[petsc-users] HPCToolKit/HPCViewer on OS X
Thu Jan 14 15:13:40 CST 2016
> On Jan 14, 2016, at 2:30 PM, Griffith, Boyce Eugene <boyceg at email.unc.edu> wrote:
>> On Jan 14, 2016, at 3:09 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>> On Jan 14, 2016, at 2:01 PM, Griffith, Boyce Eugene <boyceg at email.unc.edu> wrote:
>>>> On Jan 14, 2016, at 2:24 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>> Matt is right, there is a lot of "missing" time from the output. Please send the output from -ksp_view so we can see exactly what solver is being used.
>>>> From the output we have:
>>>>  Nonlinear solver 78 % of the time (so your "setup code" outside of PETSC is taking about 22% of the time)
>>>>  Linear solver 77 % of the time (this is reasonable pretty much the entire cost of the nonlinear solve is the linear solve)
>>>>  Time to set up the preconditioner is 19%  (10 + 9)
>>>>  Time of iteration in KSP 35 % (this is the sum of the vector operations and MatMult() and MatSolve())
>>>>   So 77 - (19 + 35) = 23 % unexplained time inside the linear solver (custom preconditioner???)
>>>>  Also getting the results with Instruments or HPCToolkit would be useful (so long as we don't need to install HPCTool ourselves to see the results).
>>> Thanks, Barry (& Matt & Dave) --- This is a solver that is mixing some matrix-based stuff implemented using PETSc along with some matrix-free stuff that is built on top of SAMRAI. Amneet and I should take a look at performance off-list first.
>>   Just put an PetscLogEvent() in (or several) to track that part. Plus put an event or two outside the SNESSolve to track the outside PETSc setup time.
>>   The PETSc time looks reasonable at most I can only image any optimizations we could do bringing it down a small percentage.
> Here is a bit more info about what we are trying to do:
> This is a Vanka-type MG preconditioner for a Stokes-like system on a structured grid. (Currently just uniform grids, but hopefully soon with AMR.) For the smoother, we are using damped Richardson + ASM with relatively small block subdomains --- e.g., all DOFs associated with 8x8 cells in 2D (~300 DOFs), or 8x8x8 in 3D (~2500 DOFs). Unfortunately, MG iteration counts really tank when using smaller subdomains.
> I can't remember whether we have quantified this carefully, but PCASM seems to bog down with smaller subdomains. A question is whether there are different implementation choices that could make the case of "lots of little subdomains" run faster.
   This is possibly somewhere where WE (PETSc) could perhaps due a better job. When originally written we definitely were biased to a small number of large subdomains so things like getting the sub matrices (and even iterating over them) could possibly be optimized when there are many. However, as you note, in the current runs this is definitely not the issue.
  Barry
> But before we get to that, Amneet and I should take a more careful look at overall solver performance.
> (We are also starting to play around with PCFIELDSPLIT for this problem too, although we don't have many ideas about how to handle the Schur complement.)
> Thanks,
> -- Boyce
>>   Barry
>>> -- Boyce
>>>> Barry
>>>>> On Jan 14, 2016, at 1:26 AM, Bhalla, Amneet Pal S <amneetb at live.unc.edu> wrote:
>>>>>> On Jan 13, 2016, at 9:17 PM, Griffith, Boyce Eugene <boyceg at email.unc.edu> wrote:
>>>>>> I see one hot spot:
>>>>> Here is with opt build
>>>>> ***             WIDEN YOUR WINDOW TO 120 CHARACTERS.  Use 'enscript -r -fCourier9' to print this document            ***
>>>>> ---------------------------------------------- PETSc Performance Summary: ----------------------------------------------
>>>>> ./main2d on a linux-opt named aorta with 1 processor, by amneetb Thu Jan 14 02:24:43 2016
>>>>> Using Petsc Development GIT revision: v3.6.3-3098-ga3ecda2  GIT Date: 2016-01-13 21:30:26 -0600
>>>>>                       Max       Max/Min        Avg      Total
>>>>> Time (sec):           1.018e+00      1.00000   1.018e+00
>>>>> Objects:              2.935e+03      1.00000   2.935e+03
>>>>> Flops:                4.957e+08      1.00000   4.957e+08  4.957e+08
>>>>> Flops/sec:            4.868e+08      1.00000   4.868e+08  4.868e+08
>>>>> MPI Messages:         0.000e+00      0.00000   0.000e+00  0.000e+00
>>>>> MPI Message Lengths:  0.000e+00      0.00000   0.000e+00  0.000e+00
>>>>> MPI Reductions:       0.000e+00      0.00000
>>>>> Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
>>>>>                          e.g., VecAXPY() for real vectors of length N --> 2N flops
>>>>>                          and VecAXPY() for complex vectors of length N --> 8N flops
>>>>> Summary of Stages:   ----- Time ------  ----- Flops -----  --- Messages ---  -- Message Lengths --  -- Reductions --
>>>>>                      Avg     %Total     Avg     %Total   counts   %Total     Avg         %Total   counts   %Total
>>>>> 0:      Main Stage: 1.0183e+00 100.0%  4.9570e+08 100.0%  0.000e+00   0.0%  0.000e+00        0.0% 0.000e+00   0.0%
>>>>> See the 'Profiling' chapter of the users' manual for details on interpreting output.
