[petsc-users] Slow MatAssembly and MatMat Mult
Bikash Kanungo bikash at umich.edu
Wed Feb 17 21:17:55 CST 2016
Hi Barry,
I had thought of using sub-communicator for these operations. But the
matrix entries have contributions from all the processors. Moreover, after
the MatMatMult operation is done, I need to retrieve certain values from
the resultant matrix through non-local calls (MatGetSubMatrices) on all
processors. Defining these matrices to be residing on sub-communicator will
prohibit me from adding contributions and calling MatGetSubMatrices from
processors not within the sub-communicator. What would be a good workaround
for it?
Bikash
On Wed, Feb 17, 2016 at 9:33 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   This is an absolutely tiny problem for 480 processors I am not surprised
> by the terrible performance. You should run this sub calculation on a small
> subset of the processes.
>   Barry
> > On Feb 17, 2016, at 7:03 PM, Bikash Kanungo <bikash at umich.edu> wrote:
> > Hi,
> > I have two small (2500x2500) matrices parallelized across 480
> processors. One of them is an MPIAIJ matrix while the other is an MPIDENSE
> matrix. I perform a MatMatMult involving these two matrices. I tried these
> operations on two machines, one is the local cluster at University of
> Michigan and the other is the XSEDE Comet machine. The Comet machine takes
> 10-20 times more time in steps involving MatAssembly and MatMatMult of the
> aforementioned matrices. I have other Petsc MatMult operations in the same
> code involving larger matrices (4 million x 4 million) which show similar
> timing on both machines. It's just those small parallel matrices that are
> inconsistent in terms of their timings. I used same the compilers and MPI
> libraries in both the machines except that I have suppressed "avx2" flag in
> Comet. I believe avx2 affects floating point operations and not
> communication. I would like to know what might be causing these
> inconsistencies only in case of the small matrices. Are there any network
> settings that I can look into and compare?
> > Regards,
> > Bikash
> > Bikash S. Kanungo
> > PhD Student
> > Computational Materials Physics Group
> > Mechanical Engineering
> > University of Michigan
Bikash S. Kanungo
PhD Student
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160217/0c667f01/attachment.html>
