[petsc-users] Error - Out of memory. This could be due to allocating too large an object or bleeding by not properly ...
TAY wee-beng zonexo at gmail.com
Fri Feb 26 01:14:40 CST 2016
On 26/2/2016 1:56 AM, Barry Smith wrote:
>     Run a much smaller problem for a few time steps, making sure you free all the objects at the end, with the option -malloc_dump this will print all the memory that was not freed and hopefully help you track down which objects you forgot to free.
>    Barry
I run a smaller problem and lots of things are shown in the log. How can
I know which exactly are not freed from the memory?
Is this info helpful? Or should I run in a single core?
Thanks
>> On Feb 25, 2016, at 12:33 AM, TAY wee-beng <zonexo at gmail.com> wrote:
>> Hi,
>> I ran the code and it hangs again. However, adding -malloc_test doesn't seem to do any thing. The output (attached) is the same w/o it.
>> Wonder if there's anything else I can do.
>> Thank you
>> Yours sincerely,
>> TAY wee-beng
>> On 24/2/2016 11:33 PM, Matthew Knepley wrote:
>>> On Wed, Feb 24, 2016 at 9:28 AM, TAY wee-beng <zonexo at gmail.com> wrote:
>>> On 24/2/2016 11:18 PM, Matthew Knepley wrote:
>>>> On Wed, Feb 24, 2016 at 9:16 AM, TAY wee-beng <zonexo at gmail.com> wrote:
>>>> On 24/2/2016 9:12 PM, Matthew Knepley wrote:
>>>>> On Wed, Feb 24, 2016 at 1:54 AM, TAY wee-beng <zonexo at gmail.com> wrote:
>>>>> On 24/2/2016 10:28 AM, Matthew Knepley wrote:
>>>>>> On Tue, Feb 23, 2016 at 7:50 PM, TAY wee-beng <zonexo at gmail.com> wrote:
>>>>>> Hi,
>>>>>> I got this error (also attached, full) when running my code. It happens after a few thousand time steps.
>>>>>> The strange thing is that for 2 different clusters, it stops at 2 different time steps.
>>>>>> I wonder if it's related to DM since this happens after I added DM into my code.
>>>>>> In this case, how can I find out the error? I'm thinking valgrind may take very long and gives too many false errors.
>>>>>> It is very easy to find leaks. You just run a few steps with -malloc_dump and see what is left over.
>>>>>>     Matt
>>>>> Hi Matt,
>>>>> Do you mean running my a.out with the -malloc_dump and stop after a few time steps?
>>>>> What and how should I "see" then?
>>>>> -malloc_dump outputs all unfreed memory to the screen after PetscFinalize(), so you should see the leak.
>>>>> I guess it might be possible to keep creating things that you freed all at once at the end, but that is less likely.
>>>>>     Matt
>>>> Hi,
>>>> I got the output. I have zipped it since it's rather big. So it seems to be from DM routines but can you help me where the error is from?
>>>> Its really hard to tell by looking at it. What I do is remove things until there is no leak, then progressively
>>>> put thing back in until I have the culprit. Then you can think about what is not destroyed.
>>>>    Matt
>>> Ok so let me get this clear. When it shows:
>>> [21]Total space allocated 1728961264 bytes
>>> [21]1861664 bytes MatCheckCompressedRow() line 60 in /home/wtay/Codes/petsc-3.6.3/src/mat/utils/compressedrow.c
>>> [21]16 bytes PetscStrallocpy() line 188 in /home/wtay/Codes/petsc-3.6.3/src/sys/utils/str.c
>>> [21]624 bytes ISLocalToGlobalMappingCreate() line 270 in /home/wtay/Codes
>>> Does it mean that it's simply allocating space ie normal? Or does it show that there's memory leak ie error?
>>> I gave the wrong option. That dumps everything. Lets just look at the leaks with -malloc_test.
>>>   Sorry about that,
>>>      Matt
>>> If it's error, should I zoom in and debug around this time at this region?
>>> Thanks
>>>> Thanks.
>>>>>> Thank you
>>>>>> Yours sincerely,
>>>>>> TAY wee-beng
>>>>>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>>>>>> -- Norbert Wiener
>>>>> -- Norbert Wiener
>>>> -- Norbert Wiener
>>> -- Norbert Wiener
>> <ibm2d.err>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160226/2fb65292/attachment-0001.obj>
