[petsc-users] petsc 3.7.2 memory usage is much higher when compared to 3.6.1
Hassan Raiesi Hassan.Raiesi at aero.bombardier.com
Tue Jul 5 15:42:54 CDT 2016
PETSc 3.7.2 seems to have a much higher memory usage when compared with PETSc- 3.1.1 c, to a point that it crashes our code for large problems that we ran with version 3.6.1 in the past.
I have re-compiled the code with same options, and ran the same code linked with the two versions, here are the log-summarie:
-flow_ksp_max_it 20
-flow_ksp_monitor_true_residual
-flow_ksp_rtol 0.1
-flow_ksp_type fgmres
-flow_mg_coarse_pc_factor_mat_solver_package mumps
-flow_mg_coarse_pc_type lu
-flow_mg_levels_ksp_type richardson
-flow_mg_levels_pc_type sor
-flow_pc_gamg_agg_nsmooths 0
-flow_pc_gamg_coarse_eq_limit 2000
-flow_pc_gamg_process_eq_limit 2500
-flow_pc_gamg_repartition true
-flow_pc_gamg_reuse_interpolation true
-flow_pc_gamg_square_graph 3
-flow_pc_gamg_sym_graph true
-flow_pc_gamg_type agg
-flow_pc_mg_cycle v
-flow_pc_mg_levels 20
-flow_pc_mg_type kaskade
-flow_pc_type gamg
-log_summary
Note: it is not specific to PCGAMG, even a bjacobi+fgmres would need more memory (4.5GB/core in version 3.6.1 compared to 6.8GB/core for 3.7.2).
Using Petsc Development GIT revision: v3.7.2-812-gc68d048  GIT Date: 2016-07-05 12:04:34 -0400
                         Max       Max/Min        Avg      Total
Time (sec):           6.760e+02      1.00006   6.760e+02
Objects:              1.284e+03      1.00469   1.279e+03
Flops:                3.563e+10      1.10884   3.370e+10  1.348e+13
Flops/sec:            5.271e+07      1.10884   4.985e+07  1.994e+10
MPI Messages:         4.279e+04      7.21359   1.635e+04  6.542e+06
MPI Message Lengths:  3.833e+09     17.25274   7.681e+04  5.024e+11
MPI Reductions:       4.023e+03      1.00149
Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
                            e.g., VecAXPY() for real vectors of length N --> 2N flops
                            and VecAXPY() for complex vectors of length N --> 8N flops
Summary of Stages:   ----- Time ------  ----- Flops -----  --- Messages ---  -- Message Lengths --  -- Reductions --
                        Avg     %Total     Avg     %Total   counts   %Total     Avg         %Total   counts   %Total
0:      Main Stage: 6.7600e+02 100.0%  1.3478e+13 100.0%  6.533e+06  99.9%  7.674e+04       99.9%  4.010e+03  99.7%
See the 'Profiling' chapter of the users' manual for details on interpreting output.
