[petsc-users] HPCToolKit/HPCViewer on OS X
Griffith, Boyce Eugene boyceg at email.unc.edu
Thu Jan 14 08:30:38 CST 2016
On Jan 14, 2016, at 8:44 AM, Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>> wrote:
On Thu, Jan 14, 2016 at 7:37 AM, Dave May <dave.mayhem23 at gmail.com<mailto:dave.mayhem23 at gmail.com>> wrote:
On 14 January 2016 at 14:24, Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>> wrote:
On Wed, Jan 13, 2016 at 11:12 PM, Bhalla, Amneet Pal S <amneetb at live.unc.edu<mailto:amneetb at live.unc.edu>> wrote:
On Jan 13, 2016, at 6:22 PM, Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>> wrote:
Can you mail us a -log_summary for a rough cut? Sometimes its hard
to interpret the data avalanche from one of those tools without a simple map.
Does this indicate some hot spots?
1) There is a misspelled option -stokes_ib_pc_level_ksp_richardson_self_scae
You can try to avoid this by giving -options_left
2) Are you using any custom code during the solve? There is a gaping whole in the timing. It take 9s to
    do PCApply(), but something like a collective 1s to do everything we time under that.
You are looking at the timing from a debug build.
The results from the optimized build don't have such a gaping hole.
It still looks like 50% of the runtime to me.
Amneet, on OS X, I would echo Barry and suggest starting out using the timer profiler instrument (accessible through the Instruments app).
-- Boyce
   Matt
Since this is serial, we can use something like kcachegrind to look at performance as well, which should
at least tell us what is sucking up this time so we can put a PETSc even on it.
     Matt
***             WIDEN YOUR WINDOW TO 120 CHARACTERS.  Use 'enscript -r -fCourier9' to print this document            ***
---------------------------------------------- PETSc Performance Summary: ----------------------------------------------
./main2d on a darwin-dbg named Amneets-MBP.attlocal.net<http://amneets-mbp.attlocal.net/> with 1 processor, by Taylor Wed Jan 13 21:07:43 2016
Using Petsc Development GIT revision: v3.6.1-2556-g6721a46  GIT Date: 2015-11-16 13:07:08 -0600
                         Max       Max/Min        Avg      Total
Time (sec):           1.039e+01      1.00000   1.039e+01
Objects:              2.834e+03      1.00000   2.834e+03
Flops:                3.552e+08      1.00000   3.552e+08  3.552e+08
Flops/sec:            3.418e+07      1.00000   3.418e+07  3.418e+07
Memory:               3.949e+07      1.00000              3.949e+07
MPI Messages:         0.000e+00      0.00000   0.000e+00  0.000e+00
MPI Message Lengths:  0.000e+00      0.00000   0.000e+00  0.000e+00
MPI Reductions:       0.000e+00      0.00000
Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
                            e.g., VecAXPY() for real vectors of length N --> 2N flops
                            and VecAXPY() for complex vectors of length N --> 8N flops
Summary of Stages:   ----- Time ------  ----- Flops -----  --- Messages ---  -- Message Lengths --  -- Reductions --
                        Avg     %Total     Avg     %Total   counts   %Total     Avg         %Total   counts   %Total
 0:      Main Stage: 1.0391e+01 100.0%  3.5520e+08 100.0%  0.000e+00   0.0%  0.000e+00        0.0%  0.000e+00   0.0%
See the 'Profiling' chapter of the users' manual for details on interpreting output.
