[petsc-users] Mass matrix with PetscFE
juan juan at tf.uni-kiel.de
Wed Feb 24 13:54:27 CST 2016
I attached another example which creates the correct mass matrix
but also overwrites the DM for the SNES solve. Somehow i cannot manage
to really copy the DM to dm_mass and use that. If i try to do that with
DMClone(dm, &dm_mass) i get a smaller mass matrix (which is not of size
A).
Maybe this helps in the discussion.
Relevant code starts at line 455.
On 2016-02-24 15:03, Julian Andrej wrote:
> Thanks Matt,
> I attached the modified example.
> the corresponding code (and only changes to ex12) is starting at line
> 832.
> It also seems that the mass matrix is of size 169x169 and the
> stiffness matrix is of dimension 225x225. I'd assume that if i
> multiply test and trial function i'd get a matrix of same size (if the
> space/quadrature is the same for the stiffness matrix)
> On 24.02.2016 14:56, Matthew Knepley wrote:
>> On Wed, Feb 24, 2016 at 7:47 AM, Julian Andrej <juan at tf.uni-kiel.de
>> <mailto:juan at tf.uni-kiel.de>> wrote:
>>     I'm now using the petsc git master branch.
>>     I tried adding my code to the ex12
>>        DM dm_mass;
>>        PetscDS prob_mass;
>>        PetscFE fe;
>>        Mat M;
>>        PetscFECreateDefault(dm, user.dim, 1, PETSC_TRUE, NULL, -1,
>> &fe);
>>        DMClone(dm, &dm_mass);
>>        DMGetDS(dm_mass, &prob_mass);
>>        PetscDSSetDiscretization(prob_mass, 0, (PetscObject) fe);
>>        PetscDSSetJacobian(prob_mass, 0, 0, mass_kernel, NULL, NULL,
>> NULL);
>>        DMCreateMatrix(dm_mass, &M);
>>        MatSetOptionsPrefix(M, "M_";)
>>     and receive the error on running
>>     ./exe -interpolate -refinement_limit 0.0125 -petscspace_order 2
>>     -M_mat_view binary
>>     WARNING! There are options you set that were not used!
>>     WARNING! could be spelling mistake, etc!
>>     Option left: name:-M_mat_view value: binary
>>     I don't know if the matrix is actually there and assembled or if
>> the
>>     option is ommitted because something is wrong.
>> Its difficult to know when I cannot see the whole code. You can always
>> insert
>>    MatViewFromOptions(M, NULL, "-mat_view");
>>     Using
>>     MatView(M, PETSC_VIEWER_STDOUT_WORLD);
>>     gives me a reasonable output to stdout.
>> Good.
>>     But saving the matrix and analysing it in matlab, results in an
>> all
>>     zero matrix.
>>     PetscViewerBinaryOpen(PETSC_COMM_WORLD, "Mout",FILE_MODE_WRITE,
>>     &viewer);
>>     MatView(M, viewer);
>> I cannot explain this, but it has to be something like you are viewing
>> the matrix before it is
>> actually assembled. Feel free to send the code. It sounds like it is
>> mostly working.
>>    Matt
>>     Any hints?
>>     On 24.02.2016 13 <tel:24.02.2016%2013>:58, Matthew Knepley wrote:
>>         On Wed, Feb 24, 2016 at 6:47 AM, Julian Andrej
>>         <juan at tf.uni-kiel.de <mailto:juan at tf.uni-kiel.de>
>>         <mailto:juan at tf.uni-kiel.de <mailto:juan at tf.uni-kiel.de>>>
>> wrote:
>>              Hi,
>>              i'm trying to assemble a mass matrix with the
>> PetscFE/DMPlex
>>              interface. I found something in the examples of TAO
>> https://bitbucket.org/petsc/petsc/src/da8116b0e8d067e39fd79740a8a864b0fe207998/src/tao/examples/tutorials/ex3.c?at=master&fileviewer=file-view-default
>>              but using the lines
>>              DMSetNumFields(dm_mass, 1);
>>              DMPlexCopyCoordinates(dm, dm_mass);
>>         NULL, NULL);
>>              DMPlexSNESComputeJacobianFEM(dm_mass, u, M, M, NULL);
>>              leads to errors in DMPlexSNESComputeJacobianFEM (u is a
>>         global vector).
>>              I don't can understand the necessary commands until
>>              DMPlexSNESComputeJacobianFEM. What does it do and why is
>> it
>>              necessary? (especially why does the naming involve SNES?)
>>              Is there another/easier/better way to create a mass
>> matrix (the
>>              inner product of the function space and the test space)?
>>         1) That example needs updating. First, look at SNES ex12 which
>>         is up to
>>         date.
>>         2) I assume you are using 3.6. If you use the development
>>         version, you
>>         can remove DMPlexCopyCoordinates().
>>         3) You need to create the matrix BEFORE calling the assembly
>>         4) Always always always send the entire error messge
>>             Matt
>>              Regards
>>              Julian Andrej
>>         What most experimenters take for granted before they begin
>> their
>>         experiments is infinitely more interesting than any results to
>> which
>>         their experiments lead.
>>         -- Norbert Wiener
>> experiments is infinitely more interesting than any results to which
>> -- Norbert Wiener
Type: text/x-csrc
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160224/88c05a57/attachment-0001.c>
