[petsc-users] Profile a matrix-free solver.
Song Gao song.gao2 at mail.mcgill.ca
Fri Jan 15 14:33:54 CST 2016
Yes, you are right. In matrix-free SGS, the AUSM 2nd order inviscid fluxes
are replace by a simpler first order numerical fluxes.
2016-01-15 14:42 GMT-05:00 Barry Smith <bsmith at mcs.anl.gov>:
> > On Jan 15, 2016, at 10:52 AM, Song Gao <song.gao2 at mail.mcgill.ca> wrote:
> > Hello, Barry,
> > Thanks for your prompt reply.  I ran the matrix-based solver with
> matrix-based SGS precondioner. I see your point. The profiling table is
> below and attached.
> > So Matmult takes 4% time and PCApply takes 43% time.
> >  MatMult              636 1.0 9.0361e+00 1.0 9.21e+09 1.0 7.6e+03
> 1.1e+04 0.0e+00  4 85 52 17  0   4 85 52 17  0  3980
> >  PCApply              636 1.0 8.7006e+01 1.0 0.00e+00 0.0 0.0e+00
> 0.0e+00 1.9e+03 43  0  0  0 24  43  0  0  0 24     0
> > The way I see it, the matrix-free solver spends most of the time (70%)
> on matmult or equivalently rhs evaluation. Every KSP iteration, one rhs
> evaluation is performed. This is much more costly than a matrix vector
> product in a matrix-based solver.
>   Sure,   but if the matrix-free SGS mimics all the work of the right hand
> side function evaluation (which is has to if it truly is a a SGS sweep and
> not some approximation (where you drop certain terms in the right hand side
> function when you compute the SGS)) then the matrix-free SGS should be at
> least as expensive as the right hand side evaluation.
>    Barry
> My guess is your SGS drops some terms so is only and approximation, but is
> still good enough as a preconditioner.
> > Perhaps this is expected in matrix-free solver.
> > I will start look at the rhs evaluation since it takes the most time.
> > Thanks.
> > Song Gao
> > 2016-01-14 16:24 GMT-05:00 Barry Smith <bsmith at mcs.anl.gov>:
> >    So
> >     KSPSolve is 96 % and MatMult is 70 % + PCApply 24 % = 94 % so this
> makes sense; the solver time is essentially the
> > multiply time plus the PCApply time.
> > compute_rhs         1823 1.0 4.2119e+02 1.0 0.00e+00 0.0 4.4e+04 5.4e+04
> 1.1e+04 71  0100100 39  71  0100100 39     0
> > LU-SGS              1647 1.0 1.3590e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00 23  0  0  0  0  23  0  0  0  0     0
> > SURFINT             1823 1.0 1.0647e+02 1.1 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00 17  0  0  0  0  17  0  0  0  0     0
> > VOLINT              1823 1.0 2.2373e+02 1.1 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00 35  0  0  0  0  35  0  0  0  0     0
> >    Depending on the "quality" of the preconditioner (if it is really
> good) one expects the preconditioner time to be larger than the MatMult().
> Only for simple preconditioners (like Jacobi) does one see it being much
> less than the MatMult().  For matrix based solvers the amount of work in
> SGS is as large as the amount of work in the MatMult() if not more, so I
> would expect the time of the preconditioner to be higher than the time of
> the multiply.
> >   So based on knowing almost nothing I think the MatMult_ is taking more
> time then it should unless you are ignoring (skipping) a lot of the terms
> in your matrix-free SGS; then it is probably reasonable.
> >   Barry
> > > On Jan 14, 2016, at 3:01 PM, Song Gao <song.gao2 at mail.mcgill.ca>
> wrote:
> > > Hello,
> > > I am profiling a finite element Navier-Stokes solver. It uses the
> Jacobian-free Newton Krylov method and a custom preconditoner LU-SGS (a
> matrix-free version of Symmetic Gauss-Seidel ). The log summary is
> attached. Four events are registered.  compute_rhs is compute rhs (used by
> MatMult_MFFD). SURFINT and VOLINT are parts of compute_rhs. LU-SGS is the
> custom preconditioner. I didn't call PetscLogFlops so these flops are zeros.
> > >  I'm wondering, is the percent time of the events reasonable in the
> table? I see 69% time is spent on  matmult_mffd. Is it expected in
> matrix-free method? What might be a good starting point of profiling this
> solver? Thank you in advance.
> > > Song Gao
> > > <log_summary>
> > <log_summary_matrix_based_version>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160115/9d66bff7/attachment.html>
