[petsc-users] Doubt in MPIPreallocation
John Albequerque johncfdcfd at gmail.com
Fri Feb 19 15:31:42 CST 2016
Barry,
I have let PETSc decide the local sizes I have only specified the global
values, I will also check with the debugger and tell you the status.
And just another query,is it a problem if I have already used *MatSetUp(A);
*once and after that assembled the matrix and after that applying
Preallocation. I guess that should not be a problem as the code ran fine
with the one processor case. Just confirming though.
Many thanks.
John Albequerque.
On Sat, Feb 20, 2016 at 2:53 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   Are you sure you have divided up the matrix so each process gets some of
> the rows?
>   You are just going to have to break down and run with -start_in_debugger
> to see exactly why it is crashing.
>   Barry
> > On Feb 19, 2016, at 3:16 PM, John Albequerque <johncfdcfd at gmail.com>
> wrote:
> > Barry,
> > I forgot to mention that the code is working fine with a single
> processor, but when I increase the number of processors, as in this case 3
> processors have been used when the error message was generated. And yes, it
> has something to do with the off-diagonal terms as I am increasing the
> number of processes, the same error triggers for each row for which
> o_nnz[i] is not zero.
> > Many thanks.
> > John Albequerque.
> > On Sat, Feb 20, 2016 at 2:38 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> >   You are setting nonzero preallocations for the "off diagonal" portion
> of the matrix, but one one process there is no off diagonal portion so you
> should be setting those values to all zero.
> >   Barry
> > > On Feb 19, 2016, at 2:29 PM, John Albequerque <johncfdcfd at gmail.com>
> wrote:
> > > Dear Barry,
> > > I am sorry I could not get you. I have also posted the entire error
> message so that you could get a deeper insight into it.
> > > Many thanks.
> > > John Albequerque.
> > > Argument out of range
> > > [0]PETSC ERROR: nnz cannot be greater than row length: local row 0
> value 1 rowlength 0
> > > [0]PETSC ERROR: See
> http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
> > > [0]PETSC ERROR: Petsc Release Version 3.6.3, unknown
> > > [0]PETSC ERROR: ./MatSparse on a linux-gnu-c-debug named John by
> johncfd Sat Feb 20 01:36:01 2016
> > > [0]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++
> --with-fc=gfortran --download-fblaslapack --download-mpich
> > > [0]PETSC ERROR: #1 MatSeqAIJSetPreallocation_SeqAIJ() line 3567 in
> /home//MyStuff/ClonedRepos/petsc/src/mat/impls/aij/seq/aij.c
> > > [0]PETSC ERROR: #2 MatSeqAIJSetPreallocation() line 3539 in
> /home/MyStuff/ClonedRepos/petsc/src/mat/impls/aij/seq/aij.c
> > > [0]PETSC ERROR: #3 MatMPIAIJSetPreallocation_MPIAIJ() line 2835 in
> /home/MyStuff/ClonedRepos/petsc/src/mat/impls/aij/mpi/mpiaij.c
> > > [0]PETSC ERROR: #4 MatMPIAIJSetPreallocation() line 3532 in
> > > On Sat, Feb 20, 2016 at 12:35 AM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
> > > > On Feb 19, 2016, at 12:54 PM, John Albequerque <johncfdcfd at gmail.com>
> wrote:
> > > > Jed, one more
> > > > nnz cannot be greater than row length: local row 0 value 1 rowlength
> 0
> > >   Always send the entire error message, this provides the context to
> know what the hey is going on.
> > >   It looks like you set a matrix block (if you are using an MPI matrix
> on one process this could the the "off-diagonal" block)  which has no
> columns (hence row length is zero) but you claim you need to preallocate an
> entry (the 1).
> > >   Barry
> > > > How do I deal with this error?
> > > > Thanks.
> > > > John Albequerque.
> > > > On Fri, Feb 19, 2016 at 8:17 PM, John Albequerque <
> johncfdcfd at gmail.com> wrote:
> > > > Thank you very much, I will try it.
> > > > Thanks
> > > > John Albequerque.
> > > > On Fri, Feb 19, 2016 at 8:16 PM, Jed Brown <jed at jedbrown.org> wrote:
> > > > John Albequerque <johncfdcfd at gmail.com> writes:
> > > > > So Jed, what you are suggesting is that I should set only the
> non-zero
> > > > > elements while using
> > > > > *  MatSetValues(A,(high-low),**idxm,nc,idxn,values,INSERT_*
> > > > > *VALUES);*
> > > > > And not mention the zero elements and for that I should loop over
> all local
> > > > > rows and then set each of the value.
> > > > Yes.  The whole point of a sparse matrix is to spend no time or
> storage
> > > > on 0.0 entries.  If you allocate a dense matrix and store all the
> zeros,
> > > > you're just being inefficient relative to a dense format.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160220/333b7f57/attachment-0001.html>
