[petsc-users] Error - Out of memory. This could be due to allocating too large an object or bleeding by not properly ...
TAY wee-beng zonexo at gmail.com
Tue Feb 23 19:50:52 CST 2016
I got this error (also attached, full) when running my code. It happens
after a few thousand time steps.
The strange thing is that for 2 different clusters, it stops at 2
different time steps.
I wonder if it's related to DM since this happens after I added DM into
my code.
In this case, how can I find out the error? I'm thinking valgrind may
take very long and gives too many false errors.
Thank you
Yours sincerely,
TAY wee-beng
* hwloc has encountered what looks like an error from the operating system.
* L3 (cpuset 0x000003f0) intersects with NUMANode (P#0 cpuset 0x0000003f) without inclusion!
* Error occurred in topology.c line 942
* The following FAQ entry in a recent hwloc documentation may help:
*   What should I do when hwloc reports "operating system" warnings?
* Otherwise please report this error message to the hwloc user's mailing list,
* along with the output+tarball generated by the hwloc-gather-topology script.
[35]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[35]PETSC ERROR: Out of memory. This could be due to allocating
[35]PETSC ERROR: too large an object or bleeding by not properly
[35]PETSC ERROR: destroying unneeded objects.
[46]PETSC ERROR: [19]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[19]PETSC ERROR: Out of memory. This could be due to allocating
[19]PETSC ERROR: too large an object or bleeding by not properly
[19]PETSC ERROR: destroying unneeded objects.
[19]PETSC ERROR: Memory allocated 0 Memory used by process 3551756288
[19]PETSC ERROR: Try running with -malloc_dump or -malloc_log for info.
[19]PETSC ERROR: Memory requested 34905645
[19]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[19]PETSC ERROR: Petsc Release Version 3.6.3, Dec, 03, 2015
[32]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[32]PETSC ERROR: Out of memory. This could be due to allocating
[32]PETSC ERROR: too large an object or bleeding by not properly
[32]PETSC ERROR: destroying unneeded objects.
[35]PETSC ERROR: Memory allocated 0 Memory used by process 3522326528
[35]PETSC ERROR: Try running with -malloc_dump or -malloc_log for info.
[35]PETSC ERROR: Memory requested 34905645
[35]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[35]PETSC ERROR: Petsc Release Version 3.6.3, Dec, 03, 2015
[35]PETSC ERROR: ./a.out on a petsc-3.6.3_static_rel named n12-03 by wtay Sun Feb 21 08:24:37 2016
[35]PETSC ERROR: Configure options --with-mpi-dir=/opt/ud/openmpi-1.8.8/ --with-blas-lapack-dir=/opt/ud/intel_xe_2013sp1/mkl/lib/intel64/ --with-debugging=0 --download-hypre=1 --prefix=/home/wtay/Lib/petsc-3.6.3_static_rel --known-mpi-shared=0 --with-shared-libraries=0 --with-fortran-interfaces=1
[35]PETSC ERROR: #1 MatLUFactorNumeric_SeqAIJ_Inode() line 1219 in /home/wtay/Codes/petsc-3.6.3/src/mat/impls/aij/seq/inode.c
[35]PETSC ERROR: #2 MatLUFactorNumeric_SeqAIJ_Inode() line 1219 in /home/wtay/Codes/petsc-3.6.3/src/mat/impls/aij/seq/inode.c
[35]PETSC ERROR: #3 MatLUFactorNumeric() line 2946 in /home/wtay/Codes/petsc-3.6.3/src/mat/interface/matrix.c
[35]PETSC ERROR: #4 PCSetUp_ILU() line 233 in /home/wtay/Codes/petsc-3.6.3/src/ksp/pc/impls/factor/ilu/ilu.c
[35]PETSC ERROR: #5 PCSetUp() line 983 in /home/wtay/Codes/petsc-3.6.3/src/ksp/pc/interface/precon.c
[35]PETSC ERROR: #6 KSPSetUp() line 332 in /home/wtay/Codes/petsc-3.6.3/src/ksp/ksp/interface/itfunc.c
[35]PETSC ERROR: #7 KSPSolve() line 546 in /home/wtay/Codes/petsc-3.6.3/src/ksp/ksp/interface/itfunc.c
[35]PETSC ERROR: #8 PCApply_BJacobi_Singleblock() line 670 in /home/wtay/Codes/petsc-3.6.3/src/ksp/pc/impls/bjacobi/bjacobi.c
[35]PETSC ERROR: #9 PCApply() line 483 in /home/wtay/Codes/petsc-3.6.3/src/ksp/pc/interface/precon.c
[35]PETSC ERROR: #10 KSP_PCApply() line 242 in /home/wtay/Codes/petsc-3.6.3/include/petsc/private/kspimpl.h
[35]PETSC ERROR: #11 KSPInitialResidual() line 63 in /home/wtay/Codes/petsc-3.6.3/src/ksp/ksp/interface/itres.c
[35]PETSC ERROR: #12 KSPSolve_BCGS() line 50 in /home/wtay/Codes/petsc-3.6.3/src/ksp/ksp/impls/bcgs/bcgs.c
[35]PETSC ERROR: #13 KSPSolve() line 604 in /home/wtay/Codes/petsc-3.6.3/src/ksp/ksp/interface/itfunc.c
[46]PETSC ERROR: Out of memory. This could be due to allocating
[46]PETSC ERROR: too large an object or bleeding by not properly
[46]PETSC ERROR: destroying unneeded objects.
