[petsc-users] Block Jacobi for Matrix-free
Timothée Nicolas timothee.nicolas at gmail.com
Thu Jan 7 19:58:38 CST 2016
I see, I just tested PCPBJACOBI, which is better than PCJACOBI, but still I
may need PCBJACOBI. The problem is that I don't seem to be allowed to
define the matrix operation for MatGetDiagonalBlock... Indeed, I don't find
MATOP_GET_DIAGONAL_BLOCK in ${PETSC_DIR}/include/petscmat.h
Therefore, when I try to define it, I get the following error at
compilation (quite logically)
matrices.F90(174): error #6404: This name does not have a type, and must
have an explicit type.   [MATOP_GET_DIAGONAL_BLOCK]
     call
MatShellSetOperation(lctx(1)%PSmat,MATOP_GET_DIAGONAL_BLOCK,PSmatGetDiagonalBlock,ierr)
Also, if I change my mind and instead decide to go for PCPBJACOBI, I still
have a problem because the manual says that the routine you talk about,
MatInvertBlockDiagonal, is not available from FORTRAN. Indeed I cannot call
it. I still cannot call it after I provide a routine corresponding to
MATOP_INVERT_BLOCK_DIAGONAL.
So, it seems to mean that if I want to use this kind of algorithms, I will
have to hard code them, which would be too bad. Is that right, or is there
an other way around these two issues ?
Best
Timothee
2016-01-08 2:38 GMT+09:00 Barry Smith <bsmith at mcs.anl.gov>:
>   Timothee,
>       You are mixing up block Jacobi PCBJACOBI (which in PETSc generally
> uses "big" blocks) and point block Jacobi PCPBJACOBI (which generally means
> all the degrees of freedom associated with a single grid point -- in your
> case 3).
>    If you are doing matrix free with a shell matrix then you need to
> provide your own MatInvertBlockDiagonal() which in your case would invert
> each of your little 3 by 3 blocks and store the result in a 1d array; each
> little block in column major order followed by the next one. See for
> example MatInvertBlockDiagonal_SeqAIJ(). You also need you matrix to return
> a block size of 3.
>    Barry
> > On Jan 7, 2016, at 8:08 AM, Timothée Nicolas <timothee.nicolas at gmail.com>
> wrote:
> > Ok, so it should be sufficient. Great, I think I can do it.
> > Best
> > Timothée
> > 2016-01-07 23:06 GMT+09:00 Matthew Knepley <knepley at gmail.com>:
> > On Thu, Jan 7, 2016 at 7:49 AM, Timothée Nicolas <
> timothee.nicolas at gmail.com> wrote:
> > Hello everyone,
> > I have discovered that I need to use Block Jacobi, rather than Jacobi,
> as a preconditioner/smoother. The linear problem I am solving at this stage
> lives in a subspace with 3 degrees of freedom, which represent the 3
> components of a 3D vector. In particular for multigrid, using BJACOBI
> instead of JACOBI as a smoother changes everything in terms of efficiency.
> I know it because I have tested with the actual matrix in matrix format for
> my problem. However, eventually, I want to be matrix free.
> > My question is, what are the operations I need to provide for the
> matrix-free approach to accept BJACOBI ? I am confused because when I try
> to apply BJACOBI to my matrix-free operator; the code asks for
> MatGetDiagonalBlock (see error below). But MatGetDiagonalBlock, in my
> understanding, returns a uniprocessor matrix representing the diagonal part
> of the matrix on this processor (as defined in the manual). Instead, I
> would expect that what is needed is a routine which returns a 3x3 matrix at
> the grid point (that is, the block associated with this grid point,
> coupling the 3 components of the vector together). How does this work ? Do
> I simply need to code MatGetDiagonalBlock ?
> > Just like Jacobi does not request one diagonal element at a time,
> Block-Jacobi does not request one diagonal block at a time. You
> > would need to implement that function, or write a custom block Jacobi
> for this matrix.
> >   Thanks,
> >     Matt
> > Thx
> > Best
> > Timothée
> > [0]PETSC ERROR: --------------------- Error Message
> > [0]PETSC ERROR: No support for this operation for this object type
> > [0]PETSC ERROR: Matrix type shell does not support getting diagonal block
> > [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> > [0]PETSC ERROR: Petsc Release Version 3.6.1, Jul, 22, 2015
> > [0]PETSC ERROR: ./miips on a arch-linux2-c-debug named Carl-9000 by
> timothee Thu Jan  7 22:41:13 2016
> > [0]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++
> --with-fc=gfortran --download-fblaslapack --download-mpich
> > [0]PETSC ERROR: #1 MatGetDiagonalBlock() line 166 in
> /home/timothee/Documents/petsc-3.6.1/src/mat/interface/matrix.c
> > [0]PETSC ERROR: #2 PCSetUp_BJacobi() line 126 in
> /home/timothee/Documents/petsc-3.6.1/src/ksp/pc/impls/bjacobi/bjacobi.c
> > [0]PETSC ERROR: #3 PCSetUp() line 982 in
> /home/timothee/Documents/petsc-3.6.1/src/ksp/pc/interface/precon.c
> > [0]PETSC ERROR: #4 KSPSetUp() line 332 in
> /home/timothee/Documents/petsc-3.6.1/src/ksp/ksp/interface/itfunc.c
> > [0]PETSC ERROR: #5 KSPSolve() line 546 in
> > What most experimenters take for granted before they begin their
> experiments lead.
> > -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160108/cec1cfb9/attachment.html>