Phase summary info:
   Count: number of times phase was executed
   Time and Flops: Max - maximum over all processors
                   Ratio - ratio of maximum to minimum over all processors
   Mess: number of messages sent
   Avg. len: average message length (bytes)
   Reduct: number of global reductions
   Global: entire computation
   Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
      %T - percent time in this phase         %F - percent flops in this phase
      %M - percent messages in this phase     %L - percent message lengths in this phase
      %R - percent reductions in this phase
   Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time over all processors)
Event                Count      Time (sec)     Flops                             --- Global ---  --- Stage ---   Total
                   Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
--- Event Stage 0: Main Stage
MatMult              500 1.0 1.0582e+01 1.2 6.68e+09 1.1 1.9e+06 1.0e+04 0.0e+00  1 19 28  4  0   1 19 29  4  0 237625
MatMultTranspose     120 1.0 7.6262e-01 1.3 3.58e+08 1.1 2.4e+05 1.5e+04 0.0e+00  0  1  4  1  0   0  1  4  1  0 180994
MatSolve             380 1.0 4.1580e+00 1.1 1.17e+09 1.1 8.6e+03 8.8e+01 6.0e+01  1  3  0  0  1   1  3  0  0  1 105950
MatSOR               120 1.0 1.4316e+01 1.2 6.75e+09 1.1 9.5e+05 7.4e+03 0.0e+00  2 19 15  1  0   2 19 15  1  0 177298
MatLUFactorSym         2 1.0 2.3449e-01 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 1.0e+01  0  0  0  0  0   0  0  0  0  0     0
MatLUFactorNum        60 1.0 8.8820e+00 1.0 1.95e+08 1.2 0.0e+00 0.0e+00 0.0e+00  1  1  0  0  0   1  1  0  0  0  7877
MatILUFactorSym        1 1.0 1.9795e-02 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatConvert             6 1.0 2.9893e-02 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 1.8e+01  0  0  0  0  0   0  0  0  0  0     0
MatScale               6 1.0 1.8810e-02 1.4 4.52e+06 1.1 2.4e+04 1.5e+03 0.0e+00  0  0  0  0  0   0  0  0  0  0 90171
MatAssemblyBegin     782 1.0 1.8294e+01 2.9 0.00e+00 0.0 9.2e+05 4.1e+05 4.2e+02  2  0 14 75 10   2  0 14 75 10     0
MatAssemblyEnd       782 1.0 1.4283e+01 3.0 0.00e+00 0.0 4.1e+05 8.7e+02 4.7e+02  1  0  6  0 12   1  0  6  0 12     0
MatGetRow        6774900 1.1 9.4289e-01 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetRowIJ            3 3.0 6.6261e-036948.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetSubMatrix       12 1.0 2.6783e+01 1.0 0.00e+00 0.0 1.1e+05 1.3e+05 2.0e+02  4  0  2  3  5   4  0  2  3  5     0
MatGetOrdering         3 3.0 7.7400e-03 7.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatPartitioning        6 1.0 1.8949e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 1.4e+01  0  0  0  0  0   0  0  0  0  0     0
MatCoarsen             6 1.0 9.5692e-02 1.2 0.00e+00 0.0 2.6e+05 1.1e+03 4.1e+01  0  0  4  0  1   0  0  4  0  1     0
MatZeroEntries       142 1.0 9.7085e-01 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatTranspose           6 1.0 2.1740e-01 1.0 0.00e+00 0.0 1.9e+05 8.5e+02 7.8e+01  0  0  3  0  2   0  0  3  0  2     0