[46]PETSC ERROR: Memory allocated 0 Memory used by process 3510972416
[46]PETSC ERROR: Try running with -malloc_dump or -malloc_log for info.
[46]PETSC ERROR: Memory requested 34905645
[46]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[46]PETSC ERROR: Petsc Release Version 3.6.3, Dec, 03, 2015
[46]PETSC ERROR: ./a.out on a petsc-3.6.3_static_rel named n12-03 by wtay Sun Feb 21 08:24:37 2016
[46]PETSC ERROR: Configure options --with-mpi-dir=/opt/ud/openmpi-1.8.8/ --with-blas-lapack-dir=/opt/ud/intel_xe_2013sp1/mkl/lib/intel64/ --with-debugging=0 --download-hypre=1 --prefix=/home/wtay/Lib/petsc-3.6.3_static_rel --known-mpi-shared=0 --with-shared-libraries=0 --with-fortran-interfaces=1
[46]PETSC ERROR: #1 MatLUFactorNumeric_SeqAIJ_Inode() line 1219 in /home/wtay/Codes/petsc-3.6.3/src/mat/impls/aij/seq/inode.c
[46]PETSC ERROR: #2 MatLUFactorNumeric_SeqAIJ_Inode() line 1219 in /home/wtay/Codes/petsc-3.6.3/src/mat/impls/aij/seq/inode.c
[46]PETSC ERROR: #3 MatLUFactorNumeric() line 2946 in /home/wtay/Codes/petsc-3.6.3/src/mat/interface/matrix.c
[46]PETSC ERROR: #4 PCSetUp_ILU() line 233 in /home/wtay/Codes/petsc-3.6.3/src/ksp/pc/impls/factor/ilu/ilu.c
[46]PETSC ERROR: #5 PCSetUp() line 983 in /home/wtay/Codes/petsc-3.6.3/src/ksp/pc/interface/precon.c
[19]PETSC ERROR: ./a.out on a petsc-3.6.3_static_rel named n12-03 by wtay Sun Feb 21 08:24:37 2016
[19]PETSC ERROR: Configure options --with-mpi-dir=/opt/ud/openmpi-1.8.8/ --with-blas-lapack-dir=/opt/ud/intel_xe_2013sp1/mkl/lib/intel64/ --with-debugging=0 --download-hypre=1 --prefix=/home/wtay/Lib/petsc-3.6.3_static_rel --known-mpi-shared=0 --with-shared-libraries=0 --with-fortran-interfaces=1
[19]PETSC ERROR: #1 MatLUFactorNumeric_SeqAIJ_Inode() line 1219 in /home/wtay/Codes/petsc-3.6.3/src/mat/impls/aij/seq/inode.c
[34]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[34]PETSC ERROR: Out of memory. This could be due to allocating
[34]PETSC ERROR: too large an object or bleeding by not properly
[34]PETSC ERROR: destroying unneeded objects.
