[petsc-users] Blocked matrix storage
Manav Bhatia bhatiamanav at gmail.com
Fri Feb 26 11:01:07 CST 2016
  I am working on a problem with system of equations in complex numbers, and am splitting it up to solve it with petsc compiled for real number support:
(J_R + i J_I) (x_R + i x_I) + (r_R + i r_I) = 0
is then defined as
[ J_R   -J_I] {x_R}  +  {r_R}  = {0}
[ J_I    J_R] {x_I}  +  {r_I}  = {0}
I have tried block-Schur solver with the Jacobian defined using the nested matrix format with a separate matrix for each quadrant of the Jacobian. This works well for diagonally dominant cases, but for high-frequency problems (J_I scales with frequency), the solver convergence is very slow.
Now, I am attempting to create a single matrix so that I can use the other ksp+pc combinations for this system of equations.
I am wondering if there is a natural way to create an mpiaij or an mpibaij matrix from the nested matrix defined above.
I would appreciate any guidance on this.
Manav
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160226/c05dc38e/attachment.html>
