[petsc-users] METIS without C++ compiler
Jed Brown jed at jedbrown.org
Tue Jan 12 00:04:51 CST 2016
Tabrez Ali <tabrezali at gmail.com> writes:
> Hello
> I just wanted to point that configure fails when "--with-metis=1
> --download-metis=1" options are used and a C++ compiler is not installed.
> After changing "project(METIS)" to "project(METIS C)" in
> petsc-3.6.3/arch-linux2-c-opt/externalpackages/metis-5.1.0-p1/CMakeLists.txt
> it works alright.
Thanks, it looks like ParMETIS needs this too.  I've pushed this change
to the repositories for each.  Satish can bump the patch number and
point PETSc to the new version.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160111/5ebef33c/attachment.pgp>