Phase summary info:
   Count: number of times phase was executed
   Time and Flops: Max - maximum over all processors
                   Ratio - ratio of maximum to minimum over all processors
   Mess: number of messages sent
   Avg. len: average message length (bytes)
   Reduct: number of global reductions
   Global: entire computation
   Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
      %T - percent time in this phase         %F - percent flops in this phase
      %M - percent messages in this phase     %L - percent message lengths in this phase
      %R - percent reductions in this phase
   Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time over all processors)
      #                          WARNING!!!                    #
      #   This code was compiled with a debugging option,      #
      #   To get timing results run ./configure                #
      #   using --with-debugging=no, the performance will      #
      #   be generally two or three times faster.              #
Event                Count      Time (sec)     Flops                             --- Global ---  --- Stage ---   Total
                   Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
--- Event Stage 0: Main Stage
VecDot                 4 1.0 9.0525e-04 1.0 3.31e+04 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0    37
VecMDot              533 1.0 1.5936e-02 1.0 5.97e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  2  0  0  0   0  2  0  0  0   375
VecNorm              412 1.0 9.2107e-03 1.0 3.57e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0   388
VecScale             331 1.0 5.8195e-01 1.0 1.41e+06 1.0 0.0e+00 0.0e+00 0.0e+00  6  0  0  0  0   6  0  0  0  0     2
VecCopy              116 1.0 1.9983e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet             18362 1.0 1.5249e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
VecAXPY              254 1.0 4.3961e-01 1.0 1.95e+06 1.0 0.0e+00 0.0e+00 0.0e+00  4  1  0  0  0   4  1  0  0  0     4
VecAYPX               92 1.0 2.5167e-03 1.0 2.66e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   106
VecAXPBYCZ            36 1.0 8.6242e-04 1.0 2.94e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   341
VecWAXPY              58 1.0 1.2539e-03 1.0 2.47e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   197
VecMAXPY             638 1.0 2.3439e-02 1.0 7.68e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  2  0  0  0   0  2  0  0  0   328
VecSwap              111 1.0 1.9721e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0   2  0  0  0  0     0
VecAssemblyBegin     607 1.0 3.8150e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAssemblyEnd       607 1.0 8.3705e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecScatterBegin    26434 1.0 3.0096e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  3  0  0  0  0   3  0  0  0  0     0
VecNormalize         260 1.0 4.9754e-01 1.0 3.84e+06 1.0 0.0e+00 0.0e+00 0.0e+00  5  1  0  0  0   5  1  0  0  0     8
BuildTwoSidedF       600 1.0 1.8942e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatMult              365 1.0 6.0306e-01 1.0 6.26e+07 1.0 0.0e+00 0.0e+00 0.0e+00  6 18  0  0  0   6 18  0  0  0   104
MatSolve            8775 1.0 6.8506e-01 1.0 2.25e+08 1.0 0.0e+00 0.0e+00 0.0e+00  7 63  0  0  0   7 63  0  0  0   328
MatLUFactorSym        85 1.0 1.0664e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
MatLUFactorNum        85 1.0 1.2066e-01 1.0 4.23e+07 1.0 0.0e+00 0.0e+00 0.0e+00  1 12  0  0  0   1 12  0  0  0   350
MatScale               4 1.0 4.0145e-04 1.0 2.51e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   625
MatAssemblyBegin     108 1.0 4.8849e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAssemblyEnd       108 1.0 9.8455e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetRow          33120 1.0 1.4157e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
MatGetRowIJ           85 1.0 2.6060e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetSubMatrice       4 1.0 4.2922e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetOrdering        85 1.0 3.1230e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAXPY                4 1.0 4.0459e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  4  0  0  0  0   4  0  0  0  0     0
MatPtAP                4 1.0 1.1362e-01 1.0 4.99e+06 1.0 0.0e+00 0.0e+00 0.0e+00  1  1  0  0  0   1  1  0  0  0    44
MatPtAPSymbolic        4 1.0 6.4973e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
MatPtAPNumeric         4 1.0 4.8521e-02 1.0 4.99e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0   103
MatGetSymTrans         4 1.0 5.9780e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPGMRESOrthog       182 1.0 2.0538e-02 1.0 5.11e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0   249
KSPSetUp              90 1.0 2.1210e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPSolve               1 1.0 9.5567e+00 1.0 3.50e+08 1.0 0.0e+00 0.0e+00 0.0e+00 92 98  0  0  0  92 98  0  0  0    37
PCSetUp               90 1.0 4.0597e-01 1.0 4.23e+07 1.0 0.0e+00 0.0e+00 0.0e+00  4 12  0  0  0   4 12  0  0  0   104
PCSetUpOnBlocks       91 1.0 2.9886e-01 1.0 4.23e+07 1.0 0.0e+00 0.0e+00 0.0e+00  3 12  0  0  0   3 12  0  0  0   141
PCApply               13 1.0 9.0558e+00 1.0 3.49e+08 1.0 0.0e+00 0.0e+00 0.0e+00 87 98  0  0  0  87 98  0  0  0    39
SNESSolve              1 1.0 9.5729e+00 1.0 3.50e+08 1.0 0.0e+00 0.0e+00 0.0e+00 92 98  0  0  0  92 98  0  0  0    37
SNESFunctionEval       2 1.0 1.3347e-02 1.0 4.68e+04 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     4
SNESJacobianEval       1 1.0 2.4613e-03 1.0 4.26e+03 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     2
Memory usage is given in bytes:
Object Type          Creations   Destructions     Memory  Descendants' Mem.
Reports information only for process 0.
              Vector   870            762     13314200     0.
      Vector Scatter   290            289       189584     0.
           Index Set  1171            823       951096     0.
   IS L to G Mapping   110            109      2156656     0.
   Application Order     6              6        99952     0.
             MatMFFD     1              1          776     0.
              Matrix   189            189     24202324     0.
   Matrix Null Space     4              4         2432     0.
       Krylov Solver    90             90       190080     0.
     DMKSP interface     1              1          648     0.
      Preconditioner    90             90        89128     0.
                SNES     1              1         1328     0.
      SNESLineSearch     1              1          856     0.
