[petsc-users] osx configuration error
Mark Adams mfadams at lbl.gov
Wed Jan 13 11:43:09 CST 2016
I'm still having problems.  I have upgraded gcc and mpich. I am now
upgrading everything from homebrew.  Any ideas on this error?
thanks,
On Wed, Jan 13, 2016 at 2:15 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Jan 12, 2016 at 6:31 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>> > 'file' object has no attribute 'getvalue'  File
>> "/Users/markadams/Codes/petsc/config/configure.py", line 363, in
>> petsc_configure
>> Hm - have to figure this one out - but the primary issue is:
>> > stderr:
>> > gfortran: warning: couldn't understand kern.osversion '15.2.0
>> > ld: -rpath can only be used when targeting Mac OS X 10.5 or later
> I get this. The remedy I use is to put
>   MACOSX_DEPLOYMENT_TARGET=10.5
> in the environment. Its annoying, and quintessentially Mac.
>   Matt
>> Perhaps you've updated xcode or OSX - but did not reinstall brew/gfortran.
>> > Executing: mpif90 --version
>> > stdout:
>> > GNU Fortran (Homebrew gcc 4.9.1) 4.9.1
>> I suggest uninstalling/reinstalling homebrew packages.
>> Satish
>> On Tue, 12 Jan 2016, Mark Adams wrote:
>> > I did nuke the arch directory.  This has worked in the past and don't
>> know
>> > what I might have changed.  it's been awhile since I've reconfigured.
>> > Thanks,
>> > Mark
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160113/32080efb/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160113/32080efb/attachment-0001.obj>
