[petsc-users] Neumann BC with non-symmetric matrix
Mohammad Mirzadeh mirzadeh at gmail.com
Thu Feb 25 20:32:19 CST 2016
Thanks a lot Barry. This was very helpful :)
On Thu, Feb 25, 2016 at 6:05 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > On Feb 25, 2016, at 4:18 PM, Mohammad Mirzadeh <mirzadeh at gmail.com>
> wrote:
> > Barry,
> > Thanks a lot for the detailed discussion. Things make much more sense
> now, especially I was confused why the manual says to provide call both
> 'MatSetNullSpace' and 'MatSetTransposeNullSpace'. I have couple of more
> questions and some observations I have made since yesterday.
> > 1) Is there a systematic way to tell KSP to stop when it stagnates? I am
> _not_ using SNES.
>   No, I added the issue
> https://bitbucket.org/petsc/petsc/issues/122/ksp-convergence-test-for-inconsistent
> writing the code for a new test is pretty simple, but you need to decide
> mathematically how you are going to detect "stagnation".
> > 2) Once KSP converges to the least-square solution, the residual must be
> in the nullspace of A^T because otherwise it would have been reduced by the
> solver. So is it (at lest theoretically) possible to use the residual
> vector as an approximate basis for the n(A^T)? In general this wouldn't be
> enough but I'm thinking since the nullspace is one-dimensional, maybe I
> could use the residual itself to manually project solution onto range of A
> after calling KSPSolve?
>   I don't see why this wouldn't work. Just run one initial solve till
> stagnation and then use the resulting residual as the null space for A^T
> for future solves (with the same matrix, of course). It could be
> interesting to plot the residual to see what it looks like and it that
> makes sense physically
> > 3) Are preconditoners applied to the left by default? If not which one
> are and which one are not?
>   It actually depends on the KSP, some algorithms only support right
> preconditioning, some implementations only support one or the other
> (depending on who wrote it) and some support both.  In PETSc CG, GMRES, and
> BiCGstab use left by default, both GMRES and BiCGstab  also support right.
> > 4) So then if I provide the nullspace of A, KSP residual should
> converge, correct? I have made a few observations:
> >    4-1) When I provide the nullspace of A through MatSetNullSpace, I
> (generally) do see the residual (preconditioned) become very small (~1e-12
> or so) but then it sometimes stagnates (say around 1e-10). Is this normal?
>   There is only some much convergence one can expect for linear solvers;
> how far one can drive down the residual depends at least in part on the
> conditioning of the matrix. The higher the conditioning the less you can
> get in tolerance.
> >    4-2) Another observation is that the true residual stagnates way
> earlier which I assume is an indication that the RHS is in fact not in the
> range of A.
>    You can hope this is the case.
>    Of course one cannot really know if the residual is stagnating due to
> an inconsistent right hand side or for some other reason. But if it
> stagnates at 10^-4 it is probably due to inconsistent right hand side if it
> stagnates at 10^-12 the right hand side is probably consistent. If it
> stagnates at 10^-8 then it could be due to inconsistent rhs and or some
> other reason.
> >    4-3) Also, I've seen that the choice of KSP and PC have considerable
> effects on the solver. For instance, by default I use hypre+bcgs and I have
> noticed I need to change coarse-grid relaxation from Gaussian Elimination
> to symmetric-sor/Jacobi otherwise hypre has issues. I assume this is
> because the AMG preconditioner is also singular on the coarse level?
>    Yes this is likely the reason.
> >    4-4) Along the same lines, I tried a couple of other PCs such as
> {jacobi, sor, gamg, ilu} and none of them were able to converge with bcgs
> as the KSP. However, with gmres, almost all of them converge
>    Sure this is expected
> > with the exception of gamg.
> >    4-5) If I use gmres instead of bcgs, and for any of {jacobi, sor,
> ilu}, the true residual seems to be generally 2-3 orders of magnitude
> smaller (1e-6 vs 1e-3). I suppose this is just because gmres is more robust?
>   Yes, with a single system I would recommend sticking with GMRES and
> avoiding Bcgs.
> >    4-6) With hypre, the true residual is always larger (~1e-3) than
> other PCs no matter if I use bcgs or gmres.
>    ok.
> > Sorry for the long discussion but this has turned out to be quite
> educational for me!
> > Thanks,
> > Mohammad
> > On Wed, Feb 24, 2016 at 2:21 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > > On Feb 24, 2016, at 9:07 AM, Mohammad Mirzadeh <mirzadeh at gmail.com>
> wrote:
> > > Barry,
> > > On Wednesday, February 24, 2016, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
> > > > On Feb 24, 2016, at 12:07 AM, Mohammad Mirzadeh <mirzadeh at gmail.com>
> wrote:
> > > At the PDE level the compatibility condition is satisfied. However I
> suspect that at the discrete level the rhs is not not exactly in the range.