MatPtAP              120 1.0 6.0157e+01 1.0 1.82e+10 1.1 1.5e+06 2.7e+05 4.2e+02  9 51 22 80 10   9 51 22 80 10 114269
MatPtAPSymbolic       12 1.0 8.1081e+00 1.0 0.00e+00 0.0 2.2e+05 3.8e+04 8.4e+01  1  0  3  2  2   1  0  3  2  2     0
MatPtAPNumeric       120 1.0 5.2205e+01 1.0 1.82e+10 1.1 1.2e+06 3.1e+05 3.4e+02  8 51 19 78  8   8 51 19 78  8 131676
MatTrnMatMult          3 1.0 1.8608e+00 1.0 3.23e+07 1.2 8.3e+04 7.9e+03 5.7e+01  0  0  1  0  1   0  0  1  0  1  6275
MatTrnMatMultSym       3 1.0 1.3447e+00 1.0 0.00e+00 0.0 6.9e+04 3.8e+03 5.1e+01  0  0  1  0  1   0  0  1  0  1     0
MatTrnMatMultNum       3 1.0 5.1695e-01 1.0 3.23e+07 1.2 1.3e+04 3.0e+04 6.0e+00  0  0  0  0  0   0  0  0  0  0 22588
MatGetLocalMat       126 1.0 1.0355e+00 1.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetBrAoCol        120 1.0 9.5921e+0019.2 0.00e+00 0.0 5.7e+05 3.3e+04 0.0e+00  1  0  9  4  0   1  0  9  4  0     0
VecDot               320 1.0 1.1400e+00 1.6 2.04e+08 1.1 0.0e+00 0.0e+00 3.2e+02  0  1  0  0  8   0  1  0  0  8 68967
VecMDot              260 1.0 1.9577e+00 2.8 3.70e+08 1.1 0.0e+00 0.0e+00 2.6e+02  0  1  0  0  6   0  1  0  0  6 72792
VecNorm              440 1.0 2.6273e+00 1.9 5.88e+08 1.1 0.0e+00 0.0e+00 4.4e+02  0  2  0  0 11   0  2  0  0 11 86035
VecScale             320 1.0 2.1386e-01 1.2 7.91e+07 1.1 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 141968
VecCopy              220 1.0 7.0370e-01 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet               862 1.0 7.1000e-01 1.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY              440 1.0 8.6790e-01 1.1 3.83e+08 1.1 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0 169857
VecAYPX              280 1.0 5.7766e-01 1.5 1.92e+08 1.1 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0 127599
VecMAXPY             300 1.0 9.7396e-01 1.2 4.98e+08 1.1 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0 196768
VecAssemblyBegin     234 1.0 4.6313e+00 5.6 0.00e+00 0.0 0.0e+00 0.0e+00 6.8e+02  0  0  0  0 17   0  0  0  0 17     0
VecAssemblyEnd       234 1.0 5.1503e-0319.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecScatterBegin     1083 1.0 2.9274e-01 4.5 0.00e+00 0.0 3.8e+06 8.5e+03 2.0e+01  0  0 59  6  0   0  0 59  6  0     0
VecScatterEnd       1063 1.0 3.9653e+00 5.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPGMRESOrthog        20 1.0 1.7405e+00 3.7 1.28e+08 1.1 0.0e+00 0.0e+00 2.0e+01  0  0  0  0  0   0  0  0  0  0 28232
KSPSetUp             222 1.0 6.8469e-02 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01  0  0  0  0  0   0  0  0  0  0     0
KSPSolve              60 1.0 1.4767e+02 1.0 3.55e+10 1.1 6.3e+06 7.2e+04 3.2e+03 22100 96 90 79  22100 96 90 79 91007
PCGAMGGraph_AGG        6 1.0 6.0792e+00 1.0 4.52e+06 1.1 3.8e+05 9.0e+02 2.5e+02  1  0  6  0  6   1  0  6  0  6   279
PCGAMGCoarse_AGG       6 1.0 2.0660e+00 1.0 3.23e+07 1.2 4.2e+05 3.1e+03 1.5e+02  0  0  6  0  4   0  0  6  0  4  5652
PCGAMGProl_AGG         6 1.0 1.8842e+00 1.0 0.00e+00 0.0 7.3e+05 3.3e+03 8.6e+02  0  0 11  0 21   0  0 11  0 22     0