>>>>> Phase summary info:
>>>>> Count: number of times phase was executed
>>>>> Time and Flops: Max - maximum over all processors
>>>>>                 Ratio - ratio of maximum to minimum over all processors
>>>>> Mess: number of messages sent
>>>>> Avg. len: average message length (bytes)
>>>>> Reduct: number of global reductions
>>>>> Global: entire computation
>>>>> Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
>>>>>    %T - percent time in this phase         %F - percent flops in this phase
>>>>>    %M - percent messages in this phase     %L - percent message lengths in this phase
>>>>>    %R - percent reductions in this phase
>>>>> Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time over all processors)
>>>>> Event                Count      Time (sec)     Flops                             --- Global ---  --- Stage ---   Total
>>>>>                 Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
>>>>> --- Event Stage 0: Main Stage
>>>>> VecDot                 4 1.0 2.9564e-05 1.0 3.31e+04 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0 0  1120
>>>>> VecDotNorm2          272 1.0 1.4565e-03 1.0 4.25e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1 0  0  0  2920
>>>>> VecMDot              624 1.0 8.4300e-03 1.0 5.29e+06 1.0 0.0e+00 0.0e+00 0.0e+00  1  1  0  0  0   1  1  0 0  0   627
>>>>> VecNorm              565 1.0 3.8033e-03 1.0 4.38e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0 0  0  1151
>>>>> VecScale              86 1.0 5.5480e-04 1.0 1.55e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0 0  0   279
>>>>> VecCopy               28 1.0 5.2261e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0 0  0     0
>>>>> VecSet             14567 1.0 1.2443e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0 0  0     0
>>>>> VecAXPY              903 1.0 4.2996e-03 1.0 6.66e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0 0  0  1550
>>>>> VecAYPX              225 1.0 1.2550e-03 1.0 8.55e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0 0  0   681
>>>>> VecAXPBYCZ            42 1.0 1.7118e-04 1.0 3.45e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0 0  0  0  2014
>>>>> VecWAXPY              70 1.0 1.9503e-04 1.0 2.98e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0 0  0  0  1528
>>>>> VecMAXPY             641 1.0 1.1136e-02 1.0 5.29e+06 1.0 0.0e+00 0.0e+00 0.0e+00  1  1  0  0  0   1  1 0  0  0   475
>>>>> VecSwap              135 1.0 4.5896e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0 0  0     0
>>>>> VecAssemblyBegin     745 1.0 4.9477e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0 0  0  0  0     0
>>>>> VecAssemblyEnd       745 1.0 9.2411e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0 0  0  0  0     0
>>>>> VecScatterBegin    40831 1.0 3.4502e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  3  0  0  0  0   3 0  0  0  0     0
>>>>> BuildTwoSidedF       738 1.0 2.6712e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0 0  0  0     0
>>>>> MatMult              513 1.0 9.1235e-02 1.0 7.75e+07 1.0 0.0e+00 0.0e+00 0.0e+00  9 16  0  0  0   9 16  0 0  0   849
>>>>> MatSolve           13568 1.0 2.3605e-01 1.0 3.45e+08 1.0 0.0e+00 0.0e+00 0.0e+00 23 70  0  0  0  23 70 0  0  0  1460
>>>>> MatLUFactorSym        84 1.0 3.7430e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  4  0  0  0  0   4  0 0  0  0     0
>>>>> MatLUFactorNum        85 1.0 3.9623e-02 1.0 4.19e+07 1.0 0.0e+00 0.0e+00 0.0e+00  4  8  0  0  0   4  8 0  0  0  1058
>>>>> MatILUFactorSym        1 1.0 3.3617e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0 0  0  0     0
