[petsc-users] PC Direct Solution failure
Matthew Overholt overholt at capesim.com
Thu Jul 21 16:00:57 CDT 2016
PETSc Users,
I am doing a KSPPREONLY solution (of the heat transfer equation using FEA)
and comparing several packages like PARDISO and MUMPS, and I am encountering
a MatSolve() failure that I am having trouble diagnosing.  The matrix
inversion fails and I get "nan".  The failure only happens for certain input
files, and its not (just) related to problem size.  By making a slight
change to the geometry of the problem I can get it to solve.
The SuperLu solver is the only one that will give me any error message:
-ksp_type preonly -pc_type lu -pc_mat_solver_package superlu -info
I get the error message:
[0] MatSolve(): MatFactorError 2
Is that a PCFailedReason of PC_FACTOR_NUMERIC_ZEROPIVOT?
If so, is there a way to perturb the pivot in some way?
In another (non-PETSc) code which uses MKL PARDISO I am able to solve the
exact same problem by the same approach without any issues, and that code
gives PARDISO a pivot perturbation flag value.
Is there a better way to figure out what is happening?  I have been running
the code in TotalView with extreme memory checks and everything appears to
be ok.
Matt Overholt
CapeSym, Inc.
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160721/4af59161/attachment.html>