[19]PETSC ERROR: #2 MatLUFactorNumeric_SeqAIJ_Inode() line 1219 in /home/wtay/Codes/petsc-3.6.3/src/mat/impls/aij/seq/inode.c
[19]PETSC ERROR: #3 MatLUFactorNumeric() line 2946 in /home/wtay/Codes/petsc-3.6.3/src/mat/interface/matrix.c
[19]PETSC ERROR: #4 PCSetUp_ILU() line 233 in /home/wtay/Codes/petsc-3.6.3/src/ksp/pc/impls/factor/ilu/ilu.c
[19]PETSC ERROR: #5 PCSetUp() line 983 in /home/wtay/Codes/petsc-3.6.3/src/ksp/pc/interface/precon.c
[19]PETSC ERROR: #6 KSPSetUp() line 332 in /home/wtay/Codes/petsc-3.6.3/src/ksp/ksp/interface/itfunc.c
[19]PETSC ERROR: #7 KSPSolve() line 546 in /home/wtay/Codes/petsc-3.6.3/src/ksp/ksp/interface/itfunc.c
[19]PETSC ERROR: #8 PCApply_BJacobi_Singleblock() line 670 in /home/wtay/Codes/petsc-3.6.3/src/ksp/pc/impls/bjacobi/bjacobi.c
[19]PETSC ERROR: #9 PCApply() line 483 in /home/wtay/Codes/petsc-3.6.3/src/ksp/pc/interface/precon.c
[19]PETSC ERROR: #10 KSP_PCApply() line 242 in /home/wtay/Codes/petsc-3.6.3/include/petsc/private/kspimpl.h
[19]PETSC ERROR: #11 KSPInitialResidual() line 63 in /home/wtay/Codes/petsc-3.6.3/src/ksp/ksp/interface/itres.c
[19]PETSC ERROR: #12 KSPSolve_BCGS() line 50 in /home/wtay/Codes/petsc-3.6.3/src/ksp/ksp/impls/bcgs/bcgs.c
[19]PETSC ERROR: #13 KSPSolve() line 604 in /home/wtay/Codes/petsc-3.6.3/src/ksp/ksp/interface/itfunc.c
[32]PETSC ERROR: Memory allocated 0 Memory used by process 3514494976
[32]PETSC ERROR: Try running with -malloc_dump or -malloc_log for info.
[32]PETSC ERROR: Memory requested 34905645
[32]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[32]PETSC ERROR: Petsc Release Version 3.6.3, Dec, 03, 2015
[32]PETSC ERROR: ./a.out on a petsc-3.6.3_static_rel named n12-03 by wtay Sun Feb 21 08:24:37 2016
[32]PETSC ERROR: Configure options --with-mpi-dir=/opt/ud/openmpi-1.8.8/ --with-blas-lapack-dir=/opt/ud/intel_xe_2013sp1/mkl/lib/intel64/ --with-debugging=0 --download-hypre=1 --prefix=/home/wtay/Lib/petsc-3.6.3_static_rel --known-mpi-shared=0 --with-shared-libraries=0 --with-fortran-interfaces=1
[32]PETSC ERROR: #1 MatLUFactorNumeric_SeqAIJ_Inode() line 1219 in /home/wtay/Codes/petsc-3.6.3/src/mat/impls/aij/seq/inode.c
[32]PETSC ERROR: #2 MatLUFactorNumeric_SeqAIJ_Inode() line 1219 in /home/wtay/Codes/petsc-3.6.3/src/mat/impls/aij/seq/inode.c
[32]PETSC ERROR: #3 MatLUFactorNumeric() line 2946 in /home/wtay/Codes/petsc-3.6.3/src/mat/interface/matrix.c
[32]PETSC ERROR: #4 PCSetUp_ILU() line 233 in /home/wtay/Codes/petsc-3.6.3/src/ksp/pc/impls/factor/ilu/ilu.c
[32]PETSC ERROR: #5 PCSetUp() line 983 in /home/wtay/Codes/petsc-3.6.3/src/ksp/pc/interface/precon.c
[32]PETSC ERROR: #6 KSPSetUp() line 332 in /home/wtay/Codes/petsc-3.6.3/src/ksp/ksp/interface/itfunc.c
[32]PETSC ERROR: #7 KSPSolve() line 546 in /home/wtay/Codes/petsc-3.6.3/src/ksp/ksp/interface/itfunc.c
[32]PETSC ERROR: #8 PCApply_BJacobi_Singleblock() line 670 in /home/wtay/Codes/petsc-3.6.3/src/ksp/pc/impls/bjacobi/bjacobi.c
[32]PETSC ERROR: #9 PCApply() line 483 in /home/wtay/Codes/petsc-3.6.3/src/ksp/pc/interface/precon.c
[32]PETSC ERROR: #10 KSP_PCApply() line 242 in /home/wtay/Codes/petsc-3.6.3/include/petsc/private/kspimpl.h
[32]PETSC ERROR: #11 KSPInitialResidual() line 63 in /home/wtay/Codes/petsc-3.6.3/src/ksp/ksp/interface/itres.c
[32]PETSC ERROR: #12 KSPSolve_BCGS() line 50 in /home/wtay/Codes/petsc-3.6.3/src/ksp/ksp/impls/bcgs/bcgs.c
[32]PETSC ERROR: #13 KSPSolve() line 604 in /home/wtay/Codes/petsc-3.6.3/src/ksp/ksp/interface/itfunc.c
[34]PETSC ERROR: Memory allocated 0 Memory used by process 3541282816
[34]PETSC ERROR: Try running with -malloc_dump or -malloc_log for info.