PCGAMGPOpt_AGG         6 1.0 6.4373e-06 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
GAMG: createProl       6 1.0 1.0036e+01 1.0 3.68e+07 1.2 1.5e+06 2.7e+03 1.3e+03  1  0 23  1 31   1  0 23  1 31  1332
  Graph               12 1.0 6.0783e+00 1.0 4.52e+06 1.1 3.8e+05 9.0e+02 2.5e+02  1  0  6  0  6   1  0  6  0  6   279
  MIS/Agg              6 1.0 9.5831e-02 1.2 0.00e+00 0.0 2.6e+05 1.1e+03 4.1e+01  0  0  4  0  1   0  0  4  0  1     0
  SA: col data         6 1.0 7.7358e-01 1.0 0.00e+00 0.0 6.7e+05 2.9e+03 7.8e+02  0  0 10  0 19   0  0 10  0 19     0
  SA: frmProl0         6 1.0 1.0759e+00 1.0 0.00e+00 0.0 6.2e+04 7.6e+03 6.0e+01  0  0  1  0  1   0  0  1  0  1     0
GAMG: partLevel        6 1.0 3.8136e+01 1.0 9.09e+08 1.1 3.8e+05 5.0e+04 5.4e+02  6  3  6  4 13   6  3  6  4 14  9013
  repartition          6 1.0 2.7910e+00 1.0 0.00e+00 0.0 4.6e+04 1.3e+02 1.6e+02  0  0  1  0  4   0  0  1  0  4     0
  Invert-Sort          6 1.0 2.5045e+00 2.0 0.00e+00 0.0 0.0e+00 0.0e+00 2.4e+01  0  0  0  0  1   0  0  0  0  1     0
  Move A               6 1.0 1.4832e+01 1.0 0.00e+00 0.0 8.5e+04 1.7e+05 1.1e+02  2  0  1  3  3   2  0  1  3  3     0
  Move P               6 1.0 1.2023e+01 1.0 0.00e+00 0.0 2.4e+04 3.8e+03 1.1e+02  2  0  0  0  3   2  0  0  0  3     0
PCSetUp              100 1.0 1.1212e+02 1.0 1.84e+10 1.1 3.2e+06 1.3e+05 2.2e+03 17 52 49 84 54  17 52 49 84 54 62052
PCSetUpOnBlocks       40 1.0 1.0386e+00 1.2 1.95e+08 1.2 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0 67368
PCApply              380 1.0 2.0034e+01 1.1 8.60e+09 1.1 1.5e+06 9.9e+03 6.0e+01  3 24 22  3  1   3 24 22  3  1 161973
SFSetGraph            12 1.0 4.9813e-0310.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFBcastBegin          47 1.0 3.3110e-02 2.6 0.00e+00 0.0 2.6e+05 1.1e+03 6.0e+00  0  0  4  0  0   0  0  4  0  0     0
SFBcastEnd            47 1.0 1.3497e-02 3.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFReduceBegin          6 1.0 1.8593e-02 4.2 0.00e+00 0.0 7.2e+04 4.9e+02 6.0e+00  0  0  1  0  0   0  0  1  0  0     0
SFReduceEnd            6 1.0 7.1628e-0318.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
BuildTwoSided         12 1.0 3.5771e-02 2.5 0.00e+00 0.0 5.0e+04 4.0e+00 1.2e+01  0  0  1  0  0   0  0  1  0  0     0
Memory usage is given in bytes:
Object Type          Creations   Destructions     Memory  Descendants' Mem.
Reports information only for process 0.
              Matrix   302            299   1992700700     0.
Matrix Partitioning     6              6         3888     0.
      Matrix Coarsen     6              6         3768     0.
              Vector   600            600   1582204168     0.
      Vector Scatter    87             87      5614432     0.
       Krylov Solver    11             11        59472     0.
      Preconditioner    11             11        11120     0.
         PetscRandom     1              1          638     0.
              Viewer     1              0            0     0.
           Index Set   247            247      9008420     0.
Star Forest Bipartite Graph    12             12        10176     0.