>>>>> MatScale               4 1.0 2.5511e-04 1.0 2.51e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0 0   984
>>>>> MatAssemblyBegin     108 1.0 6.3658e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0 0  0  0  0     0
>>>>> MatAssemblyEnd       108 1.0 2.9490e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0 0  0  0  0     0
>>>>> MatGetRow          33120 1.0 2.0157e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0   2  0 0  0  0     0
>>>>> MatGetRowIJ           85 1.0 1.2145e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0 0  0  0     0
>>>>> MatGetSubMatrice       4 1.0 8.4379e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0 0  0  0     0
>>>>> MatGetOrdering        85 1.0 7.7887e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0 0  0  0     0
>>>>> MatAXPY                4 1.0 4.9596e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  5  0  0  0  0   5  0  0 0  0     0
>>>>> MatPtAP                4 1.0 4.4426e-02 1.0 4.99e+06 1.0 0.0e+00 0.0e+00 0.0e+00  4  1  0  0  0   4  1  0  0 0   112
>>>>> MatPtAPSymbolic        4 1.0 2.7664e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  3  0  0  0  0   3  0 0  0  0     0
>>>>> MatPtAPNumeric         4 1.0 1.6732e-02 1.0 4.99e+06 1.0 0.0e+00 0.0e+00 0.0e+00  2  1  0  0  0   2  1 0  0  0   298
>>>>> MatGetSymTrans         4 1.0 3.6621e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0 0  0  0     0
>>>>> KSPGMRESOrthog        16 1.0 9.7778e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1 0  0  0  0     0
>>>>> KSPSetUp              90 1.0 5.7650e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0 0  0     0
>>>>> KSPSolve               1 1.0 7.8831e-01 1.0 4.90e+08 1.0 0.0e+00 0.0e+00 0.0e+00 77 99  0  0  0  77 99 0  0  0   622
>>>>> PCSetUp               90 1.0 9.9725e-02 1.0 4.19e+07 1.0 0.0e+00 0.0e+00 0.0e+00 10  8  0  0  0  10  8  0 0  0   420
>>>>> PCSetUpOnBlocks      112 1.0 8.7547e-02 1.0 4.19e+07 1.0 0.0e+00 0.0e+00 0.0e+00  9  8  0  0  0   9 8  0  0  0   479
>>>>> PCApply               16 1.0 7.1952e-01 1.0 4.89e+08 1.0 0.0e+00 0.0e+00 0.0e+00 71 99  0  0  0  71 99 0  0  0   680
>>>>> SNESSolve              1 1.0 7.9225e-01 1.0 4.90e+08 1.0 0.0e+00 0.0e+00 0.0e+00 78 99  0  0  0  78 99 0  0  0   619
>>>>> SNESFunctionEval       2 1.0 3.2940e-03 1.0 4.68e+04 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0 0  0  0    14
>>>>> SNESJacobianEval       1 1.0 4.7255e-04 1.0 4.26e+03 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0 0  0  0     9
>>>>> Memory usage is given in bytes:
>>>>> Object Type          Creations   Destructions     Memory  Descendants' Mem.
>>>>> Reports information only for process 0.
>>>>>            Vector   971            839     15573352     0.
>>>>>    Vector Scatter   290            289       189584     0.
>>>>>         Index Set  1171            823       951928     0.
>>>>> IS L to G Mapping   110            109      2156656     0.
>>>>> Application Order     6              6        99952     0.
>>>>>           MatMFFD     1              1          776     0.
>>>>>            Matrix   189            189     24083332     0.
>>>>> Matrix Null Space     4              4         2432     0.
>>>>>     Krylov Solver    90             90       122720     0.
>>>>>   DMKSP interface     1              1          648     0.
>>>>>    Preconditioner    90             90        89872     0.
>>>>>              SNES     1              1         1328     0.
>>>>>    SNESLineSearch     1              1          984     0.
>>>>>            DMSNES     1              1          664     0.
>>>>>  Distributed Mesh     2              2         9168     0.
