[petsc-users] ODE Solver on multiple cores
Hasan, Fahad mhasan8 at vols.utk.edu
Wed Jan 13 13:13:33 CST 2016
Hello,
I have written a code to solve a simple differential equation (x''+x'+6x=0 with initial values, x(0)=2, x'(0)=3). It works well on a single core and produces result close to theoretical answer but whenever I am trying to run the same code on multiple cores, I am getting incorrect results. It seems to me that, for multiple cores it stops after taking only 2 steps regardless of the final time and gives the final result (which is inaccurate). I tried different TSType (TSEULER, TSBEULER, TSSUNDIALS, TSCN etc.) but I always ended up with the same issue.
Can you tell me what possibly may cause this problem? Thanks in advance.
Fahad
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160113/0274efc2/attachment.html>