And for  petsc 3.6.1:
Using Petsc Development GIT revision: v3.6.1-307-g26c82d3  GIT Date: 2015-08-06 11:50:34 -0500
Time (sec):           5.515e+02      1.00001   5.515e+02
Objects:              1.231e+03      1.00490   1.226e+03
Flops:                3.431e+10      1.12609   3.253e+10  1.301e+13
Flops/sec:            6.222e+07      1.12609   5.899e+07  2.359e+10
MPI Messages:         4.432e+04      7.84165   1.504e+04  6.016e+06
MPI Message Lengths:  2.236e+09     12.61261   5.027e+04  3.024e+11
MPI Reductions:       4.012e+03      1.00150
0:      Main Stage: 5.5145e+02 100.0%  1.3011e+13 100.0%  6.007e+06  99.9%  5.020e+04       99.9%  3.999e+03  99.7%
Phase summary info:
MatMult              500 1.0 1.0172e+01 1.2 6.68e+09 1.1 1.9e+06 9.9e+03 0.0e+00  2 19 31  6  0   2 19 31  6  0 247182
MatMultTranspose     120 1.0 6.9889e-01 1.2 3.56e+08 1.1 2.5e+05 1.4e+04 0.0e+00  0  1  4  1  0   0  1  4  1  0 197492
MatSolve             380 1.0 3.9310e+00 1.1 1.17e+09 1.1 1.3e+04 5.7e+01 6.0e+01  1  3  0  0  1   1  3  0  0  2 112069
MatSOR               120 1.0 1.3915e+01 1.1 6.73e+09 1.1 9.5e+05 7.4e+03 0.0e+00  2 20 16  2  0   2 20 16  2  0 182405
MatLUFactorSym         2 1.0 2.1180e-01 1.8 0.00e+00 0.0 0.0e+00 0.0e+00 1.0e+01  0  0  0  0  0   0  0  0  0  0     0
MatLUFactorNum        60 1.0 7.9378e+00 1.0 1.95e+08 1.2 0.0e+00 0.0e+00 0.0e+00  1  1  0  0  0   1  1  0  0  0  8814
MatILUFactorSym        1 1.0 2.3076e-02 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatConvert             6 1.0 3.2693e-02 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 1.8e+01  0  0  0  0  0   0  0  0  0  0     0
MatScale               6 1.0 2.1923e-02 1.7 4.50e+06 1.1 2.4e+04 1.5e+03 0.0e+00  0  0  0  0  0   0  0  0  0  0 77365
MatAssemblyBegin     266 1.0 1.0337e+01 4.4 0.00e+00 0.0 1.8e+05 3.8e+03 4.2e+02  1  0  3  0 10   1  0  3  0 10     0
MatAssemblyEnd       266 1.0 3.0336e+00 1.0 0.00e+00 0.0 4.1e+05 8.6e+02 4.7e+02  1  0  7  0 12   1  0  7  0 12     0
MatGetRow        6730366 1.1 8.6473e-01 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetRowIJ            3 3.0 5.2931e-035550.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetSubMatrix       12 1.0 2.2689e+01 1.0 0.00e+00 0.0 1.1e+05 1.3e+05 1.9e+02  4  0  2  5  5   4  0  2  5  5     0
MatGetOrdering         3 3.0 6.5000e-03 5.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatPartitioning        6 1.0 2.9801e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 1.4e+01  1  0  0  0  0   1  0  0  0  0     0
MatCoarsen             6 1.0 9.5374e-02 1.1 0.00e+00 0.0 2.5e+05 1.1e+03 3.8e+01  0  0  4  0  1   0  0  4  0  1     0
MatZeroEntries        22 1.0 6.1185e-01 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatTranspose           6 1.0 1.9780e-01 1.1 0.00e+00 0.0 1.9e+05 8.6e+02 7.8e+01  0  0  3  0  2   0  0  3  0  2     0
MatPtAP              120 1.0 5.2996e+01 1.0 1.70e+10 1.1 9.7e+05 2.1e+05 4.2e+02 10 49 16 67 10  10 49 16 67 11 120900
MatPtAPSymbolic       12 1.0 5.8209e+00 1.0 0.00e+00 0.0 2.2e+05 3.7e+04 8.4e+01  1  0  4  3  2   1  0  4  3  2     0
MatPtAPNumeric       120 1.0 4.7185e+01 1.0 1.70e+10 1.1 7.6e+05 2.6e+05 3.4e+02  9 49 13 64  8   9 49 13 64  8 135789
