[petsc-users] [Slepc 3.7.1][macOS] install name is set to build folder instead of prefix
Denis Davydov davydden at gmail.com
Sun Jul 10 17:29:02 CDT 2016
Hi Jose,
Please, disregard my last email. The order of arguments is correct.
I still have an issue, though. I will debug it further and try to find what’s the cause...
Kind regards,
Denis
> On 10 Jul 2016, at 22:26, Denis Davydov <davydden at gmail.com> wrote:
> I debuged a bit your code,  install_name should be used as follows:
> install_name_tool -id <new_name> <library_file_to_change>
> That is, you need to change around “installName” variable and “dst” and then it works as expected.
> Kind regards,
> Denis
>> On 10 Jul 2016, at 18:56, Denis Davydov <davydden at gmail.com> wrote:
>> Hi Jose,
>> the patch you mentioned does not solve the problem (i tried it):
>> $ otool -D libslepc.dylib
>> libslepc.dylib:
>> /private/var/folders/5k/sqpp24tx3ylds4fgm13pfht00000gn/T/davydden/spack-stage/spack-stage-jqcVVv/slepc-3.7.1/installed-arch-darwin-c-opt/lib/libslepc.3.7.dylib
>> Kind regards,
>> Denis
>>> On 10 Jul 2016, at 18:47, Jose E. Roman <jroman at dsic.upv.es> wrote:
>>> I think this is already fixed in this commit:
>>> https://bitbucket.org/slepc/slepc/commits/7489a3f3d569e2fbf5513ac9dcd769017d9f7eb7
>>> Version 7.3.2 containing this patch will be released in a week or so.
>>> Thanks for reporting this.
>>> Jose
>>>> El 10 jul 2016, a las 18:36, Denis Davydov <davydden at gmail.com> escribió:
>>>> Dear developers,
>>>> Slepc 3.6.3 used to produce the following result of install names:
>>>> $ otool -lv libslepc.dylib | grep slepc
>>>> libslepc.dylib:
>>>>     name /Users/davydden/spack/opt/spack/darwin-elcapitan-x86_64/clang-7.3.0-apple/slepc-3.6.3-b35zhzknp4lrt5r2iksagql2jkya2vfl/lib/libslepc.3.6.3.dylib (offset 24)
>>>>     path /Users/davydden/spack/opt/spack/darwin-elcapitan-x86_64/clang-7.3.0-apple/slepc-3.6.3-b35zhzknp4lrt5r2iksagql2jkya2vfl/lib (offset 12)
>>>>     path /Users/davydden/spack/opt/spack/darwin-elcapitan-x86_64/clang-7.3.0-apple/slepc-3.6.3-b35zhzknp4lrt5r2iksagql2jkya2vfl/lib64 (offset 12)
>>>> same for libslepc.3.6.dylib and libslepc.3.6.3.dylib
>>>> Since [3.7.1] the installed libraries have
>>>> libslepc.dylib:
>>>>     name /private/var/folders/5k/sqpp24tx3ylds4fgm13pfht00000gn/T/davydden/spack-stage/spack-stage-JwBNAx/slepc-3.7.1/installed-arch-darwin-c-opt/lib/libslepc.3.7.dylib (offset 24)
>>>>     path /Users/davydden/spack/opt/spack/darwin-elcapitan-x86_64/clang-7.3.0-apple/slepc-3.7.1-gimrzhb4mozeus3i2hdmrtjp3tha5pgr/lib (offset 12)
>>>>     path /Users/davydden/spack/opt/spack/darwin-elcapitan-x86_64/clang-7.3.0-apple/slepc-3.7.1-gimrzhb4mozeus3i2hdmrtjp3tha5pgr/lib64 (offset 12)
>>>> That is, the “name” is wrong as it corresponds to the path in the temporary build folder.
>>>> Kind regards,
>>>> Denis