[34]PETSC ERROR: Memory requested 34905645
[34]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[34]PETSC ERROR: Petsc Release Version 3.6.3, Dec, 03, 2015
[34]PETSC ERROR: ./a.out on a petsc-3.6.3_static_rel named n12-03 by wtay Sun Feb 21 08:24:37 2016
[34]PETSC ERROR: Configure options --with-mpi-dir=/opt/ud/openmpi-1.8.8/ --with-blas-lapack-dir=/opt/ud/intel_xe_2013sp1/mkl/lib/intel64/ --with-debugging=0 --download-hypre=1 --prefix=/home/wtay/Lib/petsc-3.6.3_static_rel --known-mpi-shared=0 --with-shared-libraries=0 --with-fortran-interfaces=1
[34]PETSC ERROR: #1 MatLUFactorNumeric_SeqAIJ_Inode() line 1219 in /home/wtay/Codes/petsc-3.6.3/src/mat/impls/aij/seq/inode.c
[34]PETSC ERROR: #2 MatLUFactorNumeric_SeqAIJ_Inode() line 1219 in /home/wtay/Codes/petsc-3.6.3/src/mat/impls/aij/seq/inode.c
[34]PETSC ERROR: #3 MatLUFactorNumeric() line 2946 in /home/wtay/Codes/petsc-3.6.3/src/mat/interface/matrix.c
[34]PETSC ERROR: #4 PCSetUp_ILU() line 233 in /home/wtay/Codes/petsc-3.6.3/src/ksp/pc/impls/factor/ilu/ilu.c
[34]PETSC ERROR: #5 PCSetUp() line 983 in /home/wtay/Codes/petsc-3.6.3/src/ksp/pc/interface/precon.c
[34]PETSC ERROR: #6 KSPSetUp() line 332 in /home/wtay/Codes/petsc-3.6.3/src/ksp/ksp/interface/itfunc.c
[34]PETSC ERROR: #7 KSPSolve() line 546 in /home/wtay/Codes/petsc-3.6.3/src/ksp/ksp/interface/itfunc.c
[34]PETSC ERROR: #8 PCApply_BJacobi_Singleblock() line 670 in /home/wtay/Codes/petsc-3.6.3/src/ksp/pc/impls/bjacobi/bjacobi.c
[34]PETSC ERROR: #9 PCApply() line 483 in /home/wtay/Codes/petsc-3.6.3/src/ksp/pc/interface/precon.c
[34]PETSC ERROR: #10 KSP_PCApply() line 242 in /home/wtay/Codes/petsc-3.6.3/include/petsc/private/kspimpl.h
[34]PETSC ERROR: #11 KSPInitialResidual() line 63 in /home/wtay/Codes/petsc-3.6.3/src/ksp/ksp/interface/itres.c
[34]PETSC ERROR: #12 KSPSolve_BCGS() line 50 in /home/wtay/Codes/petsc-3.6.3/src/ksp/ksp/impls/bcgs/bcgs.c
[34]PETSC ERROR: #13 KSPSolve() line 604 in /home/wtay/Codes/petsc-3.6.3/src/ksp/ksp/interface/itfunc.c
[46]PETSC ERROR: [33]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[33]PETSC ERROR: Out of memory. This could be due to allocating
[33]PETSC ERROR: too large an object or bleeding by not properly
[33]PETSC ERROR: destroying unneeded objects.
[33]PETSC ERROR: Memory allocated 0 Memory used by process 3514351616
[33]PETSC ERROR: Try running with -malloc_dump or -malloc_log for info.