MatTrnMatMult          3 1.0 1.1679e+00 1.0 3.22e+07 1.2 8.2e+04 8.0e+03 5.7e+01  0  0  1  0  1   0  0  1  0  1  9997
MatTrnMatMultSym       3 1.0 6.8366e-01 1.0 0.00e+00 0.0 6.9e+04 3.9e+03 5.1e+01  0  0  1  0  1   0  0  1  0  1     0
MatTrnMatMultNum       3 1.0 4.8513e-01 1.0 3.22e+07 1.2 1.3e+04 3.0e+04 6.0e+00  0  0  0  0  0   0  0  0  0  0 24069
MatGetLocalMat       126 1.0 1.1939e+00 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetBrAoCol        120 1.0 5.9887e-01 2.7 0.00e+00 0.0 5.7e+05 3.3e+04 0.0e+00  0  0  9  6  0   0  0  9  6  0     0
MatGetSymTrans        24 1.0 1.4878e-01 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecDot               320 1.0 1.5860e+00 1.5 2.04e+08 1.1 0.0e+00 0.0e+00 3.2e+02  0  1  0  0  8   0  1  0  0  8 49574
VecMDot              260 1.0 1.8154e+00 2.5 3.70e+08 1.1 0.0e+00 0.0e+00 2.6e+02  0  1  0  0  6   0  1  0  0  7 78497
VecNorm              440 1.0 2.8876e+00 1.8 5.88e+08 1.1 0.0e+00 0.0e+00 4.4e+02  0  2  0  0 11   0  2  0  0 11 78281
VecScale             320 1.0 2.2738e-01 1.2 7.88e+07 1.1 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 133517
VecCopy              220 1.0 7.1162e-01 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet               862 1.0 7.0683e-01 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY              440 1.0 9.0657e-01 1.2 3.83e+08 1.1 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0 162612
VecAYPX              280 1.0 5.8935e-01 1.5 1.92e+08 1.1 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0 125070
VecMAXPY             300 1.0 9.7644e-01 1.2 4.98e+08 1.1 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0 196269
VecAssemblyBegin     234 1.0 5.0308e+00 5.5 0.00e+00 0.0 0.0e+00 0.0e+00 6.8e+02  1  0  0  0 17   1  0  0  0 17     0
VecAssemblyEnd       234 1.0 1.8253e-03 8.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecScatterBegin     1083 1.0 2.8195e-01 4.7 0.00e+00 0.0 3.8e+06 8.4e+03 2.0e+01  0  0 64 11  0   0  0 64 11  1     0
VecScatterEnd       1063 1.0 3.4924e+00 6.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPGMRESOrthog        20 1.0 1.5598e+00 3.2 1.28e+08 1.1 0.0e+00 0.0e+00 2.0e+01  0  0  0  0  0   0  0  0  0  1 31503
KSPSetUp             222 1.0 9.7521e-02 1.6 0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01  0  0  0  0  0   0  0  0  0  0     0
KSPSolve              60 1.0 1.3742e+02 1.0 3.42e+10 1.1 5.7e+06 4.4e+04 3.2e+03 25100 95 83 79  25100 95 83 79 94396
PCGAMGGraph_AGG        6 1.0 5.7683e+00 1.0 4.50e+06 1.1 3.8e+05 9.1e+02 2.5e+02  1  0  6  0  6   1  0  6  0  6   294
PCGAMGCoarse_AGG       6 1.0 1.4101e+00 1.0 3.22e+07 1.2 4.0e+05 3.2e+03 1.4e+02  0  0  7  0  4   0  0  7  0  4  8280
PCGAMGProl_AGG         6 1.0 1.8976e+00 1.0 0.00e+00 0.0 7.2e+05 3.4e+03 8.6e+02  0  0 12  1 22   0  0 12  1 22     0
PCGAMGPOpt_AGG         6 1.0 5.7220e-06 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
GAMG: createProl       6 1.0 9.0840e+00 1.0 3.67e+07 1.2 1.5e+06 2.7e+03 1.3e+03  2  0 25  1 31   2  0 25  1 31  1472
  Graph               12 1.0 5.7669e+00 1.0 4.50e+06 1.1 3.8e+05 9.1e+02 2.5e+02  1  0  6  0  6   1  0  6  0  6   294
  MIS/Agg              6 1.0 9.5481e-02 1.1 0.00e+00 0.0 2.5e+05 1.1e+03 3.8e+01  0  0  4  0  1   0  0  4  0  1     0
