[petsc-users] Mass matrix with PetscFE
Thu Feb 25 18:22:04 CST 2016
I am sorry about the delay. I have your example working but it exposed a
bug in Plex so I need to push the fix first. I should have everything for
you early next week.
  Thanks
     Matt
On Feb 25, 2016 2:04 AM, "Julian Andrej" <juan at tf.uni-kiel.de> wrote:
> After a bit of rethinking the problem, the discrepancy between the size of
> matrix A and the mass matrix M arises because of the Dirichlet boundary
> conditions. So why aren't the BCs not imposed on the mass matrix? Do I need
> to handle Dirichlet BCs differently in this context (like zero rows and put
> one the diagonal?)
> On 24.02.2016 20:54, juan wrote:
>> I attached another example which creates the correct mass matrix
>> but also overwrites the DM for the SNES solve. Somehow i cannot manage
>> to really copy the DM to dm_mass and use that. If i try to do that with
>> DMClone(dm, &dm_mass) i get a smaller mass matrix (which is not of size
>> A).
>> Maybe this helps in the discussion.
>> Relevant code starts at line 455.
>> On 2016-02-24 15:03, Julian Andrej wrote:
>>> Thanks Matt,
>>> I attached the modified example.
>>> the corresponding code (and only changes to ex12) is starting at line
>>> 832.
>>> It also seems that the mass matrix is of size 169x169 and the
>>> stiffness matrix is of dimension 225x225. I'd assume that if i
>>> multiply test and trial function i'd get a matrix of same size (if the
>>> space/quadrature is the same for the stiffness matrix)
>>> On 24.02.2016 14:56, Matthew Knepley wrote:
>>>> On Wed, Feb 24, 2016 at 7:47 AM, Julian Andrej <juan at tf.uni-kiel.de
>>>> <mailto:juan at tf.uni-kiel.de>> wrote:
>>>>     I'm now using the petsc git master branch.
>>>>     I tried adding my code to the ex12
>>>>        DM dm_mass;
>>>>        PetscDS prob_mass;
>>>>        PetscFE fe;
>>>>        Mat M;
>>>>        PetscFECreateDefault(dm, user.dim, 1, PETSC_TRUE, NULL, -1, &fe);
>>>>        DMClone(dm, &dm_mass);
>>>>        DMGetDS(dm_mass, &prob_mass);
>>>>        PetscDSSetDiscretization(prob_mass, 0, (PetscObject) fe);
>>>>        PetscDSSetJacobian(prob_mass, 0, 0, mass_kernel, NULL, NULL,
>>>> NULL);
>>>>        DMCreateMatrix(dm_mass, &M);
>>>>        MatSetOptionsPrefix(M, "M_";)
>>>>     and receive the error on running
>>>>     ./exe -interpolate -refinement_limit 0.0125 -petscspace_order 2
>>>>     -M_mat_view binary
>>>>     WARNING! There are options you set that were not used!
>>>>     WARNING! could be spelling mistake, etc!
>>>>     Option left: name:-M_mat_view value: binary
>>>>     I don't know if the matrix is actually there and assembled or if the
>>>>     option is ommitted because something is wrong.
>>>> Its difficult to know when I cannot see the whole code. You can always
>>>> insert
>>>>    MatViewFromOptions(M, NULL, "-mat_view");
>>>>     Using
>>>>     MatView(M, PETSC_VIEWER_STDOUT_WORLD);
>>>>     gives me a reasonable output to stdout.
>>>> Good.
>>>>     But saving the matrix and analysing it in matlab, results in an all
>>>>     zero matrix.
>>>>     PetscViewerBinaryOpen(PETSC_COMM_WORLD, "Mout",FILE_MODE_WRITE,
>>>>     &viewer);
>>>>     MatView(M, viewer);
>>>> I cannot explain this, but it has to be something like you are viewing
>>>> the matrix before it is
>>>> actually assembled. Feel free to send the code. It sounds like it is
>>>> mostly working.
>>>>    Matt
>>>>     Any hints?
>>>>     On 24.02.2016 13 <tel:24.02.2016%2013>:58, Matthew Knepley wrote:
>>>>         On Wed, Feb 24, 2016 at 6:47 AM, Julian Andrej
>>>>         <juan at tf.uni-kiel.de <mailto:juan at tf.uni-kiel.de>
>>>>         <mailto:juan at tf.uni-kiel.de <mailto:juan at tf.uni-kiel.de>>>
>>>> wrote:
>>>>              Hi,
>>>>              i'm trying to assemble a mass matrix with the
>>>> PetscFE/DMPlex
>>>>              interface. I found something in the examples of TAO
>>>> https://bitbucket.org/petsc/petsc/src/da8116b0e8d067e39fd79740a8a864b0fe207998/src/tao/examples/tutorials/ex3.c?at=master&fileviewer=file-view-default
>>>>              but using the lines
>>>>              DMSetNumFields(dm_mass, 1);
>>>>              DMPlexCopyCoordinates(dm, dm_mass);
>>>>         NULL, NULL);
>>>>              DMPlexSNESComputeJacobianFEM(dm_mass, u, M, M, NULL);
>>>>              leads to errors in DMPlexSNESComputeJacobianFEM (u is a
>>>>         global vector).
>>>>              I don't can understand the necessary commands until
>>>>              DMPlexSNESComputeJacobianFEM. What does it do and why is it
>>>>              necessary? (especially why does the naming involve SNES?)
>>>>              Is there another/easier/better way to create a mass
>>>> matrix (the
>>>>              inner product of the function space and the test space)?
>>>>         1) That example needs updating. First, look at SNES ex12 which
>>>>         is up to
>>>>         date.
>>>>         2) I assume you are using 3.6. If you use the development
>>>>         version, you
>>>>         can remove DMPlexCopyCoordinates().
>>>>         3) You need to create the matrix BEFORE calling the assembly
>>>>         4) Always always always send the entire error messge
>>>>             Matt
>>>>              Regards
>>>>              Julian Andrej
>>>>         What most experimenters take for granted before they begin their
>>>>         experiments is infinitely more interesting than any results
>>>> to which
>>>>         their experiments lead.
>>>>         -- Norbert Wiener
>>>> experiments is infinitely more interesting than any results to which
>>>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160225/4a66858d/attachment-0001.html>
