M^H.
>> So, yes, the way in which I currently (partially) understand your
>> description of the new DMCreateMatrices would do the job.
> If you want to separately coarsen A and M via Galerkin, I think it will be easier to just change the code in PCSetUp_MG to handle the case where A and M are different on the coarse levels.  Effectively you just need to replicate the code that computes the coarse grid "B" matrix to separately compute coarse grid A and B matrices and pass them in to KSPSetOperators.
> Cheers,
> Lawrence
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160722/bb06ac3a/attachment-0003.html>
