[petsc-users] Why use MATMPIBAIJ?
Hoang Giang Bui hgbk2008 at gmail.com
Thu Jan 14 05:04:35 CST 2016
This is a very interesting thread because use of block matrix improves the
performance of AMG a lot. In my case is the elasticity problem.
One more question I like to ask, which is more on the performance of the
solver. That if I have a coupled problem, says the point block is [u_x u_y
u_z p] in which entries of p block in stiffness matrix is in a much smaller
scale than u (p~1e-6, u~1e+8), then AMG with hypre in PETSc still scale?
Also, is there a utility in PETSc which does automatic scaling of variables?
Giang
On Thu, Jan 14, 2016 at 7:13 AM, Justin Chang <jychang48 at gmail.com> wrote:
> Okay that makes sense, thanks
> On Wed, Jan 13, 2016 at 10:12 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> > On Jan 13, 2016, at 10:24 PM, Justin Chang <jychang48 at gmail.com> wrote:
>> > Thanks Barry,
>> > 1) So for block matrices, the ja array is smaller. But what's the
>> "hardware" explanation for this performance improvement? Does it have to do
>> with spatial locality where you are more likely to reuse data in that ja
>> array, or does it have to do with the fact that loading/storing smaller
>> arrays are less likely to invoke a cache miss, thus reducing the amount of
>> bandwidth?
>> There are two distinct reasons for the improvement:
>> 1) For 5 by 5 blocks the ja array is 1/25th the size. The "hardware"
>> savings is that you have to load something that is much smaller than
>> before. Cache/spatial locality have nothing to do with this particular
>> improvement.
>> 2) The other improvement comes from the reuse of each x[j] value
>> multiplied by 5 values (a column) of the little block. The hardware
>> explanation is that x[j] can be reused in a register for the 5 multiplies
>> (while otherwise it would have to come from cache to register 5 times and
>> sometimes might even have been flushed from the cache so would have to come
>> from memory). This is why we have code like
>>     for (j=0; j<n; j++) {
>>       xb    = x + 5*(*idx++);
>>       x1    = xb[0]; x2 = xb[1]; x3 = xb[2]; x4 = xb[3]; x5 = xb[4];
>>       sum1 += v[0]*x1 + v[5]*x2 + v[10]*x3  + v[15]*x4 + v[20]*x5;
>>       sum2 += v[1]*x1 + v[6]*x2 + v[11]*x3  + v[16]*x4 + v[21]*x5;
>>       sum3 += v[2]*x1 + v[7]*x2 + v[12]*x3  + v[17]*x4 + v[22]*x5;
>>       sum4 += v[3]*x1 + v[8]*x2 + v[13]*x3  + v[18]*x4 + v[23]*x5;
>>       sum5 += v[4]*x1 + v[9]*x2 + v[14]*x3  + v[19]*x4 + v[24]*x5;
>>       v    += 25;
>> to do the block multiple.
>> > 2) So if one wants to assemble a monolithic matrix (i.e., aggregation
>> of more than one dof per point) then using the BAIJ format is highly
>> advisable. But if I want to form a nested matrix, say I am solving Stokes
>> equation, then each "submatrix" is of AIJ format? Can these sub matrices
>> also be BAIJ?
>>    Sure, but if you have separated all the variables of pressure,
>> velocity_x, velocity_y, etc into there own regions of the vector then the
>> block size for the sub matrices would be 1 so BAIJ does not help.
>>    There are Stokes solvers that use Vanka smoothing that keep the
>> variables interlaced and hence would use BAIJ and NOT use fieldsplit
>> > Thanks,
>> > Justin
>> > On Wed, Jan 13, 2016 at 9:12 PM, Barry Smith <bsmith at mcs.anl.gov>
>> wrote:
>> > > On Jan 13, 2016, at 9:57 PM, Justin Chang <jychang48 at gmail.com>
>> wrote:
>> > > Hi all,
>> > > 1) I am guessing MATMPIBAIJ could theoretically have better
>> performance than simply using MATMPIAIJ. Why is that? Is it similar to the
>> reasoning that block (dense) matrix-vector multiply is "faster" than simple
>> matrix-vector?
>> >   See for example table 1 in
>> http://citeseerx.ist.psu.edu/viewdoc/download?doi=10.1.1.38.7668&rep=rep1&type=pdf
>> > > 2) I am looking through the manual and online documentation and it
>> seems the term "block" used everywhere. In the section on "block matrices"
>> (3.1.3 of the manual), it refers to field splitting, where you could either
>> have a monolithic matrix or a nested matrix. Does that concept have
>> anything to do with MATMPIBAIJ?
>> >    Unfortunately the numerical analysis literature uses the term block
>> in multiple ways. For small blocks, sometimes called "point-block" with
>> BAIJ and for very large blocks (where the blocks are sparse themselves). I
>> used fieldsplit for big sparse blocks to try to avoid confusion in PETSc.
>> > > It makes sense to me that one could create a BAIJ where if you have 5
>> dofs of the same type of physics (e.g., five different primary species of a
>> geochemical reaction) per grid point, you could create a block size of 5.
>> And if you have different physics (e.g., velocity and pressure) you would
>> ideally want to separate them out (i.e., nested matrices) for better
>> preconditioning.
>> >    Sometimes you put them together with BAIJ and sometimes you keep
>> them separate with nested matrices.
>> > > Thanks,
>> > > Justin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160114/2b4afd0a/attachment.html>
