[petsc-users] pets error Segmentation Violation
张江 zhangjiang.dudu at gmail.com
Fri Jul 1 13:26:31 CDT 2016
I am trying to read a large data (11.7GB) with libmesh (integrated with PETSc) and use it for my application. The program runs well when using just one process. But in parallel (mpirun -n 4), some errors came out:
[0]PETSC ERROR: ------------------------------------------------------------------------
[0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
[0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
[0]PETSC ERROR: likely location of problem given in stack below
[0]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
[0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[0]PETSC ERROR:       INSTEAD the line number of the start of the function
[0]PETSC ERROR:       is given.
[0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[0]PETSC ERROR: Signal received
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.7.2, Jun, 05, 2016
[0]PETSC ERROR: ./ptracer on a arch-linux2-c-debug named compute001 by jiangzhang Fri Jul  1 10:07:07 2016
[0]PETSC ERROR: Configure options --prefix=/nfs/proj-tpeterka/jiang/opt/petsc-3.7.2 --download-fblaslapack --with-mpi-dir=/nfs/proj-tpeterka/jiang/libraries/mpich-3.2
[0]PETSC ERROR: #1 User provided function() line 0 in  unknown file
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
Anybody know the possible causes?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160701/9e44fdb7/attachment.html>
