[petsc-users] slepc eating all my ram
Hong hzhang at mcs.anl.gov
Fri Jul 15 11:13:27 CDT 2016
Simon :
For '-eps_hermitian -eps_largest_magnitude', why do you need 'spectral
transform'?
Try slepc default method for ex3.c.
Hong
> Hi,
> I'm running a slepc eigenvalue solver on a single machine with 198GB of
> ram,
> and solution space dimension 2^32. With double precision this means
> each vector is 32GB. I'm using shell matrices to implement the matrix
> vector product. I figured the easiest way to get eigenvalues is using
> the slepc power method, but it is still eating all the ram.
> Running in gdb I see that slepc is allocating a bunch of vectors in
> the spectral transform object (in STSetUp), and by this time it has
> consumed
> most of the 198GB of ram. I don't see why a spectral transform
> shift of zero needs to alloc a whole bunch of memory.
> I'm wondering if there are some other options to slepc that can
> reduce the memory footprint? A barebones implementation of the
> power method only needs to keep two vectors, perhaps I should
> just try doing this using petsc primitives. It's also possible that
> I could spread the computation over two or more machines but
> that's a whole other learning curve.
> The code I am running is essentially the laplacian grid
> example from slepc (src/eps/examples/tutorials/ex3.c):
> ./ex3 -eps_hermitian -eps_largest_magnitude -eps_monitor ascii -eps_nev 1
> -eps_type power -n 65536
> I also put this line in the source:
> EPSSetDimensions(eps,1,2,1);
> Cheers,
> Simon.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160715/b8f13cf4/attachment.html>