> The reason for my suspicion is that I know for a fact that my
> discretization is not conservative at the hanging nodes.
> >    Could be.
> > > Thanks for the suggestion. I'll give it a try. Howerver, does GMRES
> fundamentally behave differently than BiCGSTAB for these systems? I have
> seen people saying that it can keep the solution in the range if rhs is
> already in the range but I thought any KSP would do the same?
> >     Here is the deal.  There are two issues here
> > 1)  Making sure that b is the in the range of A.  If b is not in the
> range of A then it is obviously impossible to find an x such that A x = b.
> If we divide b into a part in the range of A called br and the rest call it
> bp  then b = br + bp   and one can solve Ax = br   and the left over
> residual is bp. Normally if you run GMRES with an inconsistent right hand
> side (that is bp != 0) it will solve Ax = br automatically and thus give
> you a "least squares" answer which is likely what you want. These means in
> some sense you don't really need to worry about making sure that b is in
> the range of A. But the residuals of GMRES will stagnate, which makes sense
> because it cannot get rid of the bp part. In the least squares sense
> however GMRES has converged. If you provide MatSetTransposeNullSpace() then
> KSP automatically removes this space from b when it starts the Krylov
> method, this is nice because the GMRES residuals will go to zero.
> > 2) Making sure that huge multiples of the null space of A do not get
> into the computed solution.
> > With left preconditioning Krylov methods construct the solution in the
> space {Bb, BABb, BABABb, ..} if the range of B contains entries in the null
> space of A then the Krylov space will contain vectors in the null space of
> A. What can happen is that in each iteration of the Krylov space those
> entries grow and you end up with a solution x + xn where xn is in the null
> space of A and very large, thus it looks like GMRES is not converging since
> the solution "jump" each iteration. If you force the range of B to exclude
> the null space of A, that is project out the null space of A after applying
> B then nothing in the null space ever gets into the Krylov space and you
> get the "minimum norm" solution to the least squares problem which is what
> you almost always want. When you provide MatSetNullSpace() the KSP solvers
> automatically remove the null space after applying B.
> >  All this stuff applies for any Krylov method.
> >   So based on my understanding, you should just provide the null space
> that you can and forget out the transpose null space and use left
> preconditioning with GMRES (forget about what I said about trying with
> right preconditioning).  Let GMRES iterate until the residual norm has
> stabilized and use the resulting solution which is the least squares
> solution. If you are using KSP inside SNES you may need to set
> SNESSetMaxLinearSolveFailures() to a large value so it doesn't stop when it
> thinks the GMRES has failed.
> >   Barry
> > Matt and Jed, please check my logic I often flip my ranges/null spaces
> and may have incorrect presentation above.
> > > > > 2) I have tried fixing the solution at an arbitrary point, and
> while it generally works, for some problems I get numerical artifacts, e.g.
> slight asymmetry in the solution and/or increased error close to the point
> where I fix the solution. Is this, more or less, expected as a known
> artifact?
> > >   Yeah this approach is not good. We never recommend it.
> > > > > 3) An alternative to 2 is to enforce some global constraint on the
> solution, e.g. to require that the average be zero. My question here is
> two-fold:
> > > >   Requiring the average be zero is exactly the same as providing a
> null space of the constant function. Saying the average is zero is the same
> as saying the solution is orthogonal to the constant function. I don't see
> any reason to introduce the Lagrange multiplier and all its complications
> inside of just providing the constant null space.
> > > > Is this also true at the discrete level when the matrix is
> non-symmetric? I have always viewed this as just a constraint that could
> really be anything.
> > > > > 3-1) Is this generally any better than solution 2, in terms of not
> messing too much with the condition number of the matrix?
> > > > > 3-2) I don't quite know how to implement this using PETSc.
> Generally speaking I'd like to solve
> > > > > | A        U |   | X |   | B |
> > > > > | U^T      0 |   | s |   | 0 |
> > > > > where U is a constant vector (of ones) and s is effectively a
> Lagrange multiplier. I suspect I need to use MatCreateSchurComplement and
> pass that to the KSP? Or do I need create my own matrix type from scratch
> through MatCreateShell?
> > > > > Any help is appreciated!
> > > > > Thanks,
> > > > > Mohammad
> > > > Sent from Gmail Mobile
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160225/8b3d77b2/attachment.html>
