[petsc-users] DMDAVecRestoreArrayF90 error
TAY wee-beng zonexo at gmail.com
Fri Jul 1 01:33:54 CDT 2016
I had problems with DMDAVecRestoreArrayF90 last time when I used an old
version of Intel Fortran compiler. It works fine in gfortran and new
version of Intel compiler. It was determined as a bug by the PETSc team.
To use in old version of Intel, I had to use -O1 instead of -O3 -ipo in
subroutines when DMDAVecRestoreArrayF90 is called.
Recently, my cluster was reset and all files were deleted. I upload my
files and compile my code again. However, this time, with a new version
of Intel, I got segmentation error with DMDAVecRestoreArrayF90. Changing
to -O1 works. But I thought it was working fine. So maybe I need to
check with my admin if the ver before and after reset are the same.
Another thing was using PETSc ver 3.6.4 and 3.7.2. Using v3.6.4
(compiled with -O3 -ipo), it encountered segmentation err right from the
code start, when DMDAVecRestoreArrayF90  is called.
However, for v3.7.2 (compiled with -O3 -ipo), it only happened during
the 2nd time step, when I need to use DMDAVecRestoreArrayF90 in order to
use KSP to solve the linear equation later on.
So I wonder why v3.7.2 can get pass the 1st time step w/o problem and
getting the right answer and only give errors at the 2nd time step.
Any explanation for this?
Btw, same result whether MPI is used or not.
Thank you
Yours sincerely,
TAY wee-beng