>>>>> Star Forest Bipartite Graph     4              4         3168     0.
>>>>>   Discrete System     2              2         1712     0.
>>>>>            Viewer     1              0            0     0.
>>>>> Average time to get PetscTime(): 9.53674e-07
>>>>> #PETSc Option Table entries:
>>>>> -ib_ksp_converged_reason
>>>>> -ib_ksp_monitor_true_residual
>>>>> -ib_snes_type ksponly
>>>>> -log_summary
>>>>> -stokes_ib_pc_level_0_sub_pc_factor_nonzeros_along_diagonal
>>>>> -stokes_ib_pc_level_0_sub_pc_type ilu
>>>>> -stokes_ib_pc_level_ksp_richardson_self_scale
>>>>> -stokes_ib_pc_level_ksp_type richardson
>>>>> -stokes_ib_pc_level_pc_asm_local_type additive
>>>>> -stokes_ib_pc_level_sub_pc_factor_nonzeros_along_diagonal
>>>>> -stokes_ib_pc_level_sub_pc_type lu
>>>>> #End of PETSc Option Table entries
>>>>> Compiled without FORTRAN kernels
>>>>> Compiled with full precision matrices (default)
>>>>> sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8 sizeof(PetscScalar) 8 sizeof(PetscInt) 4
>>>>> Configure options: --CC=mpicc --CXX=mpicxx --FC=mpif90 --with-default-arch=0 --PETSC_ARCH=linux-opt --with-debugging=0 --with-c++-support=1 --with-hypre=1 --download-hypre=1 --with-hdf5=yes --COPTFLAGS=-O3 --CXXOPTFLAGS=-O3 --FOPTFLAGS=-O3
>>>>> Libraries compiled on Thu Jan 14 01:29:56 2016 on aorta
>>>>> Machine characteristics: Linux-3.13.0-63-generic-x86_64-with-Ubuntu-14.04-trusty
>>>>> Using PETSc directory: /not_backed_up/amneetb/softwares/PETSc-BitBucket/PETSc
>>>>> Using PETSc arch: linux-opt
>>>>> Using C compiler: mpicc  -fPIC  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -Qunused-arguments -O3  ${COPTFLAGS} ${CFLAGS}
>>>>> Using Fortran compiler: mpif90  -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -O3   ${FOPTFLAGS} ${FFLAGS}
>>>>> Using include paths: -I/not_backed_up/amneetb/softwares/PETSc-BitBucket/PETSc/linux-opt/include -I/not_backed_up/amneetb/softwares/PETSc-BitBucket/PETSc/include -I/not_backed_up/amneetb/softwares/PETSc-BitBucket/PETSc/include -I/not_backed_up/amneetb/softwares/PETSc-BitBucket/PETSc/linux-opt/include -I/not_backed_up/softwares/MPICH/include
>>>>> Using C linker: mpicc
>>>>> Using Fortran linker: mpif90
>>>>> Using libraries: -Wl,-rpath,/not_backed_up/amneetb/softwares/PETSc-BitBucket/PETSc/linux-opt/lib -L/not_backed_up/amneetb/softwares/PETSc-BitBucket/PETSc/linux-opt/lib -lpetsc -Wl,-rpath,/not_backed_up/amneetb/softwares/PETSc-BitBucket/PETSc/linux-opt/lib -L/not_backed_up/amneetb/softwares/PETSc-BitBucket/PETSc/linux-opt/lib -lHYPRE -Wl,-rpath,/not_backed_up/softwares/MPICH/lib -L/not_backed_up/softwares/MPICH/lib -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.8 -L/usr/lib/gcc/x86_64-linux-gnu/4.8 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -lmpicxx -lstdc++ -llapack -lblas -lpthread -lhdf5hl_fortran -lhdf5_fortran -lhdf5_hl -lhdf5 -lX11 -lm -lmpifort -lgfortran -lm -lgfortran -lm -lquadmath -lm -lmpicxx -lstdc++ -Wl,-rpath,/not_backed_up/softwares/MPICH/lib -L/not_backed_up/softwares/MPICH/lib -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.8 -L/usr/lib/gcc/x86_64-linux-gnu/4.8 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -ldl -Wl,-rpath,/not_backed_up/softwares/MPICH/lib -lmpi -lgcc_s -ldl