[33]PETSC ERROR: Memory requested 34905645
[33]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[33]PETSC ERROR: Petsc Release Version 3.6.3, Dec, 03, 2015
[33]PETSC ERROR: ./a.out on a petsc-3.6.3_static_rel named n12-03 by wtay Sun Feb 21 08:24:37 2016
[33]PETSC ERROR: Configure options --with-mpi-dir=/opt/ud/openmpi-1.8.8/ --with-blas-lapack-dir=/opt/ud/intel_xe_2013sp1/mkl/lib/intel64/ --with-debugging=0 --download-hypre=1 --prefix=/home/wtay/Lib/petsc-3.6.3_static_rel --known-mpi-shared=0 --with-shared-libraries=0 --with-fortran-interfaces=1
[33]PETSC ERROR: #1 MatLUFactorNumeric_SeqAIJ_Inode() line 1219 in /home/wtay/Codes/petsc-3.6.3/src/mat/impls/aij/seq/inode.c
[33]PETSC ERROR: #2 MatLUFactorNumeric_SeqAIJ_Inode() line 1219 in /home/wtay/Codes/petsc-3.6.3/src/mat/impls/aij/seq/inode.c
[33]PETSC ERROR: #3 MatLUFactorNumeric() line 2946 in /home/wtay/Codes/petsc-3.6.3/src/mat/interface/matrix.c
[33]PETSC ERROR: #4 PCSetUp_ILU() line 233 in /home/wtay/Codes/petsc-3.6.3/src/ksp/pc/impls/factor/ilu/ilu.c
[33]PETSC ERROR: #5 PCSetUp() line 983 in /home/wtay/Codes/petsc-3.6.3/src/ksp/pc/interface/precon.c
[33]PETSC ERROR: #6 KSPSetUp() line 332 in /home/wtay/Codes/petsc-3.6.3/src/ksp/ksp/interface/itfunc.c
[33]PETSC ERROR: #7 KSPSolve() line 546 in /home/wtay/Codes/petsc-3.6.3/src/ksp/ksp/interface/itfunc.c
[33]PETSC ERROR: #8 PCApply_BJacobi_Singleblock() line 670 in /home/wtay/Codes/petsc-3.6.3/src/ksp/pc/impls/bjacobi/bjacobi.c
[33]PETSC ERROR: #9 PCApply() line 483 in /home/wtay/Codes/petsc-3.6.3/src/ksp/pc/interface/precon.c
[33]PETSC ERROR: #10 KSP_PCApply() line 242 in /home/wtay/Codes/petsc-3.6.3/include/petsc/private/kspimpl.h
[33]PETSC ERROR: #11 KSPInitialResidual() line 63 in /home/wtay/Codes/petsc-3.6.3/src/ksp/ksp/interface/itres.c
[33]PETSC ERROR: #12 KSPSolve_BCGS() line 50 in /home/wtay/Codes/petsc-3.6.3/src/ksp/ksp/impls/bcgs/bcgs.c
[33]PETSC ERROR: #13 KSPSolve() line 604 in /home/wtay/Codes/petsc-3.6.3/src/ksp/ksp/interface/itfunc.c
[46]PETSC ERROR: #7 KSPSolve() line 546 in /home/wtay/Codes/petsc-3.6.3/src/ksp/ksp/interface/itfunc.c
[46]PETSC ERROR: #8 PCApply_BJacobi_Singleblock() line 670 in /home/wtay/Codes/petsc-3.6.3/src/ksp/pc/impls/bjacobi/bjacobi.c
[46]PETSC ERROR: #9 PCApply() line 483 in /home/wtay/Codes/petsc-3.6.3/src/ksp/pc/interface/precon.c
[46]PETSC ERROR: #10 KSP_PCApply() line 242 in /home/wtay/Codes/petsc-3.6.3/include/petsc/private/kspimpl.h
[46]PETSC ERROR: #11 KSPInitialResidual() line 63 in /home/wtay/Codes/petsc-3.6.3/src/ksp/ksp/interface/itres.c
[46]PETSC ERROR: #12 KSPSolve_BCGS() line 50 in /home/wtay/Codes/petsc-3.6.3/src/ksp/ksp/impls/bcgs/bcgs.c
[46]PETSC ERROR: #13 KSPSolve() line 604 in /home/wtay/Codes/petsc-3.6.3/src/ksp/ksp/interface/itfunc.c
[16]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[16]PETSC ERROR: Out of memory. This could be due to allocating
[12]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[12]PETSC ERROR: Out of memory. This could be due to allocating
[12]PETSC ERROR: too large an object or bleeding by not properly
[12]PETSC ERROR: destroying unneeded objects.
[12]PETSC ERROR: Memory allocated 0 Memory used by process 3533832192
[12]PETSC ERROR: Try running with -malloc_dump or -malloc_log for info.
