[petsc-users] Compile petsc with bgclang compilers on mira/vesta?
Guo, Hanqi hguo at anl.gov
Fri Feb 26 21:05:35 CST 2016
I am trying to compile petsc on mira with bgclang, because my application needs C++11 support.  I have tried several ways to configure but didn’t work.  Does anyone have ideas on this?  Thanks in advance!
The followings are several combinations I have tried:
> ./configure --prefix=$HOME/local.bgclang/petsc-3.6.3 --with-cc=mpicc --with-cxx=mpic++11 --with-fc=0 --with-clanguage=cxx
             Configuring PETSc to compile on your system
TESTING: checkCxxLibraries from config.compilers(config/BuildSystem/config/compilers.py:413)                                                   *******************************************************************************
                    UNABLE to EXECUTE BINARIES for ./configure
Cannot run executables created with C. If this machine uses a batch system
to submit jobs you will need to configure using ./configure with the additional option  --with-batch.
 Otherwise there is problem with the compilers. Can you compile and run code with your compiler 'mpicc'?
> ./configure --prefix=$HOME/local.bgclang/petsc-3.6.3 --with-cc=mpicc --with-cxx=mpic++11 --with-fc=0 --with-clanguage=cxx --with-batch
TESTING: check from config.libraries(config/BuildSystem/config/libraries.py:146)                                                               *******************************************************************************
         UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for details):
Unable to find mpi in default locations!
Perhaps you can specify with --with-mpi-dir=<directory>
If you do not want MPI, then give --with-mpi=0
You might also consider using --download-mpich instead
> ./configure --prefix=$HOME/local.bgclang/petsc-3.6.3 --with-fc=0 --with-clanguage=cxx --with-batch --with-mpi-dir=/soft/compilers/bgclang/mpi/bgclang
TESTING: configureFortranCommandLine from config.utilities.fortranCommandLine(config/BuildSystem/config/utilities/fortranCommandLine.py:27)
TESTING: configureLibrary from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:476)                                              *******************************************************************************
--with-mpi-dir=/soft/compilers/bgclang/mpi/bgclang did not work
Hanqi Guo
Postdoctoral Appointee
Mathematics and Computer Science Division
Argonne National Laboratory
9700 S. Cass Ave., Bldg 240
Argonne, IL 60439
e-mail: hguo at anl.gov
web: http://www.mcs.anl.gov/~hguo
phone: 630-252-7225
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160226/cbe8c216/attachment.html>
