[petsc-users] [Slepc 3.7.1][macOS] install name is set to build folder instead of prefix
Jose E. Roman jroman at dsic.upv.es
Sun Jul 10 11:47:58 CDT 2016
I think this is already fixed in this commit:
https://bitbucket.org/slepc/slepc/commits/7489a3f3d569e2fbf5513ac9dcd769017d9f7eb7
Version 7.3.2 containing this patch will be released in a week or so.
Thanks for reporting this.
Jose
> El 10 jul 2016, a las 18:36, Denis Davydov <davydden at gmail.com> escribió:
> Dear developers,
> Slepc 3.6.3 used to produce the following result of install names:
> $ otool -lv libslepc.dylib | grep slepc
> libslepc.dylib:
>         name /Users/davydden/spack/opt/spack/darwin-elcapitan-x86_64/clang-7.3.0-apple/slepc-3.6.3-b35zhzknp4lrt5r2iksagql2jkya2vfl/lib/libslepc.3.6.3.dylib (offset 24)
>         path /Users/davydden/spack/opt/spack/darwin-elcapitan-x86_64/clang-7.3.0-apple/slepc-3.6.3-b35zhzknp4lrt5r2iksagql2jkya2vfl/lib (offset 12)
>         path /Users/davydden/spack/opt/spack/darwin-elcapitan-x86_64/clang-7.3.0-apple/slepc-3.6.3-b35zhzknp4lrt5r2iksagql2jkya2vfl/lib64 (offset 12)
> same for libslepc.3.6.dylib and libslepc.3.6.3.dylib
> Since [3.7.1] the installed libraries have
> libslepc.dylib:
>         name /private/var/folders/5k/sqpp24tx3ylds4fgm13pfht00000gn/T/davydden/spack-stage/spack-stage-JwBNAx/slepc-3.7.1/installed-arch-darwin-c-opt/lib/libslepc.3.7.dylib (offset 24)
>         path /Users/davydden/spack/opt/spack/darwin-elcapitan-x86_64/clang-7.3.0-apple/slepc-3.7.1-gimrzhb4mozeus3i2hdmrtjp3tha5pgr/lib (offset 12)
>         path /Users/davydden/spack/opt/spack/darwin-elcapitan-x86_64/clang-7.3.0-apple/slepc-3.7.1-gimrzhb4mozeus3i2hdmrtjp3tha5pgr/lib64 (offset 12)
> That is, the “name” is wrong as it corresponds to the path in the temporary build folder.
> Kind regards,
> Denis