[12]PETSC ERROR: Memory requested 4363204
[12]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[12]PETSC ERROR: Petsc Release Version 3.6.3, Dec, 03, 2015
[12]PETSC ERROR: ./a.out on a petsc-3.6.3_static_rel named n12-03 by wtay Sun Feb 21 08:24:37 2016
[12]PETSC ERROR: Configure options --with-mpi-dir=/opt/ud/openmpi-1.8.8/ --with-blas-lapack-dir=/opt/ud/intel_xe_2013sp1/mkl/lib/intel64/ --with-debugging=0 --download-hypre=1 --prefix=/home/wtay/Lib/petsc-3.6.3_static_rel --known-mpi-shared=0 --with-shared-libraries=0 --with-fortran-interfaces=1
[12]PETSC ERROR: #1 MatLUFactorNumeric_SeqAIJ_Inode() line 1228 in /home/wtay/Codes/petsc-3.6.3/src/mat/impls/aij/seq/inode.c
[12]PETSC ERROR: #2 MatLUFactorNumeric_SeqAIJ_Inode() line 1228 in /home/wtay/Codes/petsc-3.6.3/src/mat/impls/aij/seq/inode.c
[12]PETSC ERROR: #3 MatLUFactorNumeric() line 2946 in /home/wtay/Codes/petsc-3.6.3/src/mat/interface/matrix.c
[12]PETSC ERROR: #4 PCSetUp_ILU() line 233 in /home/wtay/Codes/petsc-3.6.3/src/ksp/pc/impls/factor/ilu/ilu.c
[12]PETSC ERROR: #5 PCSetUp() line 983 in /home/wtay/Codes/petsc-3.6.3/src/ksp/pc/interface/precon.c
[12]PETSC ERROR: #6 KSPSetUp() line 332 in /home/wtay/Codes/petsc-3.6.3/src/ksp/ksp/interface/itfunc.c
[12]PETSC ERROR: #7 KSPSolve() line 546 in /home/wtay/Codes/petsc-3.6.3/src/ksp/ksp/interface/itfunc.c
[12]PETSC ERROR: #8 PCApply_BJacobi_Singleblock() line 670 in /home/wtay/Codes/petsc-3.6.3/src/ksp/pc/impls/bjacobi/bjacobi.c
[12]PETSC ERROR: #9 PCApply() line 483 in /home/wtay/Codes/petsc-3.6.3/src/ksp/pc/interface/precon.c
[12]PETSC ERROR: #10 KSP_PCApply() line 242 in /home/wtay/Codes/petsc-3.6.3/include/petsc/private/kspimpl.h
[12]PETSC ERROR: #11 KSPInitialResidual() line 63 in /home/wtay/Codes/petsc-3.6.3/src/ksp/ksp/interface/itres.c
[12]PETSC ERROR: #12 KSPSolve_BCGS() line 50 in /home/wtay/Codes/petsc-3.6.3/src/ksp/ksp/impls/bcgs/bcgs.c
[12]PETSC ERROR: #13 KSPSolve() line 604 in /home/wtay/Codes/petsc-3.6.3/src/ksp/ksp/interface/itfunc.c
[16]PETSC ERROR: too large an object or bleeding by not properly
[16]PETSC ERROR: destroying unneeded objects.
[16]PETSC ERROR: Memory allocated 0 Memory used by process 3527131136
[16]PETSC ERROR: Try running with -malloc_dump or -malloc_log for info.
[16]PETSC ERROR: Memory requested 4363204
[16]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[16]PETSC ERROR: Petsc Release Version 3.6.3, Dec, 03, 2015
[16]PETSC ERROR: ./a.out on a petsc-3.6.3_static_rel named n12-03 by wtay Sun Feb 21 08:24:37 2016
[16]PETSC ERROR: Configure options --with-mpi-dir=/opt/ud/openmpi-1.8.8/ --with-blas-lapack-dir=/opt/ud/intel_xe_2013sp1/mkl/lib/intel64/ --with-debugging=0 --download-hypre=1 --prefix=/home/wtay/Lib/petsc-3.6.3_static_rel --known-mpi-shared=0 --with-shared-libraries=0 --with-fortran-interfaces=1
[16]PETSC ERROR: #1 MatLUFactorNumeric_SeqAIJ_Inode() line 1228 in /home/wtay/Codes/petsc-3.6.3/src/mat/impls/aij/seq/inode.c
[16]PETSC ERROR: #2 MatLUFactorNumeric_SeqAIJ_Inode() line 1228 in /home/wtay/Codes/petsc-3.6.3/src/mat/impls/aij/seq/inode.c
[16]PETSC ERROR: #3 MatLUFactorNumeric() line 2946 in /home/wtay/Codes/petsc-3.6.3/src/mat/interface/matrix.c
[16]PETSC ERROR: #4 PCSetUp_ILU() line 233 in /home/wtay/Codes/petsc-3.6.3/src/ksp/pc/impls/factor/ilu/ilu.c
[16]PETSC ERROR: #5 PCSetUp() line 983 in /home/wtay/Codes/petsc-3.6.3/src/ksp/pc/interface/precon.c
[16]PETSC ERROR: #6 KSPSetUp() line 332 in /home/wtay/Codes/petsc-3.6.3/src/ksp/ksp/interface/itfunc.c
[16]PETSC ERROR: #7 KSPSolve() line 546 in /home/wtay/Codes/petsc-3.6.3/src/ksp/ksp/interface/itfunc.c
[16]PETSC ERROR: #8 PCApply_BJacobi_Singleblock() line 670 in /home/wtay/Codes/petsc-3.6.3/src/ksp/pc/impls/bjacobi/bjacobi.c
[16]PETSC ERROR: #9 PCApply() line 483 in /home/wtay/Codes/petsc-3.6.3/src/ksp/pc/interface/precon.c
[16]PETSC ERROR: #10 KSP_PCApply() line 242 in /home/wtay/Codes/petsc-3.6.3/include/petsc/private/kspimpl.h
[16]PETSC ERROR: #11 KSPInitialResidual() line 63 in /home/wtay/Codes/petsc-3.6.3/src/ksp/ksp/interface/itres.c
[16]PETSC ERROR: #12 KSPSolve_BCGS() line 50 in /home/wtay/Codes/petsc-3.6.3/src/ksp/ksp/impls/bcgs/bcgs.c
[16]PETSC ERROR: #13 KSPSolve() line 604 in /home/wtay/Codes/petsc-3.6.3/src/ksp/ksp/interface/itfunc.c
mpiexec: abort is already in progress...hit ctrl-c again to forcibly terminate
  0.000000000000000E+000  0.710000000000000       0.000000000000000E+000
   90.0000000000000       0.000000000000000E+000 -0.350000000000000
   1.00000000000000       0.200000000000000                0     -400000
 AB,AA,BB,CC   -3.13300005381461        3.47950007027248
   3.69050008029444        3.79850008542417
 size_x,size_y,size_z          202         300         577
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end           0           1          50
           1          37           1      373700
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end           1          51         100
           1          37      373701      747400
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end           2         101         150
           1          37      747401     1121100
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end           3         151         200
           1          37     1121101     1494800
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end           4         201         250
           1          37     1494801     1868500
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end           5         251         300
           1          37     1868501     2242200
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end           6           1          50
          38          73     2242201     2605800
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end           7          51         100
          38          73     2605801     2969400
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end           8         101         150
          38          73     2969401     3333000
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end           9         151         200
          38          73     3333001     3696600
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          10         201         250
          38          73     3696601     4060200
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          11         251         300
          38          73     4060201     4423800
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          12           1          50
          74         109     4423801     4787400
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          13          51         100
          74         109     4787401     5151000
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          14         101         150
