[petsc-users] HDF5 and PETSc
Marco Zocca zocca.marco at gmail.com
Mon Jul 11 03:13:31 CDT 2016
Sorry for the previous mail, I hadn't fully read  ./configure --help :
all external package options are listed there, including HDF5
As far as I can see in
https://www.mcs.anl.gov/petsc/miscellaneous/external.html and on the
PDF manual, not all external packages are mentioned, and this tripped
me initially.
So my question becomes: please synchronize the output of ./configure
--help with manpages and pdf manual :)
Thanks again,
Marco
On 11 July 2016 at 09:57, Marco Zocca <zocca.marco at gmail.com> wrote:
> Good morning,
>    Does the HDF5 functionality need to be explicitly requested at
> configure time? I just noticed that my default configuration on a
> single-node machine does not compile any relevant symbol.
> I do not have HDF5 installed on my system yet, but I assumed PETSc
> includes it by default, or automagically pulls the dependency in at
> config time, since the manual doesn't mention anything about it. Do I
> have to install HDF5 from source and rebuild PETSc then?
> Thanks in advance,
> Marco
> --- config options and architecture :
> Configure Options: --configModules=PETSc.Configure
> --optionsModule=config.compilerOptions --with-cc=gcc --with-cxx=g++
> --with-fc=gfortran --download-fblaslapack --download-mpich
> Working directory: /Users/ocramz/petsc-3.7.2
> Machine platform:
> ('Darwin', 'fermi.local', '13.4.0', 'Darwin Kernel Version 13.4.0: Sun
> Aug 17 19:50:11 PDT 2014; root:xnu-2422.115.4~1/RELEASE_X86_64',
> 'x86_64', 'i386')
> Python version:
> 2.7.5 (default, Mar  9 2014, 22:15:05)
> [GCC 4.2.1 Compatible Apple LLVM 5.0 (clang-500.0.68)]
