[petsc-users] question about SNESLINESEARCHBT
Michael Povolotskyi mpovolot at purdue.edu
Fri Jan 8 14:28:17 CST 2016
Dear Petsc developers and users,
I solve nonlinear systems with Newton Broyden method with Petsc.
I use line search algorithm of type SNESLINESEARCHBT.
Usually it works, but sometimes diverges. I want to change its
parameters that are listed in
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/SNES/SNESLINESEARCHBT.html#SNESLINESEARCHBT
Is there any way to set them in the code rather then from the command line?
Thank you,
Michael.
Michael Povolotskyi, PhD
Research Assistant Professor
Network for Computational Nanotechnology
Hall for Discover and Learning Research, Room 441
West Lafayette, IN 47907
Phone (765) 4949396