          74         109     5151001     5514600
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          15         151         200
          74         109     5514601     5878200
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          16         201         250
          74         109     5878201     6241800
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          17         251         300
          74         109     6241801     6605400
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          18           1          50
         110         145     6605401     6969000
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          19          51         100
         110         145     6969001     7332600
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          20         101         150
         110         145     7332601     7696200
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          21         151         200
         110         145     7696201     8059800
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          22         201         250
         110         145     8059801     8423400
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          23         251         300
         110         145     8423401     8787000
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          24           1          50
         146         181     8787001     9150600
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          25          51         100
         146         181     9150601     9514200
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          26         101         150
         146         181     9514201     9877800
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          27         151         200
         146         181     9877801    10241400
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          28         201         250
         146         181    10241401    10605000
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          29         251         300
         146         181    10605001    10968600
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          30           1          50
         182         217    10968601    11332200
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          31          51         100
         182         217    11332201    11695800
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          32         101         150
         182         217    11695801    12059400
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          33         151         200
         182         217    12059401    12423000
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          34         201         250
         182         217    12423001    12786600
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          35         251         300
         182         217    12786601    13150200
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          36           1          50
         218         253    13150201    13513800
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          37          51         100
         218         253    13513801    13877400
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          38         101         150
         218         253    13877401    14241000
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          39         151         200
         218         253    14241001    14604600
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          40         201         250
         218         253    14604601    14968200
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          41         251         300
         218         253    14968201    15331800
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          42           1          50
         254         289    15331801    15695400
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          43          51         100
         254         289    15695401    16059000
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          44         101         150
         254         289    16059001    16422600
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          45         151         200
         254         289    16422601    16786200
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          46         201         250
         254         289    16786201    17149800
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          47         251         300
         254         289    17149801    17513400
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          48           1          50
         290         325    17513401    17877000
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          49          51         100
         290         325    17877001    18240600
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          50         101         150
         290         325    18240601    18604200
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          51         151         200
         290         325    18604201    18967800
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          52         201         250
         290         325    18967801    19331400
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          53         251         300
         290         325    19331401    19695000
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          54           1          50
         326         361    19695001    20058600
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          55          51         100
         326         361    20058601    20422200
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          56         101         150
         326         361    20422201    20785800
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          57         151         200
         326         361    20785801    21149400
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          58         201         250
         326         361    21149401    21513000
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          59         251         300
         326         361    21513001    21876600
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          60           1          50
         362         397    21876601    22240200
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          61          51         100
         362         397    22240201    22603800
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          62         101         150
