[petsc-users] Weighted Jacobi, and scaling 2nd matrix in KSPSetOperators
Timothée Nicolas timothee.nicolas at gmail.com
Mon Feb 22 16:38:55 CST 2016
Yes, exactly. I'm really sorry, I just sent the e-mail without thinking
enough... My bad.
Thanks
2016-02-22 15:28 GMT-07:00 Dave May <dave.mayhem23 at gmail.com>:
> On 22 February 2016 at 23:16, Timothée Nicolas <timothee.nicolas at gmail.com
> > wrote:
>> Hi all,
>> It sounds it should be obvious but I can't find it somehow. I would like
>> to use weighted jacobi (more precisely point block jacobi) as a smoother
>> for multigrid, but I don't find the options to set a weight omega, after I
>> set -mg_levels_pc_type pbjacobi
> Why not use  -ksp_type richardson -ksp_richardson_scale XXX ?
> Cheers,
>   Dave
> So I was thinking I could just artificially scale the second matrix in
>> KSPSetOperators with a weight omega. Since it is the one used in retrieving
>> the diagonal, it should be equivalent to have a weight and should not
>> affect the residuals, right ? However, I notice no change of behaviour
>> whatsoever when I do this.
>> Is it normal ? Have I grossly misunderstood something ?
>> Thanks
>> Timothee
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160222/b08675ed/attachment.html>
