[petsc-users] Weighted Jacobi, and scaling 2nd matrix in KSPSetOperators
Timothée Nicolas timothee.nicolas at gmail.com
Mon Feb 22 16:16:41 CST 2016
Hi all,
It sounds it should be obvious but I can't find it somehow. I would like to
use weighted jacobi (more precisely point block jacobi) as a smoother for
multigrid, but I don't find the options to set a weight omega, after I set
-mg_levels_pc_type pbjacobi  So I was thinking I could just artificially
scale the second matrix in KSPSetOperators with a weight omega. Since it is
the one used in retrieving the diagonal, it should be equivalent to have a
weight and should not affect the residuals, right ? However, I notice no
change of behaviour whatsoever when I do this.
Is it normal ? Have I grossly misunderstood something ?
Thanks
Timothee
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160222/650e5646/attachment.html>