         362         397    22603801    22967400
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          63         151         200
         362         397    22967401    23331000
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          64         201         250
         362         397    23331001    23694600
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          65         251         300
         362         397    23694601    24058200
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          66           1          50
         398         433    24058201    24421800
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          67          51         100
         398         433    24421801    24785400
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          68         101         150
         398         433    24785401    25149000
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          69         151         200
         398         433    25149001    25512600
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          70         201         250
         398         433    25512601    25876200
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          71         251         300
         398         433    25876201    26239800
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          72           1          50
         434         469    26239801    26603400
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          73          51         100
         434         469    26603401    26967000
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          74         101         150
         434         469    26967001    27330600
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          75         151         200
         434         469    27330601    27694200
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          76         201         250
         434         469    27694201    28057800
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          77         251         300
         434         469    28057801    28421400
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          78           1          50
         470         505    28421401    28785000
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          79          51         100
         470         505    28785001    29148600
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          80         101         150
         470         505    29148601    29512200
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          81         151         200
         470         505    29512201    29875800
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          82         201         250
         470         505    29875801    30239400
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          83         251         300
         470         505    30239401    30603000
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          84           1          50
         506         541    30603001    30966600
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          85          51         100
         506         541    30966601    31330200
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          86         101         150
         506         541    31330201    31693800
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          87         151         200
         506         541    31693801    32057400
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          88         201         250
         506         541    32057401    32421000
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          89         251         300
         506         541    32421001    32784600
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          90           1          50
         542         577    32784601    33148200
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          91          51         100
         542         577    33148201    33511800
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          92         101         150
         542         577    33511801    33875400
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          93         151         200
         542         577    33875401    34239000
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          94         201         250
         542         577    34239001    34602600
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end          95         251         300
         542         577    34602601    34966200
 body_cg_ini  9.999999999255602E-007  1.710991388089775E-003
   10.2254852004451
         672  surfaces with correct vertex ordering
 Warning - length difference between element and cell
 max_element_length,min_element_length,min_delta
  0.297282883542864       5.747832995728071E-002  1.800000000000000E-002
 maximum ngh_surfaces and ngh_vertics are            1           1
 minimum ngh_surfaces and ngh_vertics are            1           1
 body_cg_ini -9.199712417665717E-004  0.891121393810939
   6.75773429502958
        1776  surfaces with correct vertex ordering
  0.294864814733624       1.648655999999882E-002  1.800000000000000E-002
 maximum ngh_surfaces and ngh_vertics are            1           2
 min IIB_cell_no           0
 max IIB_cell_no        1237
 final initial IIB_cell_no       61850
 min I_cell_no           0
 max I_cell_no        4428
 final initial I_cell_no      221400
 size(IIB_cell_u),size(I_cell_u),size(IIB_equal_cell_u),size(I_equal_cell_u)
       61850      221400       61850      221400
 min IIB_cell_no           0
 max IIB_cell_no        1350
 final initial IIB_cell_no       67500
 min I_cell_no           0
 max I_cell_no       22199
 final initial I_cell_no     1109950
       67500     1109950       67500     1109950
 IIB_I_cell_no_uvw_total1       18956       18602       18748       57477
       49290       49710
 IIB_I_cell_no_uvw_total2       37851       37876       38095      500842
      504527      506410
 1500      0.00021825      9.98988642     10.43276011      8.24268002  0.64333010E+06  0.41880252E+04  0.34216012E+08
 1800      0.00023513     10.68688767      9.49082300      8.14022395  0.47192748E+06  0.37796673E+04  0.34397558E+08
 2100      0.00023612     11.14050288      9.53122678      8.10449896  0.24054404E+06  0.22516421E+04  0.34588837E+08
ORTE has lost communication with its daemon located on node:
  hostname:  n12-09
This is usually due to either a failure of the TCP network
connection to the node, or possibly an internal failure of
the daemon itself. We cannot recover from this failure, and
therefore will terminate the job.
