[petsc-users] Why use MATMPIBAIJ?
Hom Nath Gharti hng.email at gmail.com
Fri Jan 22 11:10:54 CST 2016
Thanks Matt.
Attached detailed info on ksp of a much smaller test. This is a
multiphysics problem.
Hom Nath
On Fri, Jan 22, 2016 at 12:01 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Jan 22, 2016 at 10:52 AM, Hom Nath Gharti <hng.email at gmail.com>
> wrote:
>> Dear all,
>> I take this opportunity to ask for your important suggestion.
>> I am solving an elastic-acoustic-gravity equation on the planet. I
>> have displacement vector (ux,uy,uz) in solid region, displacement
>> potential (\xi) and pressure (p) in fluid region, and gravitational
>> potential (\phi) in all of space. All these variables are coupled.
>> Currently, I am using MATMPIAIJ and form a single global matrix. Does
>> using a MATMPIBIJ or MATNEST improve the convergence/efficiency in
>> this case? For your information, total degrees of freedoms are about a
>> billion.
> 1) For any solver question, we need to see the output of -ksp_view, and we
> would also like
>   -ksp_monitor_true_residual -ksp_converged_reason
> 2) MATNEST does not affect convergence, and MATMPIBAIJ only in the blocksize
> which you
>     could set without that format
> 3) However, you might see benefit from using something like PCFIELDSPLIT if
> you have multiphysics here
>    Matt
>> Any suggestion would be greatly appreciated.
>> Thanks,
>> Hom Nath
>> On Fri, Jan 22, 2016 at 10:32 AM, Matthew Knepley <knepley at gmail.com>
>> wrote:
>> > On Fri, Jan 22, 2016 at 9:27 AM, Mark Adams <mfadams at lbl.gov> wrote:
>> >>> I said the Hypre setup cost is not scalable,
>> >> I'd be a little careful here.  Scaling for the matrix triple product is
>> >> hard and hypre does put effort into scaling. I don't have any data
>> >> however.
>> >> Do you?
>> > I used it for PyLith and saw this. I did not think any AMG had scalable
>> > setup time.
>> >    Matt
>> >>> but it can be amortized over the iterations. You can quantify this
>> >>> just by looking at the PCSetUp time as your increase the number of
>> >>> processes. I don't think they have a good
>> >>> model for the memory usage, and if they do, I do not know what it is.
>> >>> However, generally Hypre takes more
>> >>> memory than the agglomeration MG like ML or GAMG.
>> >> agglomerations methods tend to have lower "grid complexity", that is
>> >> smaller coarse grids, than classic AMG like in hypre. THis is more of a
>> >> constant complexity and not a scaling issue though.  You can address
>> >> this
>> >> with parameters to some extent. But for elasticity, you want to at
>> >> least
>> >> try, if not start with, GAMG or ML.
>> >>>   Thanks,
>> >>>     Matt
>> >>>> Giang
>> >>>> On Mon, Jan 18, 2016 at 5:25 PM, Jed Brown <jed at jedbrown.org> wrote:
>> >>>>> Hoang Giang Bui <hgbk2008 at gmail.com> writes:
>> >>>>> > Why P2/P2 is not for co-located discretization?
>> >>>>> Matt typed "P2/P2" when me meant "P2/P1".
>> >>> What most experimenters take for granted before they begin their
>> >>> experiments is infinitely more interesting than any results to which
>> >>> their
>> >>> experiments lead.
>> >>> -- Norbert Wiener
>> > experiments
>> > is infinitely more interesting than any results to which their
>> > experiments
>> > lead.
>> > -- Norbert Wiener
> What most experimenters take for granted before they begin their experiments
> is infinitely more interesting than any results to which their experiments
> lead.
> -- Norbert Wiener
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160122/dcd8e24d/attachment.obj>
