[petsc-users] Difference between Block Jacobi and ILU?
Justin Chang jychang48 at gmail.com
Wed Jan 13 21:37:12 CST 2016
Thanks Satish,
And yes I meant sequentially.
On Wed, Jan 13, 2016 at 8:26 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Wed, 13 Jan 2016, Justin Chang wrote:
> > Hi all,
> > What exactly is the difference between these two preconditioners? When I
> > use them to solve a Galerkin finite element poisson problem, I get the
> > exact same performance (iterations, wall-clock time, etc).
> you mean - when you run sequentially?
> With block jacobi - you decide the number of blocks. The default is
> 1-block/proc
> i.e - for sequnetial run you have only 1block i.e  the whole matrix.
> So the following are essentially the same:
> -pc_type bjacobi -pc_bjacobi_blocks 1 [default] -sub_pc_type ilu [default]
> -pc_type ilu
> Satish
> > Only thing is I can't seem to use ILU in parallel though.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160113/424650fa/attachment.html>
