[petsc-users] memory scalable AO
Randall Mackie rlmackie862 at gmail.com
Wed Feb 17 15:46:58 CST 2016
The attached test program demonstrates the problem. When I run it, I get the following output:
[0]PETSC ERROR: ------------------------------------------------------------------------
[0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
[0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
[0]PETSC ERROR: likely location of problem given in stack below
[0]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
[0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[0]PETSC ERROR:       INSTEAD the line number of the start of the function
[0]PETSC ERROR:       is given.
[0]PETSC ERROR: [0] PetscStrlen line 150 /home/rmackie/PETSc/petsc-3.6.3/src/sys/utils/str.c
[0]PETSC ERROR: [0] PetscStrallocpy line 185 /home/rmackie/PETSc/petsc-3.6.3/src/sys/utils/str.c
[0]PETSC ERROR: [0] DMDASetAOType line 84 /home/rmackie/PETSc/petsc-3.6.3/src/dm/impls/da/daindex.c
[0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[0]PETSC ERROR: Signal received
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
Randy
> On Feb 17, 2016, at 11:35 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>  Should be ok. Do you have implicit none and the correct include files so AOMEMORYSCALABLE is defined?
>  I think you need to run in the debugger next to track why this happens.
>   Barry
>> On Feb 17, 2016, at 11:33 AM, Randall Mackie <rlmackie862 at gmail.com> wrote:
>> What is the correct way to set the AO for a DMDA to be the memory scalable version?
>> I have tried this:
>> call DMDASetAOType(da,AOMEMORYSCALABLE,ierr)
>> call DMDAGetAO(da,ao,ierr)
>> The code compiles fine, but I simply get a Segmentation Violation when I run it:
>> [3]PETSC ERROR: ------------------------------------------------------------------------
>> [3]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
>> [3]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
>> [3]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
>> [3]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
>> [3]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and run
>> [3]PETSC ERROR: to get more information on the crash.
>> [3]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
>> [3]PETSC ERROR: Signal received
>> [3]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
>> [3]PETSC ERROR: Petsc Release Version 3.6.3, Dec, 03, 2015
>> [3]PETSC ERROR: Configure options PETSC_ARCH=linux-gfortran-opt --with-clean=1 --with-scalar-type=complex --with-debugging=0 --with-fortran=1 --download-mpich=./mpich-3.1.3.tar.gz --FOPTFLAGS=-O3 --COPTFLAGS=-O3
>> [3]PETSC ERROR: #1 User provided function() line 0 in  unknown file
>> application called MPI_Abort(MPI_COMM_WORLD, 59) - process 3
>> [cli_3]: aborting job:
>> In fact, I get the same thing even if I set the AOType to AOBASIC, in other words
>> call DMDASetAOTYPE(da,AOBASIC,ierr)
>> Previously, I did not set an AOType, and only called DMDAGetAO, which works fine, and from what I can tell sets the type to basic.
>> Thanks, Randy M.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160217/3522520c/attachment.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160217/3522520c/attachment-0001.obj>
