[petsc-users] Difference between Block Jacobi and ILU?
Justin Chang jychang48 at gmail.com
Tue Feb 23 14:03:05 CST 2016
Two more questions, somewhat related maybe.
Is there a practical case where one would use plain Jacobi preconditioning
over ILU?
Also, what exactly is happening when one uses -pc_bjacobi_blocks 2 ?
Justin
On Wed, Jan 13, 2016 at 9:37 PM, Justin Chang <jychang48 at gmail.com> wrote:
> Thanks Satish,
> And yes I meant sequentially.
> On Wed, Jan 13, 2016 at 8:26 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>> On Wed, 13 Jan 2016, Justin Chang wrote:
>> > Hi all,
>> > What exactly is the difference between these two preconditioners? When I
>> > use them to solve a Galerkin finite element poisson problem, I get the
>> > exact same performance (iterations, wall-clock time, etc).
>> you mean - when you run sequentially?
>> With block jacobi - you decide the number of blocks. The default is
>> 1-block/proc
>> i.e - for sequnetial run you have only 1block i.e  the whole matrix.
>> So the following are essentially the same:
>> -pc_type bjacobi -pc_bjacobi_blocks 1 [default] -sub_pc_type ilu [default]
>> -pc_type ilu
>> Satish
>> > Only thing is I can't seem to use ILU in parallel though.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160223/8185d7e1/attachment.html>