  SA: col data         6 1.0 8.5414e-01 1.0 0.00e+00 0.0 6.6e+05 3.0e+03 7.8e+02  0  0 11  1 19   0  0 11  1 20     0
  SA: frmProl0         6 1.0 1.0123e+00 1.0 0.00e+00 0.0 6.2e+04 7.6e+03 6.0e+01  0  0  1  0  1   0  0  1  0  2     0
GAMG: partLevel        6 1.0 3.6150e+01 1.0 8.41e+08 1.1 3.5e+05 5.0e+04 5.3e+02  7  2  6  6 13   7  2  6  6 13  8804
  repartition          6 1.0 3.8351e+00 1.0 0.00e+00 0.0 4.7e+04 1.3e+02 1.6e+02  1  0  1  0  4   1  0  1  0  4     0
  Invert-Sort          6 1.0 4.4953e+00 1.8 0.00e+00 0.0 0.0e+00 0.0e+00 2.4e+01  1  0  0  0  1   1  0  0  0  1     0
  Move A               6 1.0 1.0806e+01 1.0 0.00e+00 0.0 8.5e+04 1.6e+05 1.0e+02  2  0  1  5  3   2  0  1  5  3     0
  Move P               6 1.0 1.1953e+01 1.0 0.00e+00 0.0 2.5e+04 3.6e+03 1.0e+02  2  0  0  0  3   2  0  0  0  3     0
PCSetUp              100 1.0 1.0166e+02 1.0 1.72e+10 1.1 2.7e+06 8.3e+04 2.2e+03 18 50 44 73 54  18 50 44 73 54 63848
PCSetUpOnBlocks       40 1.0 1.0812e+00 1.2 1.95e+08 1.2 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0 64711
PCApply              380 1.0 1.9359e+01 1.1 8.58e+09 1.1 1.4e+06 9.6e+03 6.0e+01  3 25 24  5  1   3 25 24  5  2 167605
SFSetGraph            12 1.0 3.5203e-03 6.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFBcastBegin          44 1.0 2.4242e-02 3.0 0.00e+00 0.0 2.5e+05 1.1e+03 6.0e+00  0  0  4  0  0   0  0  4  0  0     0
SFBcastEnd            44 1.0 3.0994e-02 8.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFReduceBegin          6 1.0 1.6784e-02 3.8 0.00e+00 0.0 7.1e+04 5.0e+02 6.0e+00  0  0  1  0  0   0  0  1  0  0     0
SFReduceEnd            6 1.0 8.6989e-0332.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
              Matrix   246            243   1730595756     0
Matrix Partitioning     6              6         3816     0
      Matrix Coarsen     6              6         3720     0
              Vector   602            602   1603749672     0
      Vector Scatter    87             87      4291136     0
       Krylov Solver    12             12        60416     0
      Preconditioner    12             12        12040     0
              Viewer     1              0            0     0
           Index Set   247            247      9018060     0
Star Forest Bipartite Graph    12             12        10080     0
Any idea why there are more matrix created with version 3.7.2? I only have 2 MatCreate calls and 4 VecCreate calls in my code!, so I assume the others are internally created.
Thank you,
Hassan Raiesi, PhD
Advanced Aerodynamics Department
Bombardier Aerospace
hassan.raiesi at aero.bombardier.com
2351 boul. Alfred-Nobel (BAN1)
Ville Saint-Laurent, Québec, H4S 2A9
Tél.
  514-855-5001    # 62204
[cid:image001.png at 01D1D6DA.DC1D3010]
CONFIDENTIALITY NOTICE - This communication may contain privileged or confidential information.
If you are not the intended recipient or received this communication by error, please notify the sender
and delete the message without copying, forwarding and/or disclosing it.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160705/49633698/attachment-0001.html>
Type: image/png
Desc: image001.png
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160705/49633698/attachment-0001.png>