              DMSNES     1              1          664     0.
    Distributed Mesh     2              2         9024     0.
Star Forest Bipartite Graph     4              4         3168     0.
     Discrete System     2              2         1696     0.
              Viewer     1              0            0     0.
Average time to get PetscTime(): 4.74e-08
#PETSc Option Table entries:
-ib_ksp_converged_reason
-ib_ksp_monitor_true_residual
-ib_snes_type ksponly
-log_summary
-stokes_ib_pc_level_ksp_type gmres
-stokes_ib_pc_level_pc_asm_local_type additive
-stokes_ib_pc_level_pc_asm_type interpolate
-stokes_ib_pc_level_sub_pc_factor_nonzeros_along_diagonal
-stokes_ib_pc_level_sub_pc_type lu
#End of PETSc Option Table entries
Compiled without FORTRAN kernels
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8 sizeof(PetscScalar) 8 sizeof(PetscInt) 4
Configure options: --CC=mpicc --CXX=mpicxx --FC=mpif90 --PETSC_ARCH=darwin-dbg --with-debugging=1 --with-c++-support=1 --with-hypre=1 --download-hypre=1 --with-hdf5=yes --with-hdf5-dir=/Users/Taylor/Documents/SOFTWARES/HDF5/
Libraries compiled on Mon Nov 16 15:11:21 2015 on d209.math.ucdavis.edu<http://d209.math.ucdavis.edu/>
Machine characteristics: Darwin-14.5.0-x86_64-i386-64bit
Using PETSc directory: /Users/Taylor/Documents/SOFTWARES/PETSc-BitBucket/PETSc
Using PETSc arch: darwin-dbg
Using C compiler: mpicc    -g  ${COPTFLAGS} ${CFLAGS}
Using Fortran compiler: mpif90   -g   ${FOPTFLAGS} ${FFLAGS}
Using include paths: -I/Users/Taylor/Documents/SOFTWARES/PETSc-BitBucket/PETSc/darwin-dbg/include -I/Users/Taylor/Documents/SOFTWARES/PETSc-BitBucket/PETSc/include -I/Users/Taylor/Documents/SOFTWARES/PETSc-BitBucket/PETSc/include -I/Users/Taylor/Documents/SOFTWARES/PETSc-BitBucket/PETSc/darwin-dbg/include -I/opt/X11/include -I/Users/Taylor/Documents/SOFTWARES/HDF5/include -I/opt/local/include -I/Users/Taylor/Documents/SOFTWARES/MPICH/include
Using C linker: mpicc
Using Fortran linker: mpif90
Using libraries: -Wl,-rpath,/Users/Taylor/Documents/SOFTWARES/PETSc-BitBucket/PETSc/darwin-dbg/lib -L/Users/Taylor/Documents/SOFTWARES/PETSc-BitBucket/PETSc/darwin-dbg/lib -lpetsc -Wl,-rpath,/Users/Taylor/Documents/SOFTWARES/PETSc-BitBucket/PETSc/darwin-dbg/lib -L/Users/Taylor/Documents/SOFTWARES/PETSc-BitBucket/PETSc/darwin-dbg/lib -lHYPRE -Wl,-rpath,/Users/Taylor/Documents/SOFTWARES/MPICH/lib -L/Users/Taylor/Documents/SOFTWARES/MPICH/lib -Wl,-rpath,/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/6.1.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/6.1.0/lib/darwin -lclang_rt.osx -lmpicxx -lc++ -Wl,-rpath,/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.1.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.1.0/lib/darwin -lclang_rt.osx -llapack -lblas -Wl,-rpath,/opt/X11/lib -L/opt/X11/lib -lX11 -Wl,-rpath,/Users/Taylor/Documents/SOFTWARES/HDF5/lib -L/Users/Taylor/Documents/SOFTWARES/HDF5/lib -lhdf5_hl -lhdf5 -lssl -lcrypto -lmpifort -lgfortran -Wl,-rpath,/opt/local/lib/gcc49/gcc/x86_64-apple-darwin14/4.9.1 -L/opt/local/lib/gcc49/gcc/x86_64-apple-darwin14/4.9.1 -Wl,-rpath,/opt/local/lib/gcc49 -L/opt/local/lib/gcc49 -lgfortran -lgcc_ext.10.5 -lquadmath -lm -lclang_rt.osx -lmpicxx -lc++ -lclang_rt.osx -Wl,-rpath,/Users/Taylor/Documents/SOFTWARES/MPICH/lib -L/Users/Taylor/Documents/SOFTWARES/MPICH/lib -ldl -lmpi -lpmpi -lSystem -Wl,-rpath,/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.1.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.1.0/lib/darwin -lclang_rt.osx -ldl
-- Norbert Wiener
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160114/49957f67/attachment-0001.html>
